Do it yourself thread (DIY) - Page 2 - Lexus IS Forum
post #16 of 85 (permalink) Old 06-25-2006, 09:43 AM Thread Starter
Cone Killer
Bluetooh Mic sensitivity
Cheat code to change the bluetooh mic sensitivity. Some people have complained about not being able to hear you when using the handsfree kit.
first hold the "info" button (I did it for about 5 secs) then switch your parking light switch from off-to parking lights-repeatedly while still holding the info button....it takes about 5-6 cycles...an poof the NAV screen enter yet another Service menu. From there I navigated to a bluetooth menu where I was able to adjust the Microphone volume higher so that people can hear me better!
https://my.is/forums/showthread.php?t=265815
METEORO is offline
post #17 of 85 (permalink) Old 06-25-2006, 10:09 AM Thread Starter
Cone Killer
Fog Light Mod
Here is a DIY to replace the fog light bulbs. Pretty easy to do, good pics.
http://www.clublexus.com/forums/showthread.php?t=223728
METEORO is offline
post #18 of 85 (permalink) Old 07-15-2006, 04:52 PM
Brake Calipers Paint & Sticker DIY
With pics:
https://my.is/forums/showthread.php?p=4316924
cdeslandes is offline
post #19 of 85 (permalink) Old 08-19-2006, 05:13 PM
Anyone know how to change the lights under the side mirrors??
MikeyStugots is offline
post #20 of 85 (permalink) Old 08-20-2006, 10:12 PM
Hidden Configuration Screen
This also works:
Press the Info button, Tap the left side of the screen from top to bottome in quick succession for about 3-4 times until a white screen with green buttons pops up.
nemrut is offline
post #21 of 85 (permalink) Old 09-22-2006, 01:29 AM
IS-F-I-Found's Avatar
Rudy, is this what you were talking about? Works with no probs?
IS-F-I-Found is offline
post #22 of 85 (permalink) Old 09-22-2006, 09:57 AM Thread Starter
Cone Killer
Yes, just about to e-mail you to let you know I had posted it here a while back.
METEORO is offline
post #23 of 85 (permalink) Old 09-22-2006, 09:58 AM Thread Starter
Cone Killer
Detailed instructions.
1. START DIAGNOSTIC MODE
(a) There are 2 methods to start diagnostic mode. Start
the mode by using one of them.
(b) Method 1
(1) Start the engine.
(2) While pressing and holding the "INFO" switch,
operate the light control switch: OFF → Turn ON
→ Turn OFF → Turn ON → Turn OFF → Turn
ON → Turn OFF.
(3) The diagnostic mode starts and the "System
Check Mode" screen will be displayed. Service
inspection starts automatically and the result will
be displayed.
(c) Method 2
(2) Switch to the "Display Check" screen.
(3) From the display quality adjustment screen,
touch the corners of the screen in the following
order: upper left → lower left → upper left →
lower left → upper left → lower left.
(4) The diagnostic mode starts and the "System
be displayed.
2. FINISH DIAGNOSTIC MODE
(a) There are 2 methods to end diagnostic mode. Use
one of them.
(1) Turn the engine switch off.
(2) Press and hold the "DISP" switch for 3 seconds.
METEORO is offline
post #24 of 85 (permalink) Old 09-22-2006, 10:12 AM
First Look
and this step by step is for ??
IS 350 CW w/ blk interior- ML/Nav
8000k HID headlights and fogs
20" Sevas S-22-
Continental Contisports 245/30/20-F 285/25/20-R
Blitz front lip and grill
K&N Typhoon
Tanabe NF210
1st IS350 W/ AAC Halos
Custom KAW Exhaust
TEAM SOLO
mikeh555 is offline
post #25 of 85 (permalink) Old 09-22-2006, 11:41 AM
This is all for adjusting the bluetooth mic sensitivity, if people are complaining they're having trouble hearing you.
post #26 of 85 (permalink) Old 09-22-2006, 06:22 PM Thread Starter
Cone Killer
To get to the service menu in the nav screen. Amongst other things, here you can adjust the bluetooth mic sensitivity.
METEORO is offline
post #27 of 85 (permalink) Old 10-01-2006, 04:23 PM
Nav Desitination Hack in 2007??
I have a 2007 IS350 with the Navi + ML. The series of screen taps posted for the 2006 model does not seem to work in my car. Does anyone else with a 2007 with the same problem? is there a different sequence to get to override mode in the 07?
AJRDU is offline
post #28 of 85 (permalink) Old 10-02-2006, 12:42 AM
Are you trying to get the destination selection to work while you're moving or are you talking about adjusting the mic sensitivity for bluetooth?
post #29 of 85 (permalink) Old 10-02-2006, 03:50 AM
i'm trying to enter a destination while moving. the mic sensitivity trick works.
AJRDU is offline
post #30 of 85 (permalink) Old 10-02-2006, 10:33 AM
Hmmm... and you're certain you're following instructions?
Menu,
Volume,
tap top left, bottom left, top left, bottom left.
hold override until you hear a beep,
hit back button in the upper right corner???
