How-to: Change your Main Gauge Cluster & Ignition Ring lights (LEDs) *pics* - Lexus IS Forum
 18Likes
post #1 of 641 (permalink) Old 04-18-2008, 03:12 PM Thread Starter
When I was researching on how to do this mod, I found all the information I needed from 4-5 different threads. I've merged the threads and all the information and added my own comments/experience to make this DIY simpler. Here goes:
Parts Needed for the main Gauge Cluster:
You need three 4- Star SMT (11mm diameter x 19mm overall - these are the #194 leds)
194 168 W5W 2825 Map Led Parking Signal Marker Bulbs
You need two Tri-Power 3 LED Bulb (15mm x 8mm diameter - these are the #24 leds)
Autolumination Instrument Panel Light Bulbs & Lamps)
Part needed for the Ignition Ring:
You need one #24 led, it can be the 3 led or 5 led matrix.
(You might want to buy extra if you want to have a spare handy)
4/29/2008:
Part 2 is now up!
https://my.is/forums/f90/how-change-c...s-pics-360155/
PART 1: Removing the Main Cluster Gauge.
All pictures were taken from member redline814 from this thread:
https://my.is/forums/f114/how-remove-...lights-233511/
Remove the top 2 phillips head screws...
Remove the screw just below the lower tab (my toe is pointing at it). There are 2 tabs that you will need to pull out on the right side of the steering column.
There is one tab you will need to pull out on the left side of the steering column. Disconnect the connector for the dash dimmer switch.
This is what comes off...
Remove the 3 screws that hold in the gauge cluster.
Left side view...
Right side view...
At this point you can change your Ignition LED. Remove the upper right screw from ignition ring and it should come right out. Remove the bulb and put in your #24 LED.
Once it's working, screw the ignition ring back on. and continue with gauge disassembly.
Pull out the gauge cluster a few inches. Disconnect the 2 white connectors you see in this pic. They will be more toward the left side.
What the empty spot looks like...
What the gauge cluster looks like...
PART 2: Putting in your LEDs.
Twist off the #194 bulbs (the ones marked with a red circle). Remove the bulbs and put in your new 194 LED bulbs.
Twist off the #24 bulbs (the ones marked with a orange circle). Remove the bulbs and put in your new 24 LED bulbs.
PART 3: Testing the LEDs.
Now it's time to check if the polarity of the bulbs are correct, if the polarity isn't correct the bulbs will not light up.
Go back to your car and connect the 2 white connectors you see in this pic.
You'll also need to connect the dash dimmer switch.
Turn on your cluster gauge leds to see if all the bulbs light up. Check to see which bulbs didn't light up and reverse the polarity, (take out bulb and twist them in the opposite way).
Once all the bulbs are working, put everything back together.
This is what you should end up with:
I run the LEDS at about 80-85% brightness (pics above were taken at 100% intensity). I haven't heard of these LED bulbs burning out like the older "superstar" led bulbs. I'll be working on the climate controls next to complete the look.
Here are other clusters done by other members:
MAYO:
ALL INFORMATION POSTED HERE IS FOR EDUCATION ONLY. I ASSUME NO RESPONSIBILITY FOR WHOEVER MAY BURN DOWN THEIR CAR/HOUSE OR CAUSE IT TO NO LONGER WORK IN ANY OTHER WAY WHILE ATTEMPTING THIS MOD. I AM NOT LIABLE FOR ANY PERSONAL INJURIES THAT MAY OCCUR WHILE DOING THIS MOD
Itagucci likes this.
nyczzzjohn is offline
post #2 of 641 (permalink) Old 04-18-2008, 03:33 PM
I followed this for my conversion... excellent writeup. +rep
Signature goes here.
lextasy23 is offline
post #3 of 641 (permalink) Old 04-18-2008, 03:35 PM
Funny, I'm actually working on one for the heater controls and stock radio. I ebayed replacement units to test with... it's a complete pain in the ass finding leds.
