DIY: LS400 Caliper Install - Page 3 - Lexus IS Forum
post #31 of 53 (permalink) Old 03-01-2011, 06:51 PM
Nice write up. Usually how much could you get the LS calipers for?
01 MSM Turbo IS300--RIP
95 BO SC300 5spd - Current Project
N.E.L.O.C
****North East Lexus Owners Club****
http://www.clublexus.com/forums/neloc-175/
tjmhillz is offline
post #32 of 53 (permalink) Old 03-01-2011, 10:34 PM
Quoted: 27 Post(s)
I got mine for $275 shipped off of clublexus. They pop up there and on Supraforums occasionally.
I didn't take pictures during my install, but I posted some potenially helpful info in this thread:
https://my.is/forums/f174/ls400-calipers-install-414942/
Mainly part numbers for the rebuild kits. I decided to go ahead and replace all the seals since I took the calipers apart to powder coat (front and rear). They were something like $50 for the front and $60 for the rear if I remember right (from Lexus).
It might be a good idea to rebuild them while they are off the car. It doesn't take too much time and I felt a lot better knowing that everything was basically "new" rather than 15 years old.
white_is is offline
post #33 of 53 (permalink) Old 05-09-2011, 03:36 AM
Thats nice.. how much of an improvement did it make? I find my OEM brakes to be very good but after my motor build I am going to go with a BBK
1stGenIS is offline
post #34 of 53 (permalink) Old 05-09-2011, 12:02 PM Thread Starter
yeah...and theres a pair for sale on zilvia at the moment for a SUPER good deal if anyone wants to check em out.
they stop really good...its def a lot more brake than stock for quite a reasonable price
+ 2JZ-GTE IS300 +
stirlingw is offline
post #35 of 53 (permalink) Old 01-19-2012, 07:33 AM
maybe a stupid question, but why the lower ball joint spacer? is it so the rotor will clear?
cashed350 is offline
post #36 of 53 (permalink) Old 01-19-2012, 09:23 AM
The LS calipers won't have enough clearance and the bolt holes won't line up without the spacer. Though I still had to sand down my left caliper a little so it would fit.
'03 IS300 Turbo
SportDesign | 5MT | LSD | Black Onyx
Velocity211 is offline
post #37 of 53 (permalink) Old 01-22-2012, 07:59 PM
Quoted: 27 Post(s)
The lower ball joint spacer is used because the bottom side of the LS calipers hits the stud of the outer tie rod.
The caliper adapters are used to get the bolt holes to line up.
With those "two" parts mine bolted up 100% no modifications to the calipers.
white_is is offline
post #38 of 53 (permalink) Old 03-01-2012, 08:40 AM
Quoted: 7 Post(s)
Im pumped to do this, I just bought a set of LS400 Calipers for $120 picked up!! They are off of a 96 LS400 so they should work. I also read some where that there are 2 different size front rotors for the 95-00 LS400 is this true?
Im your local smarta$$
leonard_is300 is offline
post #39 of 53 (permalink) Old 03-14-2012, 12:03 AM
Oh geez I need to PM Figs and get these babies back already ahahaha.
Moderator Old School.
DonCorleone is offline
post #40 of 53 (permalink) Old 06-22-2012, 06:05 PM
Quoted: 26 Post(s)
Figured I'd contribute to this thread a little bit after having searched and read a lot on here, but first wanted to thank the OP for an awsome write up
I came up with a list of pros and cons comparing OEM vs. Supra TT vs. LS400
PROS:
-These calipers are MUCH easier to track down & get hold of vs. supra calipers(literally tried searching for months for supra calipers and every set on here fell through for one reason or another and remanufactured ones from autoparts stores all have an infinite national backorder)
-Calipers are about 3-4lbs lighter than supra calipers and about 7 lbs lighter than OEM caliper w/ bracket
-Rotors are about 1/2 lb lighter than supra(blank vs. blank) but about 1.5lbs heavier than OEM (again comparing only blank vs. blank) all due differences in rotor size....Supras are the biggest @ 325mm, LS400's are slightly smaller @ 315mm and OEM is 295mm
-Either upgrade works with stock or aftermarket stainless lines
-Rotor selection is all the same(various companies make plenty of blank, slotted, or drilled & slotted rotors for all 3 brakes)
-Either caliper upgrade is a huge cosmetic improvement over OEM
CONS:
-Pad selection is narrower than supra or OEM front capliers but not by much, EBC makes their green and red compounds, but not yellow, hawk makes HPS but nothing beyond that, carbotech seems to make every compound
-Rotors are slightly smaller than supra and don't fill up the wheel as nicely
now as far as cost here's how I did it:
-Remanufactured calipers from autozone 216 out the door(70 is part of core refund so after I take the OEM calipers back it'll only be around 145)
-Autozone front rotors 102 out the door(2 year warranty against warping/other defects)
-Orielly's rear rotors 78 out the door(2 year warranty against warping/other defects)
-Figs retrofit kit 250 shipped
-RBC redstuff pads front & rear & technafit stainless lines 270 shipped from THM(though I'd avoid them, their shipping is a PITA and customer service is about zero)
-1 bottle of ATE super blue 21 shipped(ebay)
-1 set of decals 12 shipped(ebay)
grand total for all 4 corners of pads/lines being upgraded over OEM and converting to LS calipers/discs is about 950 and after core refund will be down to around 880, not bad for a huge brake performance upgrade as well as a noticeable cosmetic upgrade
broketuner is offline
post #41 of 53 (permalink) Old 06-22-2012, 06:19 PM
Jerm__ is offline
post #42 of 53 (permalink) Old 06-30-2012, 07:32 PM
I spent under $500 doing the Supra TT Swap. I thought about the LS400 upgrade but it ran a little more than i liked.
Nyke is offline
post #43 of 53 (permalink) Old 06-30-2012, 08:14 PM
I'll probably do the supra TT upgrade rather than the LS400
Jerm__ is offline
post #44 of 53 (permalink) Old 07-01-2012, 01:49 AM
Quoted: 7 Post(s)
I have the LS400 brake setup and I love them! They feel the same as the TT setup but they offer a light weight caliper and they give a little more clearance for wheels. With my wheels and the TT caliper setup I couldnt fit a piece of paper between the wheel spoke and caliper it was that close. Now with the LS400 setup I have about a 1/4" gap between the wheel spoke and caliper.
post #45 of 53 (permalink) Old 08-25-2012, 02:30 PM
ive read thru the forum but will this work for stock wheels? i read someone was going to check but didnt see nothing after
02gita is offline
LS400 calipers install ultra kirill FIGS Engineering 106 12-21-2013 06:16 PM
HELP with Supra TT caliper install... mosmmc Stop, Drop and Roll 16 12-03-2009 08:52 AM
For those with LS400 caliper retrofits DonCorleone Stop, Drop and Roll 60 04-08-2009 10:12 PM
supra caliper pad install ( install trouble 08/19/06 ) DAWGTUFF Stop, Drop and Roll 29 09-01-2006 05:53 PM
