Lexus IS License Plate LEDs! Plug and Play install! Same-day shipping! - Lexus IS Forum
 6Likes
post #1 of 45 (permalink) Old 11-19-2014, 10:58 AM Thread Starter
Supporting Vendor
Diode Dynamics's Avatar
Quoted: 15 Post(s)
Arrow Lexus IS License Plate LEDs! Plug and Play install! Same-day shipping!
License plate bulbs are used to illuminate the rear license plate on your Lexus IS. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to LED, you can easily add this luxury look to your Lexus IS!
The installation is 100% plug-and-play, just replace your factory bulb.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your Lexus looks at night.
Brightness:
Diode Dynamics offers several bulb options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of the OEM bulbs. These are the brightest model we offer! (92 lumens)
Bulb Design
SMD2: Similarly compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your Lexus IS).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
2001-2008 Lexus IS Sedan License Plate LEDs
2002-2005 Lexus IS Sportcross Plate LEDs
New HP3
If you have any questions, please don't hesitate to post, PM, or Email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Diode Dynamics is offline
post #2 of 45 (permalink) Old 03-29-2015, 10:36 AM
PM coming your way.
'02 CWP IS300 5-spd
250k+ mi.
hawksui is offline
post #3 of 45 (permalink) Old 03-30-2015, 07:41 AM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
Originally Posted by hawksui View Post
PM coming your way.
PM sent!
Thank you very much
Nick C.
post #4 of 45 (permalink) Old 04-14-2015, 05:08 PM
when it says quantity 1 is that a single or a pair?
metalicblue300 is offline
post #5 of 45 (permalink) Old 04-15-2015, 07:18 AM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
That would be a pair
Be sure to read the listing as it describes what is included with each quantity
If you have any questions, feel free to give us a call: (314) 205-3033
Thanks!
Nick C.
post #6 of 45 (permalink) Old 04-28-2015, 05:14 PM
Quoted: 26 Post(s)
On the site you show an hp5.
Is that &/or the hp3 confirmed for proper fitment if the bulbs are bigger than normal halogen bulbs?
broketuner is offline
post #7 of 45 (permalink) Old 04-29-2015, 08:40 AM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
The HP3/HP5 models are the same length and will fit nearly every license plate application
If you have any questions about fitment, please feel free to give us a call: (314) 205-3033
Thanks!
Nick C.
post #8 of 45 (permalink) Old 05-01-2015, 02:06 PM
Quoted: 26 Post(s)
Any similar lit up shots of the hp5?
post #9 of 45 (permalink) Old 05-01-2015, 02:16 PM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
Nick C.
post #10 of 45 (permalink) Old 06-12-2015, 07:50 AM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
Nick C.
post #11 of 45 (permalink) Old 10-29-2015, 01:27 PM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
Our 194 HP3 and HP5 LEDs are now available in 4000K / 5000K / 6000K Color Temperatures
Nick C.
post #12 of 45 (permalink) Old 11-15-2015, 05:48 PM
Quoted: 36 Post(s)
Will the HP5 fit the IS300 (sedan) license plate? There isn't much room on our vehicles. So far I have bought 3 different types of LEDs off the web and none have fit due to length. Can you confirm? You guys stated "fit nearly most applications"
-Mike
MY2J is offline
post #13 of 45 (permalink) Old 11-16-2015, 08:20 AM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
The HP3 and HP5 feature a unique diffusing lens and are designed to be a direct replacement for the incandescent 194 bulbs they replace. If you have clearance issues, the lens can be removed to make them even shorter than factory incandescent bulbs.
Nick C.
post #14 of 45 (permalink) Old 11-17-2015, 04:54 AM
Quoted: 36 Post(s)
payment sent
Diode Dynamics likes this.
-Mike
MY2J is offline
post #15 of 45 (permalink) Old 11-17-2015, 12:21 PM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
Thank you for ordering with us!
Nick C.
  Lexus IS Forum > Vendors > Diode Dynamics
New 'super bright' LED license plate bulbs installed Steve Theodore Showroom 14 10-19-2013 07:03 PM
Bright License Plate bulbs IS250/350 luig300 Canada 12 03-10-2009 08:30 AM
Bright LED License Plate Bulbs......... kaikaekahi Showroom 33 11-20-2008 09:09 PM
License plate LED's that aren't too bright??? jollibee jiant Showroom 2 09-25-2008 07:39 AM
IS250 has bright white license plate lights? amitkc General Discussion 22 02-04-2006 09:39 AM
