DIY: Complete Timing Belt+Water Pump+ Seals - Page 3 - Lexus IS Forum
 10Likes
post #31 of 40 (permalink) Old 03-25-2016, 09:48 AM Thread Starter
mm71522's Avatar
Quoted: 353 Post(s)
Turn it very carefully. Wear thick gloves or with a rag bc the gears are pretty sharp. Be very cautious and patient bc they're hard to turn at first, but once its turns it'll want to go fast. If its the vvti gear, it has free play, so turn it until you feel resistance and then turn it enough till you can get it on point.
Mike
'02 AR IS300; M98 L-Tuned
TOKICO HP/TANABE NF210
ENKEI KOJIN 18X8.5+35/9.5+30
DIY: Nav+Aftermarket HU
DIY: Timing Belt
My Thread
mm71522 is offline
post #32 of 40 (permalink) Old 03-27-2016, 11:01 PM
Quoted: 10 Post(s)
Just curious do u have a picture of the 10 mm golden plate u are talking about and does it go a certain way? Also is this plate what the crank position sensor uses as a reference? Thanks
aformerclarityam is offline
post #33 of 40 (permalink) Old 03-29-2016, 08:08 AM
Quoted: 34 Post(s)
go to post #7 and #8
Help, please -- messed up timing belt job - Club Lexus Forums
I believe this is the plate that the OP was referring to. as for the orientation. take note of how it is positioned before removing and then put it back on the same way.
but as for needing to remove this plate before the timing gear - that is exactly what the user in the clublexus didnt do - he left the plate on when pulling the timing gear.
chunktwo is offline
post #34 of 40 (permalink) Old 03-29-2016, 08:09 AM
Quoted: 34 Post(s)
accidental double post.
chunktwo is offline
post #35 of 40 (permalink) Old 03-29-2016, 08:49 AM Thread Starter
mm71522's Avatar
Quoted: 353 Post(s)
Good reference To add to this, there's an indentation where the plate goes that keeps it from rotating up or down. It should fall in between there when putting it back on. There's no way to screw this up unless you really have no clue what you're doing.
The plate is there to keep the gear/sprocket from coming outwards. The crank position sensor reads the teeth on the gear/sprocket. If any teeth are missing on your gear/sprocket, replace it before proceeding or you'll have to do this job all over again to replace it when your car won't turn on or misfire.
Mike
DIY: Timing Belt
My Thread
mm71522 is offline
post #36 of 40 (permalink) Old 04-22-2016, 07:48 PM
I did my timing belt following the steps but now my is300 no start but im thinking is not timing problem because I have no spark the dots on the timing are line up right ..the gold timing plate still in good shape..no check engine light on any help will be appreciated thanks
Sent from my SM-G900T1 using Tapatalk
tollito is offline
post #37 of 40 (permalink) Old 09-22-2017, 11:16 PM
I'm going to begin this work tomorrow. Crossing my fingers...
JPB
Steps are calculated risks. Leaps are tests of fate.
SilverIsMy300 is offline
post #38 of 40 (permalink) Old 08-11-2018, 08:30 PM
Thanks!
feet is offline
post #39 of 40 (permalink) Old 10-22-2018, 05:09 PM
Lightbulb
Little tip if you're stuck taking the cam gears of yourself, to get to the seals: use a piece of wood to hold an adjustable wrench. This piece just so happened to be from a jenga set. For the other side, I used a large set of bolt cutters, which were the right length and could hold the wrench.
Pain the in ass, but I got it done solo.
YezzirDoodles is offline
post #40 of 40 (permalink) Old 10-23-2018, 10:35 PM Thread Starter
mm71522's Avatar
Quoted: 353 Post(s)
Not bad I use a big pipe wrench to hold the end of the adjustable wrench.
Mike
DIY: Timing Belt
My Thread
mm71522 is offline
Diy: Timing Belt & Water Pump sdfontanini DIY/tutorial forum 302 11-26-2016 07:27 PM
is300 timing belt diy Slavik Gud IS300 Owner's Forum 0 11-24-2010 01:20 PM
DIY Changing Timing Belt and Water Pump??? linner420 General Discussion 8 10-23-2008 07:26 PM
New timing belt/water pump < 100 miles and started ticking/ratteling ivo timing belt Rynocross IS300 Owner's Forum 2 08-10-2008 08:23 AM
any timing belt DIY/tutorials? legendnum2 General Discussion 1 03-10-2008 10:09 AM
