Sportcross Story GTE AR5 Build - Lexus IS Forum
 12Likes
post #1 of 45 (permalink) Old 10-26-2015, 02:04 PM Thread Starter
Quoted: 28 Post(s)
Starting to get some progress on my build so updating finally, decided to create a new build thread since I didnt want it to be confused with my old sportcross. Here is a link to the my original sportcross build.
https://my.is/forums/f219/sportcross-...3/#post6610450
To recap a little, purchased a sportcross with 475,000 miles!! and bad motor and.... well everything lol. Pulled motor and plan to put in a 2JZGTE with a single turbo, and a manual conversion. Along with paint, new suspension parts, wheels tires, well you get the picture.
The purpose of this thread will be not only to share my car story, but I will also try to fill some gaps left in some of the information out there.
Here is a glimpse off the top of my head of the parts list....
Aristo 2JZGTE
New Titan motorsports modified oil pump
Mojo lq9 coil kit
Gates timing belt
SRT billet tensioner bracket
New OEM Exhaust, intake, valve cover gaskets
New OEM front, rear seals
New OEM M/T drive belt tensioner “kit”
New OEM Crank pulley, timing belt tensioner
Vvti cam gear rebuild kit
Megan racing motor mounts
AR5 5 speed, transmission mount/isolator
OS Giken R3C
OS Giken movement alteration kit
Sequioa custom driveshaft
Arp custom flywheel bolts
Drift Motion Stainless steel clutch line
New clutch pedal assembly/ Brake pedal assembly
M/T LSD
New OEM R154 Slave Cylinder
New OEM R154 Bellhousing
New OEM R154 Retianer/ seal
Proefi 128
Color disply/logger
Flexfuel sensor
Oil sensor
Fuel sensor
5 bar sensor
wideband sensor
IAT sensor
Iboost switch
Sound Performance Torque monster kit
Precision DBB 6466
Precision 46MM waste gate
Ported Treadstone T4 Manifold
SP Quick spool valve
Squash performance Dual fuel hanger
Walbro 450 E85 pumps
Titan Fuel rail
ID1300
Drift motion flex fuel sensor fittings
Vibrant An fittings
Vibrant nylon braided -8 feed -6 return
Fuel Lab fuel filter
Aeromotive regulator
Altezza ABS bracket
Finshing lines stainless steel brake lines
Here is what it looked like bringing it home. Doesnt look to bad in this picture, but the car is actually pretty rough and in need of some serious TLC
screen grab
Pulled hood
upload image online
then motor
windows 7 screenshot
free upload image
13 J8A FR-S Series 10
01 DWP IS300 Sold
Curran is offline
post #2 of 45 (permalink) Old 10-26-2015, 02:05 PM Thread Starter
Quoted: 28 Post(s)
ABS relocation
ABS Relocation
Relocated the abs using the Altezza rhd bracket, planned on just bending and re-flaring the stock lines, but it wasn't looking as good as I wanted, so ended up buying the ABS relocation kit from finishing lines. Since my altezza bracket was about 8” closer to the fender than the kit was designed for, I asked they lengthen the lines that amount. When I got the lines they are super long, makes it difficult to make it look very clean. I need to find some brake line retainer similar to the stock clips but not finding anything yet. I personally like the look of hard lines better so might swap them out in the future.
image ru
01 DWP IS300 Sold
Curran is offline
post #3 of 45 (permalink) Old 10-26-2015, 02:06 PM Thread Starter
Quoted: 28 Post(s)
Tunnel modification
Tunnel Modification
I have a lot of people ask about the tunnel, pedals, and clutch master cylinder installation. So here are some details of my second time.
In my first manual swap, I had created a box to account for the different height of the tunnel, and then later decided to complety remove the auto tunnel and replace it with a manual tunnel. It looked good, but it was a pita. This time around I decided to do it a little different.
