DIY: Dark Chrome-ish or painting fog lights - Lexus IS Forum
post #1 of 33 (permalink) Old 09-13-2012, 08:10 PM Thread Starter
I see there is a DIY for the headlights but not for the fogs, so I thought "why not"
Tools:
1) Oven, oven mitt
2) Screwdriver (flat-nose and phillips)
3) Spray paint of choice. I used VHT Niteshade.
4) primer if necessary, I didn't use any cause I tried to get that Dark Chrome look
5) sand paper: 220, 1000, 2000 grit. could go lower and/or higher if you want.
6) Meguiars Plast-X
7) Clear silicone
8) optional: clear vinyl with need hairdryer and some invisible glass or water/alcohol mix and a spreader.
Step 1: Get your fogs lights out. Unclip the wiring harness by taking off the wheels, putting the car on jack stands and pulling back the fender liner, detaching the wiring harness then taking off the 2 bolts hold on the fogs. I undid them from the front of the car through the small slit between the fog light and the lower grill/mesh.
Step 2: take them apart by taking off the rear caps, and getting the bulbs out.
Step 3: preheat the oven to 350*F. put them in there for 5 minutes.
Step 4: once they're out but still hot, take the flat nose screw driver and pry up the tabs and then pull them apart using two gloves or something to protect your hands from getting burnt; I used a towel hah
Step 5: Clean up the silicone from the lens by pushing it back into the plastic valley. This will make it easiest to put some more silicone when you're putting them back together.
Step 6 (OPTIONAL STEP): You can do this or choose not to but I didn't want the projector lense to be yellow so I wet-sanded them with said sand paper. you need to unscrew 2 screws with a phillips screw driver. Obviously you work your way up from the lowest grit to the highest grit. It takes a LONG-ass time. I was going at it for like 15 minutes till I started to see the yellow disappear haha You ONLY NEED TO SAND DOWN THE FLAT SPOT OF THE LENS, THAT IS THE ONLY PART THAT IS COLOURED!
Step 7: Spray the housing, you'll have to take it out of the plastic lens. I didn't put any primer because obviously all I wanted to do was darken the OEM chrome housing. I put too many coats, I think I did 5. 3 should be enough.
Step 8: Put the glass lens back in the fog light and the housing in the plastic lens part. Preheat the oven to 350F again and put the 2 parts of the fogs separately in. You just want to make the OEM silicone soft.
Step 9: Take out the 2 pieces of each fog light, apply a small line of clear silicone along the edge of the black part of the fog lights and press the two pieces of the fogs lights together. You may want to use clamps. Make sure that the tabs on the fogs are back to where they should be.
Step 10: now that you have painted the fogs, you most likely need to clean up the lenses. Wet sand them with 1000 and 2000 grit sand paper.
Step 11: after the 2000 grit sand paper you may want to use the PlastX to clean them up a little more. I used by Porter Cable 7424XP Dual action polisher.
Step 12: next step is to apply the vinyl. Cut a small piece, just enough to cover the fogs. I spray the fogs with invisible glass to make applying the vinyl easier. Work your way from the center to the edges of the fogs. This was my first time doing this so I had to re-do it a couple times. You can use the hairdryer to stretch the vinyl and to get rid of some small air bubbles. Air bubbles may occur although they usually go away after sitting for a few hours. Cut the excess vinyl with a SHARP razor blade.
Step 13: re-install them once they're dry
Thanks for reading!
Jerm__ is offline
post #2 of 33 (permalink) Old 09-13-2012, 08:12 PM
Quoted: 25 Post(s)
so happy you put your fogs back on great job!