post #4 of 641 (permalink) Old 04-18-2008, 09:40 PM
Nice writeup man , so wut color is the key ignition ring? white or blue? I was looking on the site you provided on the key ignition led and have no idea which one is for our key ignition can u show me correct one. thanks +rep
05 MSM E-shift w/ LSD
Back Alley Shoot.
azn4life is offline
post #5 of 641 (permalink) Old 04-18-2008, 09:45 PM Thread Starter
i went with all superwhite. the key ignition one is the same #24 for the gauge cluster. Just order 3 of each bulb (194 & 24) and you're set! The #24 bulb is this one:
post #6 of 641 (permalink) Old 04-18-2008, 09:45 PM
wow awesome write up if u guys do one for the middle consel il being doing this conversion
+rep
2jz love
drift300 is offline
post #7 of 641 (permalink) Old 04-19-2008, 11:28 AM
Nice write up! +rep when I recharge
Josh300 is offline
post #8 of 641 (permalink) Old 04-20-2008, 06:23 PM
can you take a picture of it at 100 percent brightness.
thanks for the writeup
HKS Hipermax II coilovers / HKS DraggerII / Kaminari Kit / VIS Invader 6 hood / Carbon Creations trunk lid / Seibon carbon grill / Alpine / Phoenix Gold / JL Audio / 19" FF7 / TRD spoiler.
marcsis3 is offline
post #9 of 641 (permalink) Old 04-20-2008, 06:27 PM
nice DIY +rep will be doing soon in a bright red i dont like the orange too much
Bottles Are For Babies... Real Men Get Blown ;)
02' AR IS300//E-Shift//K&N//TRD//SRT 2.75 Comming SOON!
TRD*Nemesis is offline
post #10 of 641 (permalink) Old 04-20-2008, 10:31 PM Thread Starter
all the pictures taken were at 100% brightness setting. They look a little brighter in person.
post #11 of 641 (permalink) Old 04-20-2008, 10:39 PM
usdm IS300's Avatar
usdm IS300 is offline
post #12 of 641 (permalink) Old 04-21-2008, 08:54 AM
I don't think the back cover of the gauge cluster needs to be removed to change out the bulbs. I was just able to twist out the bulbs and replaced then with the new ones. Makes it a lot faster to install.
SilverLex04 is offline
post #13 of 641 (permalink) Old 04-21-2008, 09:08 AM
I was just wondering that, they look accessible in the pics with the cover on. Can anyone verify this? And I assume the color you want to buy to replace stock is Amber - right?
2001 is300 is offline
post #14 of 641 (permalink) Old 04-21-2008, 09:10 AM
can u take pics of what your White Leds look like please
nice write up !
02 CW
[NLC MA#009][find me @ISFanatics]
nless_dream is offline
post #15 of 641 (permalink) Old 04-21-2008, 09:38 AM
that looks nice!
03 BO E Shift
* Tein* EDFC* Hotchkis* L-Tuned * ProLex Performance* B&M* TurboEast* NGK* HKS* R-Spec* Altezza* CarsonTuned* EMR/VIS* FIGs* Huper Optik* Junction Produce Fusa* Momo* Clifford* Pioneer* DLS* Stinger* Monster* Sony* Dynamat
mutantblack is offline
Tutorial - DIY Superstar LED bulbs in main gauge cluster Truthunter DIY/tutorial forum 99 11-10-2012 09:08 PM
Attempting LEDs in Gauge Cluster Truthunter Showroom 7 01-05-2006 05:36 PM
2001 Gauge Cluster Lights Dimming/Out! 4NTOY Showroom 0 04-07-2005 12:05 AM
Help gauge cluster lights went out djlunatiq Showroom 3 08-02-2004 10:48 PM
Gauge Cluster Lights Stoped Working Ace0246 Basic Help & Repair 1 05-18-2004 07:24 AM