Got a used manual tunnel for free, traced where I wanted to make my cuts
image hosting over 2mb
image upload no size limit
marked where I wanted to cut the auto tunnel
image sharing sites
gif uploader
post a picture
test fit and painted “missed painted picture”
free upload image
Forgot a picture, but drilled and placed rivits, then put down some seam sealer.
free image uploading
image sharing
upload an image
and finally installed the rivets.
screenshot tool
photo uploading
01 DWP IS300 Sold
Curran is offline
post #4 of 45 (permalink) Old 10-26-2015, 02:07 PM Thread Starter
Quoted: 28 Post(s)
Clutch Master Cylinder installation
I trace a outline of the area cut out on the firewall on a piece of card stock, I just use junk mail, then center the clutch master cylinder on it to make a template.
upload gif from url
then trace it to the firewall
adult photo sharing
then cut, and paint the raw metal
jpg images
and install the CMC
host image online
01 DWP IS300 Sold
Curran is offline
post #5 of 45 (permalink) Old 10-26-2015, 02:08 PM Thread Starter
Quoted: 28 Post(s)
Clutch/ Brake Pedal Installation
So after buying a RHD pedal set and realizing that there are not the same as the LHD pedals, starting looking for a used LHD set. I couldnt find anything at a reasonable price so decided to buy new. Ordered new parts from amayama and quickly realized I had ordered the wrong brake pedal DUH!!!! more on that in a little bit...
image hosting 15mb
post images
I know there is a clutch pedal thread here on the forum, but it is mostly incomplete, so here is a little more info
screen capture tool
I do not have the proper names for everything so just hang in there.
imag
Install plastic bushing
free image hosting
followed by metal busing
free screenshot software
install the pedal stop
gif hosting
install spring clip
upload images free
install clucth master cylinder retianer
photo sharing sites
install busing
greenshot
spring, “I use grease on mine to prevent squeaky noises”
post images
this thing, with c clip
free photo upload
and larger spring, with more grease
image hosting free no registration
so then I thought I would modifiy my orginal brake pedal. Traced out the shape of the manual pedal, installed it and realized that it still wasnt right, way to far left. Cut my losess and ordered another pedal.
And finally 3 pedals again
picture sharing
01 DWP IS300 Sold
Curran is offline
post #6 of 45 (permalink) Old 10-26-2015, 02:15 PM Thread Starter
Quoted: 28 Post(s)
Motor Maintenance
Getting ready for motor maintence, stripped the motor and painted the block black “no picture” had the turbo water lines for the old turbos tig welded shut. Cleaned them up, painted the water neck.
host image online
20mb image hosting
free image host
switch over the pulley to Srt billet bracket
screen shot pc
cleaned up and painted the oil cooler wrinkle black
photo uploading
I had purchased my turbo kit new but second hand, so it was already all black, wanted to keep the motor somewhat symetrical so decided to paint the intake to match. Cleaned and taped up lower intake, upper intake, and throttle body, and painted wrinkle black.
gif upload
imagur
how do you print screen
painted
image upload no compression
free image hosting
screen capture
Then painted the motor mounts, but repainted then the same black.
image hosting over 10mb
bought some used low mileage megan motor mounts from a member here
upload gif
had a problem getting the orginal map sensor tapped for the 1/8 npt size, so had that hole tig welded and made a new hole and tapped it.
image hosting 30 mb
Also taped the oil line union bolt for the pro efi oil pressure sensor... finished and installed
image upload no registration
Day for motor maintenance, had my mechanic friend stop by for guidance, since..... well im a newbie to this sort of thing. Have all my parts organized waiting to be installed.
imagehost
Not many pictures here, but tore down motor, for new titan modified oil pump. Didnt know there was orings on the pan and oil pump, off to toyota....
pic host
Honestly I think this motor had already had its major service done, many parts seemed like aftermarket brand, but I didnt want to trust anything so after a long day everything installed with new parts.
upload pictures free
eoe021 and corby_baby like this.
