DIY: Removing the dash, center console, and painting them *tons of pics* - Lexus IS Forum
 3Likes
post #1 of 107 (permalink) Old 10-17-2011, 08:05 PM Thread Starter
Preparation.
First off yes, there are plenty of other threads already made on this topic as well. But, almost every thread I come across has come up with broken images. So for the sake of clarity, I've decided to compile what I found and incorporate some tips along the way
Here is what I used:
Paint thinner
2-3 cans of flat black paint (must be able to bond to PLASTIC)
Sponge (2 sided)
Philip head screw driver
Ratchet (I used 3/8 drive) and extensions
14mm socket, 12mm socket, 10mm socket
Something to label your nuts n bolts, etc (so you don't lose any, or use the wrong ones when assembling everything back together)
Matt K likes this.
madchyers is offline
post #2 of 107 (permalink) Old 10-17-2011, 08:05 PM Thread Starter
Removing the dash.
Originally Posted by chris_hill
Edited by MY2J with some of my .02 cents
*DONT ASSUME THESE STEPS ARE 100% ACCURATE*
USE COMMON SENSE WHEN WORKING ON YOUR CAR!
DONT BLAME ME IF YOU BREAK SOME SHIT
Easier done if the seats are removed/set all the way back...
Usually only takes about 1-2 hours, assuming you are good at stripping cars.
#1 Disconnect Battery, Do Not perform work until 5 mins pass.
If you let the car sit without power for 5 mins you lessen the chance popping your airbag. Once the airbag is disconnected your safe, as long as you aren't jacking with it!
You will not need to disconnect the drivers side airbag.
#2 Remove Glove Box by removing the two plastic pins at the hinge and the 10mm/phillips head bolt.
#3 Remove Glove box hook bracket by removing the two phillips head screws, and the 10mm bolt.
#4 Using a pair of needle nose pliers, squeeze the airbag wire retaining clip out of the glove box hook bracket.
#5 Now that the harness is free, unplug it by pulling back the white tab on the plug. Now you are pretty safe from deploying your airbag.
#6 Disconnect the glove box light switch. Shown in step #3
#7 Remove the clip that holds the wire loom in place by wiggleing it back and forth with pulling.
#8 Now the wire loom should be free.
#9 Remove the nuts (2 10mm) and bolts (2 12mm) that hold the airbag in place.
#10 Remove the black passenger door sill panel.
#11 Remove the black plastic push nut from the passenger kickpanel.
#12 Remove the kickpanel by pulling towards you. Then remove the 10mm bolt that is revealed.
#13 Remove the cloth dash tray panel by prying the front of cloth covered panel with a pick or small screwdriver. Use a folded paper towel to protect the plastic.
#14 Remove the two phillips head/10mm screws that are revealed.
#15 Remove the dash tray by pulling straight out, it will take some force.
#16 Remove the 10mm nut, the 10mm bolt, and the top 2 10mm bolts that hold the AC/Radio bracket in.
#17 Remove the trim panel that holds the 'trac' switch buy applying pressure the the underneath side, and pulling straigt out.
#18 Remove the two 10mm bolts that are revealed.
#19 Now remove radio/ac unplugging the wires before you pull to far.
#20 Remove the 10mm bolt thats revealed.
#21 Remove the leather e-brake boot by first setting the e-brake, then pulling up the boot (pinch the leather on both sides of the e-brake).
#22a Start to remove the center console by removing the 2 phillips head screws on both sides of the console, the two in the pocket behind the e-brake.
#22b If you have an 02+ then there are 2 more 14mm bolts holding the center console underneath the 2 caps on either side behind the armrest. Once the bolts are out you can lift the armrest off and pull the center console out.
#23 Now Remove the trim panel that holds the cig lighter, and ashtray by prying up around the chrome ring that's around the shifter. Once loose use your hands to pull up the rest of the panel. Unplug the cig lighter, cig lighter light, and ashtray light.
#24 Now remove the two phillips head screws that are revealed.