JDM TRD NEO WIDEBODY
ToMs2jz is offline
post #3 of 33 (permalink) Old 09-13-2012, 08:18 PM Thread Starter
^Thanks Tom, but I never had any to begin with haha
Jerm__ is offline
post #4 of 33 (permalink) Old 09-13-2012, 09:30 PM
nice!!! I'm still debating if i want to sand down the yellow lens... although i still like the yellow lighting
how well does that vinyl stuff work/ hold up?? sounds like a great idea for my fogs and new headlights. is that the same stuff that a tint shop would use
Bhotchkiss is offline
post #5 of 33 (permalink) Old 09-13-2012, 09:32 PM Thread Starter
It holds up VERY good. Love it. I have it on my hood, bumper, mirrors, fogs, headlights
I got mine here Paint Protection Film | Page 1 of 1
Jerm__ is offline
post #6 of 33 (permalink) Old 09-13-2012, 09:37 PM
thanks jerm! you're just the go-to guy for everything lately
post #7 of 33 (permalink) Old 09-13-2012, 09:47 PM Thread Starter
^hahahahahaha is that a joke? I haven't done much lately
But thanks man!
Jerm__ is offline
post #8 of 33 (permalink) Old 09-13-2012, 10:17 PM
Quoted: 582 Post(s)
I think they came out looking great. IMO, don't tint the head lights, but do the same exact thing by opening them and VHTing the insides.
post #9 of 33 (permalink) Old 09-14-2012, 07:41 AM
you should have made a DIY for venture shield install i want it on my front end now when i get it back from paint! i see the front bumper being verry difficult
post #10 of 33 (permalink) Old 09-14-2012, 07:51 AM Thread Starter
^Ya, it's not the easiest thing to apply. I got it done by a professional!
Chris, I'm not sure yet, I think I may just tint it though ha
Jerm__ is offline
post #11 of 33 (permalink) Old 09-14-2012, 10:52 AM
Formerly known as 01WaIS
BNort2310's Avatar
This. Car is looking good as always Jeremy!
-Nick Norton-
RIP Brandon Robert Norton - 11/14/09
RIP Nicholas Vincenzo DeSimone - 8/20/07
2001 MSM Turbo - 304 rwhp | SRT 2.75 | Re-build v.2 in progress
2015 IS350 F-Sport - Obsidian Black
_____ My Build Thread :) _____
BNort2310 is offline
post #12 of 33 (permalink) Old 09-14-2012, 11:45 AM Thread Starter
Jerm__ is offline
post #13 of 33 (permalink) Old 09-24-2012, 07:55 PM
Quoted: 22 Post(s)
This is just the DIY threads i was looking for. Thanks for the great step by step w/pics.
'01 SY IS300 NA-T (Under Construction)
McLex01 is offline
post #14 of 33 (permalink) Old 09-24-2012, 08:17 PM Thread Starter
Jerm__ is offline
post #15 of 33 (permalink) Old 09-24-2012, 10:24 PM
Don't use silicone, again DO NOT USE SILICONE!!! Silicone gets hard over time and pulls away, silicone and butyl don't mix together, don't bond together and just flat out don't work together.
D
Did someone say headlights? Yes we do them and do them well!!!
GET IN ON THE PRE-BUY FOR THE SS DOOR SILLS, LOCATED IN THE TUNEDPARTS VENDOR AREA.
LIKE US ON FACEBOOK and A CHANCE FOR DISCOUNTS AND UPDATES.
http://www.facebook.com/pages/Tunedp...32141386810153
https://my.is/forums/f217/headlight-g...9/#post6376119
Lowest prices on ///TECK KITS///MAF FLANGES///
Tunedparts vendor section for details.
is300soon is offline
US chrome, dark chrome, SD tail lights and head lights Johnnysks Showroom 5 10-26-2013 11:06 AM
DIY: Dark Chrome Emblem Painting lilboi DIY/tutorial forum 158 09-17-2010 03:52 PM
FT: 04 IS300 OEM Chrome for JDM Dark Chrome head and tail lights bustin Canada 3 03-18-2010 01:35 PM
got my dark chrome tail lights volkaltezza Showroom 17 07-05-2008 09:51 PM
