DIY walbro 255 fuel pump install with pics (alot) - Lexus IS Forum
 2Likes
post #1 of 36 (permalink) Old 03-30-2010, 12:04 AM Thread Starter
well i just wanna say thanks to wingzero's diy thread, when i first saw it though it was a tad bit vague and i was thinking someone whos never pulled a fuel pump out before probaly wouldnt find it as informative, so last night after pulling mine out i made a step by step process on how.
*warning*
it is recommended to run your car dry of gas before doing this diy. if you do not wish to do so then you run the risk of getting gasoline on your car, or other surfaces, which may lead to unexpected combustion. preform this diy at your own risk
first remove your backseats, pretty much good trick here is put your hands were you feel the metal clips (circled in red) and from there give a good tug and you will hear an audible pop
next step is to remove the lid holding above the fuel pump, its located behind drivers side and has 3x bolts there weird plastic screws, 10 or 12 mm
then proceed to take out the 8 screws on the metal peice holding the pump in place, after those go you should be able to lift the pump up but its stuck about an inch but because the fuel cable is still attached. to detach the fuel cable grab the yellowish green clip and put it all the way out.
once that clip is out "slowly" with twisty motion is best remove the cable, should pop right out and you may get some gasoline on you, i got few drips.
now move the fuel line out the way and slowly pull up, you will meet 2 points of resistance. 1. is the fuel level indicator 2. is a rubber hose clamped onto the pump, you cant see it in this picture but you will know when you see it. clamp is kinda tough, i used some pliers then shimmy'd it down. for the fuel level indicator once you get the hose off angle it so that the metal comes out
i chose to d/c the cable once i pulled it out, but you can at anytime really "its tricky though you gotta use alot of force to get that clip down"
heres a pic of the hose once i taken it out, you cant miss it though
once everything is d/c'd go head and pull it out
alrite here comes the tricky part. the fuel pump housing is a bitch. there are 4 clips holding the top lid as pointed out by the red arrows. you will probaly have to use a screwdriver and its gunnna require a bit of force but remeber its still plastic so dont go hulk on that thing. the bottom part pointed by the blue arrrows were easy, might have the move that lil hose thing but cake deal.
once the top's off d/c the connector on top and with a lil twisty motion pull the stock pump out, take a lil bit of force and you might get gas on ya. oncce you pull it out you will find a spacer, a o ring and a cap on the tip, you can see my cap in this pic, its tan. save those as you will be re using them on the walbro
at the bottom of your stock fuel pump youll see a lil metal ring thing with 3 prongs angled but pointing towards you. thats the fuel filter retaining clip, in my pic i already moved it to the walbro but you will probaly need a screwdriver to unclip it
*warning*
be very careful during the next step, if you plan on soldering, which you should, that fuel pump is going to have deposits of gasoline, you can throughly clean there but there will be spots were you cant see, and a solderer is very hot, take caution and if you can solder the connections in a different area of the house, maybe backyard, keep a bottle of water handy w/ wet cloth.
now here comes the dangerous part, soldering. you shouldve purchased the walbro with the installation kit, "fuel filter plus pig tails" your going to need to clip the connector from the pump housing group and solder it on with the one provided in the kit. its red = pos black = neg, i drew 2 lines just if you were confused, but just rember black on black. now i forgot to in this pic but its reccomended that you "stagger" the connections meaning clip them at 2 different points, just incase if the rubber tube or e tape come undone they dont touch each other and spark, which is bad.
and after all that, you may put it back together and back step from there. enjoy!
dooderek is offline
post #2 of 36 (permalink) Old 03-30-2010, 06:54 PM Thread Starter
instead of starting a new thread i just edited a one i made yesterday so bumpage incase anyone needed help on the pump replacement
dooderek is offline
post #3 of 36 (permalink) Old 03-30-2010, 07:31 PM
Quoted: 26 Post(s)
Should be noted not all Walbros have teh same input/output locations, I believe the GSS342 is the Walbro of choice for us.
A very helpful thread and supplement from Lambchop
BlackSportD is offline
post #4 of 36 (permalink) Old 03-31-2010, 03:56 PM
Nice write-up mayne. You get the f10x up and running yet?
NazTBoIs300 is offline
post #5 of 36 (permalink) Old 03-31-2010, 06:28 PM Thread Starter
The wiring is a bitch, its gettin put in right now
dooderek is offline
post #6 of 36 (permalink) Old 03-31-2010, 07:35 PM
cool man. always good to have pics and details for an install. im going to put mine in soon.
[CENTER]
03 MSM 5MT/LSD
WORKING TOWARDS LS1 POWER...
jdub_gsx is offline
post #7 of 36 (permalink) Old 03-31-2010, 08:11 PM
nice write up, will save me some time checking out the housing to figure it out
btlegacy is offline
post #8 of 36 (permalink) Old 03-31-2010, 08:28 PM
no hammer and screwdriver?
jk much better than your last write up keep it up
(add a fuel return)
02 IBP soon to be fed on a diet of corn juice and corvette
MX99204 is offline
post #9 of 36 (permalink) Old 03-31-2010, 08:37 PM
awesome write-up does this give any power without bigger injectors?
2003 Onyx Black IS300
SRT intake
Greddy Carbon Ti-C
Tein Basic coilovers
Chrome Lexus RX330 wheels
southernpridesd is offline
post #10 of 36 (permalink) Old 03-31-2010, 09:00 PM Thread Starter
No the pump does not add hp but it is a pre requisite for big injectors and big injectors is a pre req for bigger hp numbers. Haha I wouldn't call my turbo thread a write up =P
dooderek is offline
post #11 of 36 (permalink) Old 03-31-2010, 09:16 PM
This car still runs....?
For Sale:
GTE VVTi Swap | AEM V2 | PTE 6766 | Carson Tuned | UGO | Tein Flex
sean05 is offline
post #12 of 36 (permalink) Old 03-31-2010, 10:53 PM Thread Starter
very funny
dooderek is offline
post #13 of 36 (permalink) Old 07-09-2010, 02:44 PM
+rep! thanks for the tips, just did mine in between customers at the shop.
Sask_IS300 is offline
post #14 of 36 (permalink) Old 07-10-2010, 11:17 AM
I've installed 2 pumps in the tank (using alum pump hanger) one year ago.
I this year i change my setup w/ fuel collector tank (installed in the trunk) with same 2 walbros inside and leave std pump in the main tank.
My results:
1. Now I see that this is most reliable way to have more fuel w/o air because the pumps always have clean fuel (collector tank always full, fuel filtered by std pump filter in the main tank).
2. The SARD 5L fuel collector tank cost little bit more than PHR or SRT pump hanger, you need only one bulkhead fitting in the main tank for return line and little bit more 6AN hose to route lines to the trunk. You can use some noname fuel collector tank (copy of sard) it's cost about $200
SARD 5L
Noname (as old SARD model)
p.s.: sorry for my english
Lexus GS300 '98 w/ 2JZ-GET - 616 Hp / 750 Nm on pump gas
qphoton is offline
post #15 of 36 (permalink) Old 07-11-2010, 12:51 AM
Quoted: 167 Post(s)
thumbs up /applause
Great example of a DIY write-up!
whatthe is offline
fuel pressure regulator or fuel pump problem is300tt Go Faster 2 05-04-2007 10:33 AM