#25 Remove the center console by pulling straight back. Once loose lift it out of place.
#26 Remove the phillips head screw that is revealed.
#27 remove the access panel thats under the steering column by removing the 3 phillips head screws that hold it in place. Unplug the temp sensor and hose, remove diag plug, and remove hood cable.
#28 Remove the bottom portion of the steering column trim by removing the three phillips head screws. One is on the bottom of the trim panel. The other two will require turning the steering wheel right or left. Once screws are removed, gently pull the bottom off.
#29 Remove the 4 14mm nuts that hold the steering column in place. Let the column drop and rest on the metal cross brace below the column. The upper two are easy to spot, the rear two are harder to get to, and will require that you push the tilt spring out of the way with your socket.
#30 Remove guage cluster trim by removing the 2 phillips head screws. Then pulling out slightly until free. Unplug dimmer wire.
#31 Remove the 3 phillips head screws that hold the guage cluster in.
#32 Remove cluster, unplug the 2 harnesses. Once removed, remove the 10mm nut that is revealed.
#33 Unplug the light sensor harness.
#34 Remove driver side black door sill trim.
#35 Remove black plastic push nut from drivers side kick panel.
#36 Remove drivers side kick panel by pulling towards you, then remove the 10mm bolt that is revealed.
#37 Pull the rubber seal away from the car on both the passenger and drivers side.
#38a Remove both the passenger and driver side pillar trim.
#38b If you have an 02+ then there will be air bags in the side pillars. Remove them by lifting the tabs and using a 10mm socket to loosen the pillar trim from the pillar.
#39 The dash is now ready to be removed. From the center pull with slight force. the dash will unclip and be loose. Make sure you have the dash completely loose.
#40 Once you are sure it's loose lean it forward a bit, then lift it over the steering wheel, and out the passenger side of the car.
side notes:
After #40, I found that it was easiest to pull the dash out buy starting from the passenger side first, then middle, then driverside. The clips holding the dash secure are all located right under the windshield. And also, pull the steering column off of the studs completely, it will make it easier to pull the dash out with minimal problems. Leave the column detached from the studs for when you put the dash back in as well.
Before putting the dash back in, I'd recommend covering the steering wheel with a towel, because it gets kind of tricky putting the dash back in without scratching the steering wheel. Also, wait until the paint is COMPLETELY dry, I'd recommend waiting over night to be sure so that it doesn't scuff when putting it back in the car, maybe even tape the edges with painters tape/masking tape so that when it rubs on the windshield or pillars it doesn't scuff either.
post #3 of 107 (permalink) Old 10-17-2011, 08:06 PM Thread Starter
Painting - Befores and afters.
Once you get here, you're ready to paint your scuffed up/melted dash
Set up a nice place to paint with some fresh air, for your safety
On the areas where there are alot of scratches and scuffs, you can use the paint thinner to remove the layers of scratches down to the plastic/primer. By doing this, it's like sanding the layers so that once the new paint applied dries, you won't be able to see the scratches underneath, making it nice and smooth. If you really have time, you should apply the paint thinner to the entire dash to ensure that everything comes out smooth. I used the soft part of the sponge to apply the paint thinner, and then the rougher part to help pull the paint off quicker. Once you're satisfied with the parts you've touched up, rinse off your sponge, and get a bucket of soapy water. Apply the soapy water sponge to your dash, center console, glovebox, and anything else you want to paint. You want a nice clean surface to paint over, any dirt or dust that gets painted over will show up when the paint dries.
Before (notice the layers of paint, this area of the dash was where I had the most noticeable scratches and scuffs)
After (putting the radio/AC back in was kind of difficult to put in without getting minor scuffs, for future reference, I'd tape them up while installing them back in, as well as the center console. I will be touching this area up soon)
blackmenace likes this.
post #4 of 107 (permalink) Old 10-17-2011, 09:07 PM
I don't want to paint my dash but this helps other interior needs. Thanks!
