IS300 Maintenance DIY Info + extras - Lexus IS Forum
post #1 of 42 (permalink) Old 05-07-2009, 03:36 AM Thread Starter
Juic's Avatar
I've collected pretty much everything you need to know to do your major services by yourself. I have attached them as PDFs at the bottom of this post, but here are the corresponding links to each PDF(These users deserve the real +rep):
https://my.is/forums/f221/60k-service...edures-256162/
https://my.is/forums/f221/diy-install...inutes-346845/
https://my.is/forums/f221/diy-brake-f...cement-281014/
https://my.is/forums/f221/diy-timing-...r-pump-348511/
https://my.is/forums/f221/spark-plug-...tached-254217/
https://my.is/forums/f221/transmissio...tached-254631/
https://my.is/forums/f221/differentia...tached-254397/
https://my.is/forums/f221/oil-change-...tached-264598/
https://my.is/forums/f221/brake-pad-r...tached-255699/
I got about half way through typing the 60K service and realized how long it would take so I scanned the manual instead:
30K Service<<>>35K-40K Services<<<>>45K Service<<>>50K-55K Services
60K service<<>>65K-70K Services<<>>>75K Service<<>>80K-85K Services
90K Service<<..>95K-100K Services<<>>105K Service<.>>110K-115K Services
120K Service<>>125K-130K Services<<.>135K Service<<.>140K-145K services
150K Service
__________________________________________________ _________________________________________________
OK here are the parts lists(big thanks to Brit6):
60K Service:
  1. A/C Filter(Optional): Part No. 87139-48020
  2. Oil Pan Drain Washer: Part No. 90430-12031
  3. Oil Filter: Part No. 90915-20003
  4. Toyota Coolant: Part No.
    1. 00272-1LLAC-01 (QTY=2)*
    2. 00272-SLLC2 (QTY=2)*
  5. Spark Plugs(Only for Platinum Plugs, not Iridium): Part No. 90919-01219 (Qty=6)
  6. Engine Air Filter: Part No. 17801-46080 (Lexus)
  7. Brake Fluid: Part No. 00475-1BF03*
  8. Toyota Oil: Part No.
    1. 0W20: 00279-1QT20-01*
    2. 5W30: 00279-1QT5W-01*
    3. 10W30: 00279-1QT30-01*
Sewell has a bundle for the whole service, the only thing missing is the oil:
http://is.sewellparts.com/accessorie...2002/1967.html
90K Service:
  1. Timing Belt: Part No. 13568-49036
  2. Timing Tentioner: Part No. 13540-46030
  3. Idler: Part No. 13505-46041
  4. T/Stat: Part No. 90916-03093
  5. T/Stat Gasket: Part No. 16325-62010
  6. PCV 5/2000-5/2001: Part No. 12204-46030
  7. PCV 5/2001 and up: Part No. 12204-46031
  8. O-Ring Bypass Outlet: Part No. 96761-24028
  9. Serepentine Tensioner: Part No. 16620-0W025
  10. A/C Filter Part: No. 87139-48020-83
  11. Crankshaft Seal: Part No. 90311-46001
  12. Oil Pan Drain Washer: Part No. 90430-12031
  13. Oil Filter: Part No. 90915-20003
  14. Differential Drain/Fill Crush Wash(Optional): Part Number: 12157-10010
  15. O-Rings Bypass Pipe: Part No. 96761-24022 (Qty=2)
  16. Camshaft Seals: Part No. 90311-40020 (Qty=2)
  17. Coolant: Part No.
    1. 00272-SLLC2 (Qty=2)*
    2. 00272-1LLAC-01 (Qty=2)*
  18. Spark Plugs: Part No. 90919-01219 (Qty=6)
  19. Drive Belt: Part No. 90916-02412 (Lexus)
  20. Water Pump: Part No. 16100-49876-83 (Lexus)
  21. Engine Air Filter Part: No. 17801-46080 (Lexus)
  22. PCV Grommet: Part No. 90480-18001 (Lexus)
  23. Differential Fluid(Optional): Part No. ?
  24. Brake Fluid: Part No. 00475-1BF03*
  25. Toyota Oil: Part No.
Sewell is also offering a bundle for the 90k service and water pump/Timing Belt Service:
http://is.sewellparts.com/accessorie...2002/1987.html
http://is.sewellparts.com/accessorie...2002/1972.html
Also, here is a link to a bunch of other DIY threads:
https://my.is/forums/f221/is300-offic...thread-383582/
Another also, I would like to plug Toyodiy if you need to find ANY(OEM, JDM, EDM, ADM?) Toyota part number.
