DIY Cam Gear Install - Page 8 - Lexus IS Forum
post #106 of 120 (permalink) Old 09-27-2012, 11:40 AM
Quoted: 18 Post(s)
Install cam gear at 0 and adjust it once everything is re installed.
Boost and Stuff- 2004 CW Turbo IS300 5MT LSD
354rwhp / 320lb ft @ 7.5PSI
Daily and Stuff- 2003 AR IS300 5AT LSD
rL-gT is offline
post #107 of 120 (permalink) Old 09-30-2012, 10:32 AM
Quoted: 11 Post(s)
Thanks for the reply, so the 2nd pic is how it should look, -3.5į, right?
Entropy964 is offline
post #108 of 120 (permalink) Old 12-26-2012, 01:08 PM
+1 rep
Nice writeup, +1 rep. Just ordered a fidanza-cam-gear. Got two questions about the install.
-How many degrees can I go before 02-sims are needed?
-Can I use my old timing belt and waterpump again (car has 32.000 miles on it)?
300Sportcrosser is offline
post #109 of 120 (permalink) Old 12-26-2012, 08:43 PM
Originally Posted by 300Sportcrosser View Post
+1 rep
I dont know y u would need 02 sims for cams. Since the sims are usually for the Catalytic Converter efficiency sensors. But either he doesnt want to pay for those sensors, or is decatted on a stock manifold.
Inspect the Timing belt prior to installing the cam gear if it looks cracked or decaying change it while or before installing your cam gear.
`04 Onyx Black IS300 MT
Teck Pro Ground Kit, FIGs hood Prop, FIGs CDD, GIGA LEDs, Auto Illumination, TOM's drop-in, JOEz intake tube, TS 02 delete, TS Trac Module, FIGS BBK PPK3, Eibach Prokit & Sways, Tokico HTS, T.P. RIGID Bars, Tanabe Under Braces, Apex WS II
taks_is300 is offline
post #110 of 120 (permalink) Old 12-27-2012, 12:27 AM
Th o2 thing I read earlier in this thread. I surelly missunderstood it, becaues there were mentioned headers, too.
Will watch out for cracks in the belt. Thanks.
post #111 of 120 (permalink) Old 12-28-2012, 07:37 AM
Bezik777's Avatar
Quoted: 44 Post(s)
Lexus recommends the timing belt replaced at 6 years or 90k miles, whichever comes first , i would stick a new one on !
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #112 of 120 (permalink) Old 02-05-2013, 02:47 AM
Quoted: 11 Post(s)
Thanks for the great tutorial, i did mine yesterday.
Preparation is everything, mark the old belt, the 3 gears, dismount the old belt,
mark the new like the old one and install everything like before:
Set to -4 lines (hopefully degrees on the cam itself). I dont like the construction of
all the adjustable cam gears, the hex screw on the back is not reachable, i
used some loctite 243 and secured the nuts in the front with 9.5Nm.
The screw should be connected to the other screws to prevent turning.
Looks great in the car, unfortunately there is a cover on it
I started up the car, but did not drive around, so lets see if there are power gains!
post #113 of 120 (permalink) Old 02-16-2013, 06:48 AM
Bezik777's Avatar
Quoted: 44 Post(s)
-3 or -3.5 are best overall settings ....For NA
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #114 of 120 (permalink) Old 03-06-2013, 04:15 PM
Has anybody used the OBX Exhaust Cam Gear Sprocket.. worth time getting?
Ken386 is offline
post #115 of 120 (permalink) Old 01-21-2014, 04:12 PM
Quoted: 17 Post(s)
Sorry to ressurrect an old thread (albeit a good DIY thread), I think Leonard mentioned the replacement of the cam gear will give a smoother power band but I cant wrap myself around that notion when all you're doing (before any -/+ adjustment) is replacing a pulley with another pulley. I can see the benefit with retardation and maybe thats what he meant and then add BC cams or the like. Am I right?
Arent those Megan headers making your car awfully loud? I know some like that result...lol
Also I like this DIY for replacing your timing belt at the same time if its due!
Rayson is offline
post #116 of 120 (permalink) Old 04-09-2014, 07:08 AM
Bezik777's Avatar
Quoted: 44 Post(s)
Dyno proven and better throttle response ...with changes ... Most adj cam gears are lighter at least my ur pulley is...if you are staying at "0" no reason to change pulley unless you was it to look pretty ...
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #117 of 120 (permalink) Old 05-14-2015, 03:39 PM
Probably a stupid question, but I need the posts to get access to the FS/FT section. Do you turn the inner part of the adjustable cam clockwise or counterclockwise to retard? Thanks. I am assuming you turn the inner part in the same direction as it rotates to retard. Thanks!
jeffsgail is offline
post #118 of 120 (permalink) Old 08-19-2015, 11:22 AM
Can anyone tell me how to set the timing on 01 is300 3.0 2jz-ge vvti engine . Did head gasket and messed up by not marking timing and took head off and cams and now i reinstalled everything but cant figure timing out . Help me please . If i have #1 tdc and try to line cam gears up they wont turn but so far due to valves hitting . Took cams out and tried setting them and then tighten caps down but wont work because valves are trying to go down again .
justin323 is offline
post #119 of 120 (permalink) Old 10-22-2018, 05:16 PM
Shared this on the timing belt DIY thread. This worked well for me to get the bolts off the cams while solo. I used a pair of bolt cutters, oddly enough, for the intake cam, and for some resistance while tightening.
YezzirDoodles is offline
post #120 of 120 (permalink) Old 02-18-2019, 07:48 AM
I just finished up my install over the weekend and just wanted to thank the OP and everyone else who contributed to this thread! It was invaluable info that greatly helped make the install go smoothly. I set mine to -3*, and the car def runs a little better...becuz my but dyno says so-lol. Here's a couple of pics:
Name:	lexus adj cam gear 1.jpg
ID:	122661   Click image for larger version
Name:	lexus adj cam gear 2.jpg
TobiasSing likes this.
lexa$$01 is offline
DIY: Exhaust Cam Gear sdfontanini Go Fast Stuff 16 06-04-2008 08:16 PM
Need help...Cam gear install miubhi856 Go Fast Stuff 1 02-17-2008 09:14 PM
Cam Gear Install ISZach Go Fast Stuff 2 09-01-2006 09:04 AM
Any DIY instruction on Cam gear!! wat_it_IS Go Fast Stuff 26 03-22-2005 07:23 AM
Please help with cam gear install. bpointer Go Fast Stuff 16 04-10-2002 08:59 PM
