How-to: Change your Main Gauge Cluster & Ignition Ring lights (LEDs) *pics* - Page 6 - Lexus IS Forum
 18Likes
post #76 of 641 (permalink) Old 10-07-2008, 02:30 PM
Originally Posted by 5thgearIS View Post
So are you guys buying these blue bulbs for the dash and climate controls and heated seats and key ring off of lexstasy or what?Sexy black lexi and a couple other guys got the blue whats the bulb size for dash,climate,seats,clock,key ring?What company?
Ya most everything is on the first post, but the heated seat buttons are type A bulbs, and I also did the shifter and the snow/power buttons. The shifter was size 24 i think and the snow was type A.
2001 Black Onyx R.I.P. :(
2003 GGP Sportdesign - Starting the modding all over again!
Sexy Black Lexi is offline
post #77 of 641 (permalink) Old 10-08-2008, 11:02 AM
that site is hard to navigate.
5thgearIS is offline
post #78 of 641 (permalink) Old 10-08-2008, 08:33 PM
Check my link for pics of the buttons
I mentioned this before, but I tried replacing the heated seat buttons with Neowedge Type A bulbs from autolumination.com but had difficulties because the base was an extremely tight fit. As I tried turning them, the base started to get mangled. I decided to keep the stock bulbs in. Somebody previously mentioned that you need to also remove a film that makes the light amber. Can somebody confirm? Take a look at my link for the size of the heated seats and traction control. The traction control is a neowedge type B.
Also, I did replace the light in the shifter. It's a #74 bulb. I used one from superbrightleds.com and shaved the hell out of it to make it fit. I have to do the same for the ashtray light because it's not currently lighting up. Once that's complete, I may splice the permanent bulb for the cigarette lighter and use the snakelight from autolumination.com.
Sorry for the flip flop of bulbs from two different sites. I just preferred certain bulbs for certain applications.
Picasa Web Albums - Xerxes - My IS300
XMan714 is offline
post #79 of 641 (permalink) Old 10-09-2008, 08:46 AM
Originally Posted by nyczzzjohn View Post
c'mon man, i posted everything in the first post of this thread. you will find everything you need there.
avoid lextasy like the plague.
Ya sorry I see that but that autolumination site is not user friendly, also military computers didnt let me see that link or pictures lol so ya got to understand the beast of the federal govt.....thxs I had to email lumination and got a $49 total for 3x of star smt blue #194 bulbs and 3 of the tri power 3 led #24 bulb blue.Cant wait!
post #80 of 641 (permalink) Old 10-09-2008, 08:53 AM Thread Starter
I heard the same, but haven't seen anything written up on it.
no problem man, good luck with the mod. post some pics up when you're done.
nyczzzjohn is offline
post #81 of 641 (permalink) Old 10-09-2008, 12:02 PM
I'm veering off the original topic of Main gauge cluster and ignition ring lights into climate control. There's another posting for that, but I'll update both topics just in case.
I've uploaded additional pics of the cigarette lighter bulb and shifter bulb. The shifter was a bit tough to remove. Pulling real hard to pry it out seemed like I was about to break something. Not sure what position was best, but I believe I moved the shifter to neutral as nyczzzjohn posted. In any case you do need to put a lot of effort to yank it out. Unless I'm doing it the hard way, and should have removed other pieces, I just pulled it off once the top ashtray console was removed.
XMan714 is offline
post #82 of 641 (permalink) Old 10-18-2008, 06:25 PM
I just recently brought a 03 is300 and this the first thing I have done to the car. And by the way I am a complete newbie, if you follow the write up you will do fine. Here are the pics:
107_0997.jpg - Image - Photobucket - Video and Image Hosting
one more thing it looks a little dim in the picture.
sqchess is offline
post #83 of 641 (permalink) Old 10-20-2008, 12:12 PM
$117 ducks worth the led bulbs on way from superlumination cant wait will post when I install and take pics
post #84 of 641 (permalink) Old 10-22-2008, 01:11 PM
You'll become LED obsessed, as I have. Once you replace the main gauge cluster and key ring, you'll probably hit the climate controls, then the driver and passenger doors (also replacing the red cover with clear covers off a 2001 ES 300. Check my previous posts or my link to find out the part #). You'll probably change the dome lights and vanity lights next, which for now I've skipped. I'm stuck at this point because I've already replaced the ashtray and shifter bulbs. Too bad the cigarette lighter is a permanent bulb. I haven't felt like splicing the wires and replacing with an LED at this point.
XMan714 is offline
post #85 of 641 (permalink) Old 10-22-2008, 04:49 PM
Hey x-man wer did u get the clear lenses 4 the doors no one site Lextasy that has them really trying to avoid buying them from that ripp off site any help? thanxs!!!!
2005 CW E-SHIFT/FALKEN FK452
SRT INTAKE/GREDDY EVO2/EBC ROTORS/REDSTUFF PADS/STOPTECH SS LINES
AAC CF Cooling Plate/TECKPRO GROUNDING KIT
FIGS HOOD PROP-HEATSHEILD/WR ENGINE TORQUE DAMPER
ROYAL PURPLE-Oil,Tranny,Diff/JDM WINDOW-SUNROOF VISORS
WICKED IS300 is offline
post #86 of 641 (permalink) Old 10-22-2008, 06:50 PM
SEAHAWKS!!
IS3_FTW's Avatar
Quoted: 552 Post(s)
Its a stock feature for the 01 ES300. Its a direct bolt on replacement
I have it and luv it
Phil
2001 IS300
IS3_FTW is offline
post #87 of 641 (permalink) Old 10-23-2008, 09:41 PM
Lexus parts world. I think it was about $20 with shipping. I think the link provided will be directly to the 2001 ES 300 clear lenses.
Lexus parts World
XMan714 is offline
post #88 of 641 (permalink) Old 11-05-2008, 06:05 PM
what is the little bulb used for? right next to the #24 bulb on the right side, mine broke, well i dont have a bulb there
Horsepower sells cars, Torque wins races
2001 OB, in the works
AlexRawk is offline
post #89 of 641 (permalink) Old 11-06-2008, 12:07 PM
Is this a question for me? If you're talking about the first picture I show, the little bulb is a #74 bulb. It's in the key ring, ashtray, and shifter. That bulb is the one removed from the key ring. You may have to shave it in the keyring, and absolutely have to shave it in the ashtray and shifter.
I do want to comment that the #74 bulb I used does not have a wide angle. You may not get the brightness desired. The bulb is from superbrightleds.com
It's white and I got the look I intended to get.
XMan714 is offline
post #90 of 641 (permalink) Old 11-06-2008, 03:46 PM
lol sry i was reffering to the gauge cluster pic, but that is the bulb im talking about,
AlexRawk is offline
Current users viewing this Thread: 12 (0 members and 12 guests)
Tutorial - DIY Superstar LED bulbs in main gauge cluster Truthunter DIY/tutorial forum 99 11-10-2012 09:08 PM
Attempting LEDs in Gauge Cluster Truthunter Showroom 7 01-05-2006 05:36 PM
2001 Gauge Cluster Lights Dimming/Out! 4NTOY Showroom 0 04-07-2005 12:05 AM
Help gauge cluster lights went out djlunatiq Showroom 3 08-02-2004 10:48 PM
Gauge Cluster Lights Stoped Working Ace0246 Basic Help & Repair 1 05-18-2004 07:24 AM
