GCMBob overdoes it again - Page 3 - Lexus IS Forum
post #31 of 87 (permalink) Old 06-17-2011, 11:16 PM Thread Starter
The wife traded me some time this eve so i got the rear section of the brake lines run.
Also mocked up how i am brobably going to do the handbrake. I have to get the gearbox installed before i can remember the throw on the shifter though so this will be a last detail thing. The line roughts funny in the back because it goes around the fuel pump access.
And the rear section. Like a genius i used the polymer coated line for the handbrake to T first. so left me with one silver and one black one in the rear. Oh well. I need to make tie downs for them still but im pretty happy with my flares etc on them.
My Chassis Build The "Other" Build
gcmbob is offline
post #32 of 87 (permalink) Old 07-14-2011, 08:52 PM Thread Starter
Its Been A while. The wife went away with the kids for a week so i had time to hole up and get some work done.
Finished bending the last brake line from the firewall to the prop valve. All the lines just need tying down now.
Also pictured is the ECU mounting. It used to bolt to the underside of the AC so i had to weld a fer tabs on to secure it.
Also got new rear rotors and replaced all the studs with ARP
I went to put on the Whiteline rear swaybar kit i got but as i bolted it up i noticed there was alot of play between the bar and the bushing. Sure enough the wrong bushings came in the kit. The company i got it from is trying to sort it out for me. Shakes fist at [email protected]
Also cut off the rear bushing in prep of installing the whiteline antilift kit, and decided to freshen up the paint a bit. They are different colours because...internet.
My buddy just got a strlet that he wants to fix up for rally so i broke him in by letting him help me delete wires from the dash. Filled up a plastic grocery bag and cleaned it up a lot
Besides this stuff i been cleaning things here and there and clearenced the rear wheel whels a bit more and painted them and cleaned goo off the body in prep for paint etc. Still waiting on a few parts to come in but its moving along.
gcmbob is offline
post #33 of 87 (permalink) Old 08-06-2011, 04:54 PM Thread Starter
Been slowly getting more work done. De wired the engine harness of un needed BS.
Put the Dash in to get a feel for everything and where i want to put the ignition. Im dumping the key barrel so ill just stick a "key" in the slot and turn to ign on then wire in a push button cuz the turn to start part takes a high amount of tourque for how it will have to be mounted.
Been spendint most time cleaning up and refreshing the engine. the outsides anyway. Changing timing belts and idlers and cleaning up the oil pump and pressure valve. Pulled that out and polished the pore and piston. changing the water pump and oil seals etc. The engine has a little varninish but over all not in bad shape. pressure valve on the bottom.
i went to put on the oil pan from the original engine (a '95) and it wouldnt go in. the pickup was hitting it. This engine is a '92 or so and it seems at some point they changed the pan and pickup.
The newer pan is on the bottom and it is shorter by wider. I decided to change to the newer one as it gives the car a little more ground clearence.
differences in the pick ups
My crank pulley is pretty nasty and i want to change to a lightened one but ill get around to that. Its pretty heavy.
I also cleaned up the valve cover some. all the pain is off so i degreaed it and got all the corrosion off and decided to leave it like that. But i polished the "TOYOTA" letters. A bit of a play on an old motor in a nely built car type thing... or some crap.
My clutch came in too. Got a sprung hub for the wife to cut down on the harshness a bit.
Also got the biggest joke when i went to check the original engine when i was replacing the waterpump on this one.
I still cant figure out how the car made it the 10 miles to my house...I need to find the person that worked on this car and beat them with a tourque wrench.
gcmbob is offline
post #34 of 87 (permalink) Old 09-21-2011, 08:49 AM Thread Starter
gcmbob is offline
post #35 of 87 (permalink) Old 09-21-2011, 11:47 AM
Technical Poseur
Quoted: 31 Post(s)
Bob...if I ever make it rich I'm gonna fly you in to be a laborous set of hands.
-Tom- is offline
post #36 of 87 (permalink) Old 09-21-2011, 12:52 PM Thread Starter
you better be making some bill gates bank
gcmbob is offline
post #37 of 87 (permalink) Old 10-19-2011, 09:57 AM Thread Starter
Being lazy. you just get pics
gcmbob is offline
post #38 of 87 (permalink) Old 10-19-2011, 01:44 PM
Technical Poseur
Quoted: 31 Post(s)
Any reason you relocated the oil filter? Looks easy enough to service where it is.
-Tom- is offline
post #39 of 87 (permalink) Old 10-19-2011, 02:21 PM Thread Starter
The intake for the turbo is right there and this way it gets a cleaner shot in. Plus it will make it easier if I add an oil cooler later.
gcmbob is offline
post #40 of 87 (permalink) Old 10-20-2011, 01:25 PM
S*A*G*E
BobbyJ'sIS's Avatar
definately liking the build, good skills ya got there, and I agree with the movement of the Oil Filter, one its easier and two gets it outta the way
'03 SD E-shift Ibisweiss White Chargespeed.Vertex.Volk Racing G2 Type 2.Tein Super Street.Tanabe.VIS.Bride
Sage Autosports
Built from the ground up!! My IS build thread
BobbyJ'sIS is offline
post #41 of 87 (permalink) Old 10-24-2011, 06:53 AM Thread Starter
hanbrake version 1...hate it.
version 2 using and old strut brace...hate it less. Will get it turned down on a lathe
Got around to porting the Maifold. Runner 3 has a major protusion from a stub boss. So i smoothed it out. I went from 18in vacuum to 20in on my old car just by doing this. So i know it helps, even if its just evening out the flow across the cylinders.
Stock
Ported
gcmbob is offline
post #42 of 87 (permalink) Old 11-08-2011, 09:56 AM
Bezik777's Avatar
Quoted: 44 Post(s)
Looking great ....wires by the bags lol keep up the good work
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #43 of 87 (permalink) Old 12-16-2011, 09:07 PM
man, i work for express oil change, and we use valvoline filters exclusively...they are garbage...i really recommend switching to a wix/mobile/bosch.....much better filter.
1st Gen Elitist
RIVALHOUSEGARAGEDOTCOM
Avernier is offline
post #44 of 87 (permalink) Old 12-16-2011, 09:29 PM Thread Starter
I get them free and are basically changed every 3 race meets or so, they prob get ... 30 miles on them. They are probably good enough.
gcmbob is offline
post #45 of 87 (permalink) Old 12-18-2011, 09:42 AM
Loving this build. Never been interested in a build on a Starlet
PandaEj1 is offline