File Type: pdf 03 Power Steering Fluid Flush Hiroshima.pdf (158.6 KB, 2166 views)
File Type: pdf 07 Brake Fluid Replacement DIY pinoyballah.pdf (113.1 KB, 1724 views)
File Type: pdf 10 Timing Belt Water pump sdfontanini.pdf (797.0 KB, 3375 views)
White2003Lexus likes this.
Juic is offline
post #2 of 42 (permalink) Old 05-07-2009, 03:46 AM
ahhhhh a updated DIY info page!
good looking out!!
2002 IS300 BO, 6-Speed
2002 IS300 CW, E-Shift → 5-Speed sold
vroomRollLEX is offline
post #3 of 42 (permalink) Old 05-07-2009, 04:13 AM Thread Starter
Juic's Avatar
You're welcome Hopefully this will get stickied. I'll update it with more info as I come up with it.
Juic is offline
post #4 of 42 (permalink) Old 05-07-2009, 07:12 AM
sent rep your way, i was waiting for someone to do this!
nyczzzjohn is offline
post #5 of 42 (permalink) Old 05-07-2009, 07:13 AM
Quoted: 9 Post(s)
damn good stuff...all in one spot. +rep. hopefully it gets stickied
2005 MSM Lexus IS300
Stock?
SupraMan1784 is offline
post #6 of 42 (permalink) Old 05-07-2009, 10:25 AM
Ninja?
WE need more members like JUIC.
And hopefully [email protected]$$ people will SEARCH and READ the STICKIES to find JEWELS like this thread.
©2006 my.IS
2015 F32 w/ N55 Alpine White
DO SUSPENSION FIRST!
kayotik is offline
post #7 of 42 (permalink) Old 05-07-2009, 11:33 AM
Patriot
nice job..thanks for putting that together.
'03 5 speed
Carson Tuned/VOLK/Seibon/PLP/TRD/TEIN/TANABE/K&N/IPT/B&M/MEGAN/OBX
pinoyballah is offline
post #8 of 42 (permalink) Old 05-14-2009, 01:15 PM Thread Starter
Juic's Avatar
Updated with scans for all the services from 30K to 150K. If you have less than 30K miles on your IS you probably have the manual and don't need this page anyway.
I'm not going to do parts list for them since they are all pretty much the same and all items can be found on the L-tuned OEM site.
Juic is offline
post #9 of 42 (permalink) Old 05-31-2009, 07:50 AM
nice job ...rep that
bdivell is offline
post #10 of 42 (permalink) Old 06-05-2009, 02:05 PM
Great job, thanks a lot. rep+
deburn is offline
post #11 of 42 (permalink) Old 07-01-2009, 04:48 PM
Oh very nice, very nice.
nautox is offline
post #12 of 42 (permalink) Old 08-03-2009, 02:54 PM
Thanks guys for informative DIY Instructions...
sean_is300 is offline
post #13 of 42 (permalink) Old 08-03-2009, 03:11 PM
acumenhokie's Avatar
Here's another good DIY thread for 1st gen owners:
https://my.is/forums/f138/is300-offic...thread-383582/
IS300 Alumni
acumenhokie is offline
post #14 of 42 (permalink) Old 06-24-2010, 01:38 PM
Just signed up yesterday and just wanted to thankyou for the post.
First Lexus..Wanted this car since I was 17 (the year they came out) and finally got one.
One owner. Bone stock. '02 Black on Black. 90k
konacar is offline
post #15 of 42 (permalink) Old 07-29-2010, 11:33 AM Thread Starter
Juic's Avatar
You're welcome. This is a really awesome post now that I look back at it. I sure did have a lot of free time back then.
Has anyone tried to use the part numbers recently? Mainly I want to know if there are any errors/changes so I can update the post. I don't think L-tuned has the 1 dollar shipping but I might be wrong.
Juic is offline
DIY INFO: Black Headlight mod..... this one with PICS! CWis300 DIY/tutorial forum 121 09-13-2010 08:13 PM
DIY wideband free info goohead Go Faster 5 03-03-2005 10:25 AM
DIY Maintenance / Maintenance costs . . . mtsao General Discussion 6 06-12-2003 06:28 AM
Need info on fluids for maintenance DHCrocks General Discussion 7 02-18-2003 08:50 PM
Got my new IS and extras! lexluger General Discussion 4 05-13-2002 09:28 AM
