---DIY---INTAKE and more Intake info - Page 5 - Lexus IS Forum
 2Likes
post #61 of 84 (permalink) Old 05-13-2011, 08:12 PM Thread Starter
Bezik777's Avatar
Quoted: 44 Post(s)
Bump for the new members....
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #62 of 84 (permalink) Old 06-20-2011, 02:03 PM
Short Ram Install Issue
I grabbed on of the junker pipes from ebay and slapped it on, cars running like shit. From what Ive read, it could be an issue with the MAF and the diameter of the intake pipe. Im going to clear the ecu and give her another shot, check for vac leaks and then hope its fixed. Any input?
paulturner911 is offline
post #63 of 84 (permalink) Old 07-02-2011, 03:02 PM Thread Starter
Bezik777's Avatar
Quoted: 44 Post(s)
Anything more then 3.25in tubing will cause problems ...clean MAF , check all hoses , check all sensor plugs, reset ecu...
throwing cel??
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #64 of 84 (permalink) Old 07-02-2011, 07:27 PM
CEL for secondary O2 sensor bc I have no cats. I cleaned the MAF with MAF cleaner...all though it says it prob shouldnt be used on lexus sensors. But I figured I have two so ill try it anyways. Checked all sensor plugs and vac lines to another IS3 and im square. I did notice two different part number for the MAF sensors, mine are both the same but my gf has a different one. I tried to run a 3in pipe today again with two different MAF Sensors, cleared the ECU, still crap. So I just cut the charge pipe the PO was using and have been running that with the ebay filter on it untill I get a Blox filter.
post #65 of 84 (permalink) Old 07-13-2011, 10:54 AM
Going to have to track down an SRT Intake! Thanks for this.
2004 Sportdesign Thundercloud IS300
5spd manual w/navi
yakk00 is offline
post #66 of 84 (permalink) Old 07-22-2011, 04:39 PM Thread Starter
Bezik777's Avatar
Quoted: 44 Post(s)
Buy used , even then they are over priced......
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #67 of 84 (permalink) Old 08-23-2011, 02:31 PM
great job on the write up! i just bought my first IS300 last week ...needless to say i was looking for a quick and easy method to ditch that stock air intake. thanks again!
Mr.Bluth is offline
post #68 of 84 (permalink) Old 08-23-2011, 02:35 PM Thread Starter
Bezik777's Avatar
Quoted: 44 Post(s)
Thxs
What are you looking to get / do ??
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #69 of 84 (permalink) Old 08-23-2011, 02:48 PM
Originally Posted by Bezik777 View Post
Thxs
i saw your post over the weekend and wanted to go with the joe-z intake. so i took a quick drive down to carson toyota this morning (any excuse to go for a cruise, right? haha) and also got a afe power air filter. just dropped both of them in and took a test drive...very nice!
Mr.Bluth is offline
post #70 of 84 (permalink) Old 08-23-2011, 03:11 PM Thread Starter
Bezik777's Avatar
Quoted: 44 Post(s)
Good stuff ....glad you like the set up
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #71 of 84 (permalink) Old 11-08-2011, 06:10 AM Thread Starter
Bezik777's Avatar
Quoted: 44 Post(s)
Bump up !!!
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #72 of 84 (permalink) Old 11-09-2011, 12:26 PM
From what ive gathered.... back in the "day" LMS had a long true CAI for the IS300
if i recall correctly team Lexus had it on their racecar as well
also AEM makes a extension piece for their setups to mate up to the AEM SRI for the IS....
My version incorporates some piping i had laying around from my 240SX, and a OBX-r IS300 intake (pretty much the longer kin to Joe-Z pipe, with a maf adapter already welded)
its pretty straight forward including cutting the fender well opening...ALL PIPING IS 3 INCH
I cut my hole with a dremel cutting bit, and further smoothed the edges with a sanding drum...
the only thing that i have noticed that sets this apart from the LMS design is that it sits lower and my bends are more smooth. I run an Apex-i cone filter so its shorter than most filters and it sits about 2 inches away from the opening next to the foglight
the homework has been done here on my IS to acheive the best power for NA intakes and i beleive the happy medium was somewhere between 5-6ft total length from the intake valve to the filter, mine measures in at about a lil over 6ft...
with just the SRI the car felt about normal just way loud, with the longer setup its hard to tell because i did this the same time i did my header, so my outcome is skewed, spunky yes, low end well i toss that to the long runners moving my power band around, noise? not nearly as loud but it does sound pretty mean near the bumper.....
-01 MSM IS300 & 05 Mazda3-
taba is offline
post #73 of 84 (permalink) Old 11-09-2011, 03:24 PM Thread Starter
Bezik777's Avatar
Quoted: 44 Post(s)
^^^ great info thanks for posting , I've owned the LMS intake and with emu tuned awesome set up .
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #74 of 84 (permalink) Old 04-09-2012, 06:30 AM Thread Starter
Bezik777's Avatar
Quoted: 44 Post(s)
Bump for the new members ....any questions
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #75 of 84 (permalink) Old 10-13-2012, 05:30 AM
just ordered my srt, im still a bit confused on connecting the r/ecu. I drive an 03.
julianxp is offline
IS300 DIY: TU Intake Snorkel Mod (Proven, Cheap, Intake Modification) smallboostingIS DIY/tutorial forum 57 11-11-2017 07:57 PM
Dyno Tested: K&N Typhoon Intake vs Stock Airbox vs DIY Intake Mod Supraman16 IS-F 15 01-15-2013 03:04 PM
DIY: How To Paint Your Intake ins0mnia DIY/tutorial forum 17 05-12-2008 06:41 PM
intake DIY?? o.O aznbboyt3k Go Fast Stuff 6 03-30-2005 11:24 PM
Found another DIY intake mod. YellowIS5spd Go Fast Stuff 5 02-02-2003 10:34 AM