01 DWP IS300 Sold
Curran is offline
post #7 of 45 (permalink) Old 10-26-2015, 02:37 PM
Quoted: 41 Post(s)
wow brandon, talk about attention to detail. this will surely look great when it's done. What's your plans for the body? are you going to go gita bumpers with lips?
2002 MSM Sportcross
TEIN//Gita//Blitz//Pioneer//FIGS//Work
instagram - ellis300
ellis300 is offline
post #8 of 45 (permalink) Old 10-26-2015, 04:28 PM
Quoted: 14 Post(s)
Well this build is already making mine look like a Mickey Mouse job.
Very impressive.
Land Ark is offline
post #9 of 45 (permalink) Old 10-26-2015, 05:57 PM
Quoted: 14 Post(s)
Looking forward to see where this build goes, I'm still undecided which route I want to take with mine but yours is motivation
chandlerdoom is offline
post #10 of 45 (permalink) Old 11-15-2015, 11:31 AM
Quoted: 11 Post(s)
I'm interested to know where did you buy the m/t drive belt tensioner kit? This is something I need to do asap. Was there any modifications needed for it to fit? I had read before that the bolts didn't line up to block.
At one point I was doing research about the ar5 but another member on here who had tried that setup recommended that I shouldn't go that route. I ended up getting an R154 built with all the MC upgrades.
GTE IS 300 is offline
post #11 of 45 (permalink) Old 11-18-2015, 01:09 PM Thread Starter
Quoted: 28 Post(s)
Unsure right now, was going with a elegance kit, but now im thinking making of making something custom.
Very impressive.
Thank you sir,
I can understand that, it took a couple years before i decided this is the build i wanted.
I bought a lot of my new toyota parts from amyama trading co, simply because it was less money than to buy locally from my toyota dealership. There are no modifications necessary to make it work, it all literally bolts on. I will say that the bracket in the diagram is not positioned correctly so i made me totally confused for about ten minutes lol.
As far as the AR5, well i believe it has proven itself a worthy alternative. Now will it be comparable to a MC R154? i dont think so, but i think it will suit me fine for my goals and driving style.
01 DWP IS300 Sold
Curran is offline
post #12 of 45 (permalink) Old 11-18-2015, 01:19 PM Thread Starter
Quoted: 28 Post(s)
Ar5
AR5 Swap
Some of you may have seen some of the information that I have helped contribute in the AR5 swap thread. Im finally getting around to getting mine put together. I have had some back and forth on what would fit my goals clutch kit wise, but here is what my final setup will look like.
OS Giken R3C
M/T LSD
New OEM Bellhousing covers
Here is the AR5 transmission when I got it delivered, I was able to sell the bellhousing and shifter assembly for what I basically paid for the transmission.
image free hosting
Here is when I received another order from amayama. I had no R154 parts so I bought them new.
windows 7 print screen
with the jzx shifter housing it fits perfectly for the is300 application 29” from bellhousing front to center of shifter, exactly the measurement for the is300. The shifter housing is literally a bolt on part for the AR5, there is no modification necesary
imgur
adult image hosting
removed the retianer for R154 style retianer
image sharing
cleaned up the old fipg
how do i print screen
put down some new fipg
free image hosting
put on retianer seal
how to take screenshots
and bolted up retianer
put on the 2JZ r154 Bellhousing
image post
A single disk clutch wasn’t going to work for my power goals, so after a lot of research I noticed a popular clucth was OS Giken. I had contacted driftmotion about getting custom disks for the AR5 26 spline input shaft, but they didn’t think the OS Giken would, and didn’t seem interested in finding out.
So I contacted OS giken USA and they said that the special order wouldn’t be a problem. I also noticed RHD Japan had much better prices with the OS Giken line, so after letting them know about my special Order, I ordered the RC3 triple disk clutch, with the OS Giken movement alteration kit.
