Lexus IS Fog Light LED Bulbs! Install Video! Luxeon LED Replacement Housings! New SLF - Lexus IS Forum
 3Likes
  • 1 Post By Diode Dynamics
  • 1 Post By toneekay
post #1 of 13 (permalink) Old 06-15-2015, 12:48 PM Thread Starter
Supporting Vendor
Diode Dynamics's Avatar
Quoted: 15 Post(s)
Arrow Lexus IS Fog Light LED Bulbs! Install Video! Luxeon LED Replacement Housings! New SLF
Diode Dynamics carries LED bulbs for replacement of your Lexus IS fog lights, in all major sizes. They are available in HP, XP, and SLF styles. This will make your Lexus IS' fog lights a nice bright white that closely matches factory-equipped HID lighting & LED DRLs! Just simple plug and play, replace the bulb and you are good to go! We also offer Luxeon LED Housings for a complete replacement of your Lexus IS & IS-F factory fog light housings (See Install Video)
Diode Dynamics offers the brightest, highest-quality bulbs on the market. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Slightly lower brightness than factory.
XP80: 510 lumens. Similar brightness to factory.
SLF: Street Legal Output. Much brighter than factory. These are bright! USA Made!
Luxeon LED Replacement Housing: Powered by three genuine Luxeon T LED chips per side, the perfect 5000K white color provides a brilliant LED illumiunation, with a Trulux measured output of 600 lumens. (Please note: similar styles of lamp can be found online which claim much higher output, but these numbers are highly inflated. These lamps are the brightest on the market!)
Available for the following IS Models and Model Years:
Lexus IS250 2011-2014
Lexus IS350 2011-2014
Lexus IS-F 2008-2013
Bulb Design
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Luxeon LED Replacement Housing: Integrated projector lens distributes light in a wide, even pattern, compliant with DOT and ECE standards for use on-road. With a durable poly-carbonate lens, aluminum housing, and constant-current drive circuit, these LEDs will be durable and reliable for years to come.
Diode Dynamics' products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
Diode Dynamics: Fog Light LEDs for 2008-2013 Lexus IS F
Diode Dynamics: Fog Light LEDs for 2006-2010 Lexus IS Sedan
Diode Dynamics: Fog Light LEDs for 2003-2005 Lexus IS Sedan
Diode Dynamics: Fog Light LEDs for 2003- 2005 Lexus IS Sportcross
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics is offline
post #2 of 13 (permalink) Old 06-15-2015, 12:55 PM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
post #3 of 13 (permalink) Old 03-24-2016, 01:06 PM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
Customer Submitted photo with Yellow XML2 Installed
Nick C.
post #4 of 13 (permalink) Old 04-12-2016, 03:48 PM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
H11 XP80 Installed on a 2014 IS 250
Nick C.
post #5 of 13 (permalink) Old 01-29-2018, 09:49 AM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
Curious to see how the new Diode Dynamics, USA-Made, SLF performs in fog light locations? (2015+ F150 shown for comparison)
post #6 of 13 (permalink) Old 02-28-2018, 09:02 AM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
Why Do Yellow LEDs Look Green? | Yellow LED Fog Lights from Diode Dynamics
toneekay likes this.
post #7 of 13 (permalink) Old 02-28-2018, 10:27 AM
Quoted: 33 Post(s)
Been meaning to replace a few of my lights, so I did just that!... Just placed an order for new 6K HID bulbs, LED fogs, and sidemarkers!!!
Diode Dynamics likes this.
toneekay is offline
post #8 of 13 (permalink) Old 02-28-2018, 10:33 AM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
Thank you for your support @toneekay!!
Looking forward to seeing pictures!
Nick C.
post #9 of 13 (permalink) Old 02-28-2018, 10:36 AM
Quoted: 33 Post(s)
Nick C.
I will definitely get some before and after pictures up once everything is installed!
toneekay is offline
post #10 of 13 (permalink) Old 03-01-2018, 09:19 AM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
Diode Dynamics SLF Fog Light LEDs
post #11 of 13 (permalink) Old 04-11-2018, 01:45 PM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
Diode Dynamics SLF LED Fog Lights / USA Made
post #12 of 13 (permalink) Old 04-30-2018, 04:50 PM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
Behind the LEDs: Trevor Dobbins
post #13 of 13 (permalink) Old 06-21-2018, 04:28 PM Thread Starter
Supporting Vendor
Quoted: 15 Post(s)
Don't forget to send us a PM for the free-shipping code!
  Lexus IS Forum > Vendors > Diode Dynamics
Lexus ISF LED Conversion Overview Diode Dynamics Diode Dynamics 5 06-15-2015 12:53 PM
How to turn off brake light indicator for using LED light bulbs? kavinbao Showroom 2 05-07-2010 02:57 PM
Fog Light: Halogen bulbs or LED Vincerulz Showroom 21 03-03-2010 12:08 PM
LED Light Bulbs Jballer Showroom 15 07-08-2007 11:26 PM
