Headlight Halos - Lexus IS Forum
 7Likes
  • 2 Post By mm71522
  • 2 Post By blkdout
  • 1 Post By mm71522
  • 1 Post By blkdout
  • 1 Post By Diode Dynamics
post #1 of 15 (permalink) Old 05-13-2015, 04:14 PM Thread Starter
Cherisher
blkdout's Avatar
Quoted: 631 Post(s)
Headlight Halos
Have you guys figured out what size Angel Eye rings are needed for the IS300? I don't see Lexus listed on the site as having an available kit.
I have a pair of new headlights and I'm deciding what to do with them!
Once I open them up I'll share the inner diameter if you guys don't have it.
'03 Wagon - Stock
'02 Sedan - Not Stock
-Hiral
blkdout is offline
post #2 of 15 (permalink) Old 05-13-2015, 06:15 PM
mm71522's Avatar
Quoted: 353 Post(s)
I have AAC halos in my garage. Let me know if you want the measurements and I'll get them for you
IS3_FTW and blkdout like this.
Mike
'02 AR IS300; M98 L-Tuned
TOKICO HP/TANABE NF210
ENKEI KOJIN 18X8.5+35/9.5+30
DIY: Nav+Aftermarket HU
DIY: Timing Belt
My Thread
mm71522 is offline
post #3 of 15 (permalink) Old 05-13-2015, 06:42 PM Thread Starter
Cherisher
blkdout's Avatar
Quoted: 631 Post(s)
That would be helpful indeed! The outside diameter is what's needed whenever you have time. No rush!
Still have AAC halos installed but cut the inverters out after so many warranty failures. I gave up on the whole concept until our newest vendor joined!
I think promoting an IS300 kit would be beneficial for DiodeDynamics as well
IS3_FTW and mm71522 like this.
'03 Wagon - Stock
-Hiral
blkdout is offline
post #4 of 15 (permalink) Old 05-13-2015, 07:10 PM
mm71522's Avatar
Quoted: 353 Post(s)
Good to know about the AAC failures.
Glad I never installed them. I busted my headlights open years ago and broke a low beam halo while installing it, so I gave up.
The outer diameter on the high beam halo is 11.75cm and 14cm on the low beam
blkdout likes this.
Mike
DIY: Timing Belt
My Thread
mm71522 is offline
post #5 of 15 (permalink) Old 05-13-2015, 07:42 PM Thread Starter
Cherisher
blkdout's Avatar
Quoted: 631 Post(s)
You rock, Mike! Thanks a bunch!
Looks like the 120mm and 140mm rings should do it!
AAC bulbs were fine but the inverters just kept going out. Come to think of it, I believe DiodeDynamics sells separate inverters that just might remedy that issue!
IF I decide to go this route again, I think the COB halos might do the trick and at the same time, eliminate the inverter and need for AC power altogether.
mm71522 likes this.
'03 Wagon - Stock
-Hiral
blkdout is offline
post #6 of 15 (permalink) Old 05-14-2015, 04:12 AM
Quoted: 569 Post(s)
yeah CCFL inverters are easily replaceable, the CCFL halo itself works forever
TobiasSing is online now
post #7 of 15 (permalink) Old 05-14-2015, 07:12 AM
Supporting Vendor
Diode Dynamics's Avatar
Quoted: 15 Post(s)
^^You are correct!
CCFL may not be the brightest style, but they are very reliable. The inverters can be replaced without having to take the headlights apart.
We also offer RGB SMD with external regulators, but they won't have the same smooth appearance as CCFL or COB
We've done an IS300 before, but I don't recall what the ring sizes were TBH. It was quite some time ago. They are so bright that we had to turn the brightness down for these pictures:
Feel free to give us a call if you have any questions or need help with professional installation: (314) 205-3033
Thanks!
Nick C.
Diode Dynamics is offline
post #8 of 15 (permalink) Old 05-14-2015, 09:56 AM Thread Starter
Cherisher
blkdout's Avatar
Quoted: 631 Post(s)
Okay, I'm looking into the COB version. Assuming 120mm and 140mm are the correct sizes for the IS, Will this list complete the kit?
$70 - High beam rings
$80 - Low beam rings
$30 - RGB Controller
$20 - Harness
'03 Wagon - Stock
-Hiral
blkdout is offline
post #9 of 15 (permalink) Old 05-14-2015, 10:05 AM
Supporting Vendor
Quoted: 15 Post(s)
$20 - Harness
We only offer single color COB at the moment
Those prices are correct for COB, but there's no reason to buy a controller with single color
Nick C.
blkdout likes this.
post #10 of 15 (permalink) Old 05-14-2015, 07:11 PM Thread Starter
Cherisher
blkdout's Avatar
Quoted: 631 Post(s)
Makes sense! In that case will a dimmer be useful or does the regulator take precedent? At the least, I'd like to control brightness with a potentiometer.
'03 Wagon - Stock
-Hiral
blkdout is offline
post #11 of 15 (permalink) Old 05-15-2015, 03:25 AM
Quoted: 569 Post(s)
Well if you're going to buy a new set, you should buy one that is built for the IS300. Since the high beam is not a full circle, you will have trouble fitting a universal 120mm in there (though it might be possible).
post #12 of 15 (permalink) Old 05-15-2015, 07:23 AM
Supporting Vendor
Quoted: 15 Post(s)
Check out this video
Nick C.
post #13 of 15 (permalink) Old 06-05-2015, 07:15 AM
Supporting Vendor
Quoted: 15 Post(s)
We are actually doing a set of IS300 headlights right now
Should be able to get a new listing creating for the site
Thanks!
Nick C.
post #14 of 15 (permalink) Old 06-05-2015, 07:47 AM Thread Starter
Cherisher
blkdout's Avatar
Quoted: 631 Post(s)
Ah! I forgot to thank you for posting that video... good stuff. Thanks!
This would be great for the site. As the car ages, our options definitely diminish so it's always nice to see new supporting products! Haven't started on the project yet (car is still undergoing surgery) but I'm excited to see this. It will definitely help make up my mind
'03 Wagon - Stock
-Hiral
blkdout is offline
post #15 of 15 (permalink) Old 06-05-2015, 08:59 AM
Supporting Vendor
Quoted: 15 Post(s)
We had an IS300 in the studio about two years ago, (in our old facility) and didn't have much time to take comparison photos
Index of /images/lexus
Nick C.
  Lexus IS Forum > Vendors > Diode Dynamics
ISX50 headlight and foglight halos is300soon Showroom 3 08-09-2011 01:06 AM