Here it is
free screen capture
When I received it, somehow my special order got overlooked, and I received the wrong clutch hub. They had filled the order with a regular 21 spline hub for a R154, when I had ordered 26 spline. Luckily it was no problem and they sent out the right hub.
One of the reasons I choose this clutch kit, is because the unique way the hub is seperate from the disk. So in the future when I get replacement disks, I wont have to worry about a special order, I can just get the regular disk rebuild kit for a r154.
screen shot windows
upload an image
Installation of the movement alteration kit
I didnt receive instructions with my movement kit, but here is how I did mine.
Install this bracket, may note that the bottom side is longer than the top, if you dont install correctly it wont line up right. The guide post is also installed here. Everything has locktite on it.
screen shot windows 7
Then remove two bellhousing bolts, and install larger peice
upload image free
this part is tricky and dont know how to explain it but here is a picture lol.
upload gambar
put clip on
upload foto
Slide on hub and put on the springs
image hosting adult
gif upload
One of the big misconceptions out there is that you will need to trim 1” off the input shaft, but actually the input shaft could fit with out any modification. I decided however to trim 1/8' off the input shaft to make it resemble more like a r154 input shaft. I also tapered/rounded the tip to make it easier for installation.
screen capture windows
Install pilot Bearing, I got mine from driftmotion, but all you need is a pilot bearing with a ID 15mm and OD 32mm
photoupload
Install Flywheel. May note OS giken flywheel uses a reduced depth flywheel bolt, and that stock flywheel bolts torque specs are 36ftlbs + 90 degree. I used arp which has some different information out there, I just followed the instructions from drift motion where I bought the bolts, and used locktite and 75ftlbs.
how to screen capture
Mark them as I go, especially helpful when tightening the 18 bolt cover.
picture upload
While not necessary I picked up a steel alignment tool to easy assembly of the multiplate clutch.
free image hosting
assembly the clutch, locktite and 13ftlbs in the order provided from the instructions
photo hosting sites
And finally the bolted up the transmission to the engine
had to swap out the “slide pin?” on the slave cylinder to the one provided with the OS giken alteration kit.
screen capture software
photoupload
Install slave cylinder
image hosting no register
install cover plates
image hosting websites
image hosting 5mb
The Nuke and el_jefe like this.
01 DWP IS300 Sold
Curran is offline
post #13 of 45 (permalink) Old 11-18-2015, 07:52 PM
Quoted: 38 Post(s)
What did the clutch/flywheel setup run you? I'm looking at going with an AR5 shortly.
el_jefe is offline
post #14 of 45 (permalink) Old 11-19-2015, 03:02 AM
Quoted: 45 Post(s)
Not a fan of the sportx, looks like station wagon lol but the fact that your one of the very few with a manual and swap makes it a collector's item. It's gonna be worth alot, definitely hang on to it
Its Better To Have And Not Want, Than To Want And Not Have
LIFE never stops teaching, so we should never stop LEARNING
Watch build thread. : http://www.youtube.com/playlist?list...XBnCliYMmEcTAH
dreadis300 is offline
post #15 of 45 (permalink) Old 11-20-2015, 10:46 AM
Quoted: 11 Post(s)
I'm loving your clutch setup
AlphaTuned
05 IS300 GGP ProEFI 2JZGTE VVTI 685whp 621wtq @30psi
A Sportcross Story Curran Member Build Threads - Lexus IS only 291 03-31-2016 07:47 AM
Sportcross anyone? (story inside) enyaw Canada 15 12-20-2013 01:30 PM
SportCross a Love Story AltezzaGita02 SportCross Owner's Forum 14 06-03-2013 12:56 AM
Cool Story, Bro. Spacer Horror Story Update w/pics s300ae Stop, Drop and Roll 50 10-22-2010 01:04 AM
THE HELL STORY - Car won't start, need help! Long story... lil' IS 300 Go Fast Stuff 44 12-16-2003 05:27 PM
