DIY Cam Gear Install - Page 7 - Lexus IS Forum
post #91 of 120 (permalink) Old 03-12-2011, 07:43 PM
A tip when I did mine use white finger nail polish for marking
LexusSpeed01 is offline
post #92 of 120 (permalink) Old 03-12-2011, 11:41 PM Thread Starter
Its already in the directions that I wrote.
Im your local smarta$$
leonard_is300 is offline
post #93 of 120 (permalink) Old 03-12-2011, 11:46 PM
DOH was trying to figure out what to mark it with earlier when I was doing my cam gear install.
post #94 of 120 (permalink) Old 05-17-2011, 09:45 AM
okay i tried taking off my oem cam but it seems to not be coming off. It keeps turning with the bolt? Am i doing this right nor not? Do i keep turning and have the cam come off with the bolt?
svv323 is offline
post #95 of 120 (permalink) Old 05-17-2011, 12:08 PM
hold the crank pulley so the engine won't turn and then try to loosen the cam bolt, with the belt still on of course.
'03 IS300 Turbo
SportDesign | 5MT | LSD | Black Onyx
Velocity211 is offline
post #96 of 120 (permalink) Old 05-18-2011, 10:54 AM
^^ x2!
It'll be much easier that way with the t-belt still on.
Great DIY.
1994 Honda Accord EX; JDM H22A/T2T4 LSD = 204whp/157wtq
2002 Lexus IS300 5spd (R.I.P)
nusdogg is offline
post #97 of 120 (permalink) Old 05-18-2011, 12:07 PM Thread Starter
put a 17mm wrench on the bolt and hit it with your hand, if your not a pretty boy it should break loose.
post #98 of 120 (permalink) Old 07-14-2011, 08:45 AM
Originally Posted by leonard_is300 View Post
Loosen the five or 3 bolts on the cam gear and put a 17mm wrench on the bolt holding the cam gear to the cam and very gently tap it towards the way you want. and make sure you tighten the 3 or 5 bolts so your cam gear does not slip.
Hey Donnie.....is there a torque spec for those 5 bolts on the UR cam gear? How tight should it be?
2012 VW Sportwagen TDI SOLD
2014 Subaru Forester XT SOLD
2007 Saab 9-5 Sportcombi Aero SOLD
2015 VW Tiguan
1998 Lexus LX470
sway162 is offline
post #99 of 120 (permalink) Old 07-14-2011, 09:53 AM
Never mind^ Found it on their website.
2015 VW Tiguan
1998 Lexus LX470
sway162 is offline
post #100 of 120 (permalink) Old 07-15-2011, 10:08 PM
I did alot of reading and with our motors -4 yeilds the best results with an intake and exhaust. i have the Brian crower 264 cams and valve train, full exhaust, and intake i have the cam gear set to -4 and im all on the stock tune. slapping this cam gear on and setting it to -4 will be fine on stock tune but if your wanting to get the most out of your NA car and have an SAFC or something like that then a tune would not hurt at all!
A stock IS300 can have a cam gear set to -4 without messing anything up.
thanks for the clearing up! i was wondering where the negative 4 came from.
Ignited Alchemy is offline
post #101 of 120 (permalink) Old 03-10-2012, 05:50 PM
Thanks for the write up! It looks a lot more simple then I expected. I've had my gear for a year now and it just sits there. haha. I'm still pretty new to car stuff.
`01 MSM
jazilla is offline
post #102 of 120 (permalink) Old 03-10-2012, 09:49 PM
I'd be scared as hell to install my own cams... 0_o
Colin IS300 is offline
post #103 of 120 (permalink) Old 07-26-2012, 09:35 PM
Quoted: 18 Post(s)
Bumping this cause I just did this install.
Boost and Stuff- 2004 CW Turbo IS300 5MT LSD
354rwhp / 320lb ft @ 7.5PSI
Daily and Stuff- 2003 AR IS300 5AT LSD
rL-gT is offline
post #104 of 120 (permalink) Old 07-27-2012, 09:27 AM
Quoted: 11 Post(s)
I might attempt this mod this weekend! Seems like solid info on here!
ShiftnGears is offline
post #105 of 120 (permalink) Old 09-27-2012, 11:36 AM
Quoted: 11 Post(s)
Hi!
I will install my TITAN Cam Gear soon, so i want to check if my plan is right.
0) Install two O2 Sims
1) Adjust Cam Gear to -3.5
2) Tighten the 5 nuts with 48 inch pounds, which means only 6Nm (?!) and use Loctite 243
3) Timing Belt Change, Water Pump Change and so on
4) Start der Car und have fun?!
Or do i have to install the cam gear with setting 0° and adjust it when its mounted?
Here is the pic, i think i have to fasten it like the pic below.
I'm glad to get some help, rest of the setup is original IS300, except muffler.
Thanks!
Entropy964 is offline
DIY: Exhaust Cam Gear sdfontanini Go Fast Stuff 16 06-04-2008 08:16 PM
Need help...Cam gear install miubhi856 Go Fast Stuff 1 02-17-2008 09:14 PM
Cam Gear Install ISZach Go Fast Stuff 2 09-01-2006 09:04 AM
Any DIY instruction on Cam gear!! wat_it_IS Go Fast Stuff 26 03-22-2005 07:23 AM
Please help with cam gear install. bpointer Go Fast Stuff 16 04-10-2002 08:59 PM
