DIY Cam Gear Install - Page 4 - Lexus IS Forum
post #46 of 120 (permalink) Old 06-23-2009, 12:57 AM
Quoted: 50 Post(s)
Originally Posted by winslow View Post
All Honda motors are interference motors and they all use timing belts.
ok your right about that, but Honda's run higher compression ratios and valve clearance to the piston is really close so if a belt breaks. sha bam! so does the valve or anything else. Toyota's have more clearance than Honda does so if a belt breaks nothing happens. like when my timing belt broke on my cressida (5M-GE straight six motor) nothing happen i just rolled to a stop towed the car home replaced the belt and it was backup and running fine ;-)
doen't mean are motors are interferance engines. i just know that the J and M motors aren't interfrance.
Poke_IS300 is offline
post #47 of 120 (permalink) Old 06-23-2009, 06:44 AM Thread Starter
our 2JZ-GE engines are interferance motors trust me. the only motors from toyota that i know are non-interferance are the 5S-FE and 3S-FE. You snap a belt on the 2JZ and your going to be buying alot of stuff for your engine.
Im your local smarta$$
leonard_is300 is offline
post #48 of 120 (permalink) Old 07-26-2009, 04:51 PM
I often see pictures of cars without the cover over the cam gears...is it better to keep it on? I figure it may just be taken off for image purposes.. But it looks good so I would prefer to keep it off. I just ordered a Greddy Cam Gear in blue/silver and just waiting for it to get here so I can install it.
03 GGP Sport Design
Greddy CF Front Lip + AAC CCFL 8k Halo Headlights
Greddy Evo II Cat-Back + SRT Intake + R-ECU
Ghazali_GTE is offline
post #49 of 120 (permalink) Old 07-27-2009, 06:30 AM Thread Starter
keep the cover on, its there to stop debris from getting at your timing belt. the last thing you want to do is replace your engine because a rock tore your timing belt since you left that cover off.
post #50 of 120 (permalink) Old 07-27-2009, 07:01 AM
Thanks. I figured that would probably be the smart thing to do, lol. Maybe I'll just have to have a photoshoot before I cover it back up after the install...I suppose I could also just take it off sometime too..would it be a wise decision to change my timing belt simultaneously, since it's already open and there? I just hit 77k miles and it has not yet been changed.
03 GGP Sport Design
post #51 of 120 (permalink) Old 07-27-2009, 11:38 AM
Originally Posted by leonard_is300 View Post
They are actually red here is a better picture of my setup
My engine mods are
Toyo Moto header
Megan y-pipe
Full brian crower head setup with 264 cams
Unorthodox Cam gear set to -4
Joe-Z style intake
Un-oiled K&N Filter
All on stock ECU
What would you say that you are putting to the rear wheels?
IS300Enthusiast103 is offline
post #52 of 120 (permalink) Old 07-27-2009, 11:52 AM Thread Starter
well since our cars really come alive with boost its not much but way better then stock. I would like to say im putting about 215 to the wheels
post #53 of 120 (permalink) Old 07-27-2009, 03:11 PM
Not Bad!
Thanks
post #54 of 120 (permalink) Old 07-30-2009, 06:46 AM
Setting the new cams to -4 won't turn on the check engine light will it?
03 GGP Sport Design
post #55 of 120 (permalink) Old 07-30-2009, 06:56 AM Thread Starter
no it will not, i have had mine set to -6 with no CEL
post #56 of 120 (permalink) Old 07-30-2009, 07:18 AM
That's good to know. I'm going to install mine this weekend!
03 GGP Sport Design
post #57 of 120 (permalink) Old 09-22-2009, 05:35 PM
The Toyota 3S-GTE is also non-interference.
Just on the tuning of the cam gear:
How do I set the cam gear? The intake is all apart and I want to know if I need to pull the valve cover to turn the cam or can I turn it elsewhere?
Also to confirm, HKS cam gear so two ticks = 4* right?
mr2_mike is offline
post #58 of 120 (permalink) Old 09-22-2009, 08:42 PM Thread Starter
Well not matter what a NA 2JZ-GE engine will be an INTERFERENCE engine. Well the best way to turn the intake cam is by the camshaft itself. It is not a good idea to turn the cam over when the timing belt is not on either. Doing so can bend valves and wreck the valve face and its possible to damage the piston. SO your best bet to turn the intake cam is to either keep the timing belt on and turn it by the crank pully bult OR remove the timing belt and turn the crank a little and then the intake cam a little and keepdo that over and over. This is assuming the exhaust camshaft is out. All in all it is not the best idea to turn the camshaf over using just the 10mm alen bolt holding the VVT-i cam gear to the camshaft. I am not sure if you know this but DO NOT EVER DISASSEMBLE THE VVT-i CAM GEAR!!! Once it is taken apart it is junk and you will need to buy a new one. And I think on the HKS exhaust cam gear eith tick is 2 degree's i could be wrong. I think it was talked about at point in this thread.
post #59 of 120 (permalink) Old 09-22-2009, 09:17 PM
I went in loosened the three screws on the HKS. Then with an arm to hold the t-belt from moving, I used a 17mm wrench and turned the ext. cam two ticks towards the Retard.
Is this right?
mr2_mike is offline
post #60 of 120 (permalink) Old 09-23-2009, 01:03 PM Thread Starter
it will show you on your cam gear which way is advance and retarded, or at least mine does.
DIY: Exhaust Cam Gear sdfontanini Go Fast Stuff 16 06-04-2008 08:16 PM
Need help...Cam gear install miubhi856 Go Fast Stuff 1 02-17-2008 09:14 PM
Cam Gear Install ISZach Go Fast Stuff 2 09-01-2006 09:04 AM
Any DIY instruction on Cam gear!! wat_it_IS Go Fast Stuff 26 03-22-2005 07:23 AM
Please help with cam gear install. bpointer Go Fast Stuff 16 04-10-2002 08:59 PM
