Any Camry guys? NEED HELP - Lexus IS Forum
post #1 of 5 (permalink) Old 07-14-2016, 11:15 PM Thread Starter
mm71522's Avatar
Quoted: 353 Post(s)
Hey guys!
I'm looking for advice as I'm stumped.
I just did a head gasket replacement on my Dad's 1999 Toyota Camry 2.2. Everything torqued to spec. Also replaced the timing belt, spark plugs/wires, o rings on the injectors since they were included in the engine gasket kit.
The CEL codes: P0105 and P0106 - Manifold Absolute Pressure Performance
-The car start right away but the RPMs bounce around 500-1000rpms
-A lot of black gunk out of the exhaust
-I removed the spark plugs and the tips were full of black dust/gunk
Things I've checked/done:
-Timing
-Cleaned throttle body
-Checked the injectors to make sure an o ring wasn't pinched
-Spark plug gap
-Swapped MAP sensors with our other Camry
-Checked for vacuum leaks
Thanks for any help or advice I can get
Mike
'02 AR IS300; M98 L-Tuned
TOKICO HP/TANABE NF210
ENKEI KOJIN 18X8.5+35/9.5+30
DIY: Nav+Aftermarket HU
DIY: Timing Belt
My Thread
mm71522 is offline
post #2 of 5 (permalink) Old 07-15-2016, 12:07 AM
Quoted: 81 Post(s)
Did you check the voltage to the map from ignition state to start and see if it is changing? Check the wiring/connection to the map. Its sound to be really running rich like perhaps a sensor is off and the O2 readings are going up/down quite aggressively.
Also your TPS is low at 10 percent and the load is at 96.
isthisme is offline
post #3 of 5 (permalink) Old 07-15-2016, 09:31 AM Thread Starter
mm71522's Avatar
Quoted: 353 Post(s)
I have not checked the voltage yet but I will tomorrow.
Yeah I also noticed the load and TPS. Seems to be at WOT which made me think of a vacuum leak somewhere. It is running very rich. Maybe the TPS is out of spec and needs adjusting.
Thanks for your input
Mike
DIY: Timing Belt
My Thread
mm71522 is offline
post #4 of 5 (permalink) Old 07-20-2016, 07:21 PM Thread Starter
mm71522's Avatar
Quoted: 353 Post(s)
Thanks for the help @isthisme
This is the hose going to the MAP sensor. I missed it on first check since its so small. It was making the car think it was at WOT all the time. Everything good now.
Mike
DIY: Timing Belt
My Thread
mm71522 is offline
post #5 of 5 (permalink) Old 07-21-2016, 01:08 AM
Quoted: 81 Post(s)
Happy to help and glad you found the issue. One thing I know for sure, when something isn't working right there is always a reason!
isthisme is offline
Toronto is300 guys, which EMS, who tuned your car? arunanlogen General Discussion 0 06-17-2016 05:24 PM
Do you guys trust alibaba/global sources censoredgreen General Discussion 2 06-09-2016 03:14 PM
Chemical Guys Nonsense? mhx Showroom 6 06-06-2016 03:25 AM
Sup guys. Church401 New Member Introductions 0 04-04-2016 01:35 PM
is300 guys in arizona adelosreyes1 General Discussion 0 11-22-2015 08:40 AM