DontStopMe is offline
post #5 of 107 (permalink) Old 10-17-2011, 09:14 PM
Quoted: 9 Post(s)
Dang. That's awesome! +rep!
My pix whoring thread
Johnnysks is offline
post #6 of 107 (permalink) Old 10-17-2011, 09:19 PM Thread Starter
you're welcome guys. I had wanted to paint this dash for years, but could never find a clear thread that helped. Like I said, all the pictures and links were broken, so when I finally found all the info from years ago to present, I decided to tackle it! I know this is probably the #1 problem that people want to fix with their IS's, so I was determined to compile all the steps into one easy to read thread
post #7 of 107 (permalink) Old 10-17-2011, 09:25 PM
Nice! Chad, you've been quite busy. Excellent DIY and glad to see informational steps with pics! Edit: says I must spread repz before giving again.
post #8 of 107 (permalink) Old 10-17-2011, 09:35 PM Thread Starter
Thanks Jason! I figure I may as well do all the work I never had time to do while the new motor is being put together.
post #9 of 107 (permalink) Old 10-18-2011, 12:09 PM
Good thread like always man. I did this to mine at the end of the summer but some of the areas came out a little rough. Plus I think the airbag panel on mine wasn't fixable. Great DIY thread though, +rep
edit: must spread more rep first, lame.
wocoISguy is offline
post #10 of 107 (permalink) Old 10-18-2011, 12:41 PM
Awesome write up! I didn't read through carefully so if I missed something forgive me, but the smooth parts of your dash were yellow before?
Facebook: "IS's of Alabama"
- 6 Speed Sport e90 BMW 335i; MTech package & e85 COBB tuned (Current)
- 2004 IS300 Black Onyx 5 Speed w/LSD; Pioneer, AEM, R-Dash, 2013 ISX50 5 spoke wheels (Owned from November 2010-2013)
- 2002 IS300 Black Onyx 5 Speed w/LSD Stock (Owned from 2009-2010)
- 2001 IS300 Black Onyx Stock (Owned in 2007)
202IS is offline
post #11 of 107 (permalink) Old 10-18-2011, 02:04 PM Thread Starter
Yeah dude, same here, small nicks that I could have prevented, but I'm gonna be touching them up. Thanks for the feedback
Thanks for the comment The yellow dash isn't mine. I nabbed those pics from another write up that took me a while to dig up from the boards. Most of the credit goes to chris_hill and MY2J. I just re-saved the pictures to my photobucket that way I know that if someone is looking at this DIY in a couple years, the pics will still be up, since most of the threads you look at on this topic will have broken links for the pics.
post #12 of 107 (permalink) Old 10-18-2011, 02:21 PM
When I painted my dash, I removed the steering wheel for additional clearance. It really helped when re installing the dash.
CorrPerformance Tuning
02 MSM 5MT/LSD...SOLD
03 GGP Auto/SportDesign...SOLD
01 MSM Auto/LSD...SOLD
el-guapin is offline
post #13 of 107 (permalink) Old 10-18-2011, 03:02 PM
S*A*G*E
Chaco's Avatar
Excellent write up Chad, +reep for you kind sir
Chaco is offline
post #14 of 107 (permalink) Old 10-18-2011, 04:08 PM Thread Starter
Good call! I should have done that.
Thanks guy, wanna talk about it over some wine coolers
post #15 of 107 (permalink) Old 10-18-2011, 05:07 PM
S*A*G*E
Chaco's Avatar
ill bring a movie
Chaco is offline
Guide to removing center console aquafish Showroom 22 10-10-2016 04:56 PM
removing the center console JapbOii Showroom 2 12-07-2009 02:45 PM
Painting Dash and Maybe a Center Console APMonkey Showroom 11 01-08-2009 04:12 PM
Help removing center console with NAV chado Showroom 3 07-13-2008 12:37 PM
Help removing center console, i'm stuck steelerfan Mobiletronics 14 05-04-2006 02:37 PM
