Koyo's are back! - Page 6 - Lexus IS Forum
post #76 of 92 (permalink) Old 09-13-2011, 09:51 AM Thread Starter
Supporting Vendor
THMotorsports's Avatar
In stock!
PM ME FOR ALL QUOTES.
Will Xiao
- Phone: 1-800-959-0145 EXT: 7028
- [email protected]
THMotorsports is offline
post #77 of 92 (permalink) Old 09-19-2011, 09:11 AM Thread Starter
Supporting Vendor
up top
Will Xiao
- [email protected]
post #78 of 92 (permalink) Old 10-10-2011, 12:10 AM
Quoted: 27 Post(s)
Still in stock?
Do you guys have any 1.1 Bar caps that would fit? I haven't had much luck finding any other than the HKS D1 limited edition. If you have one that would work I'd be interested in that also. You have the HKS one on your website so I mainly wanted to confirm that if I ordered it it would be a 1.1 bar.
I really wanted a TRD cap but all I can find are 1.3 bar. And after searching I dont think they made a 1.1 bar...
white_is is offline
post #79 of 92 (permalink) Old 10-11-2011, 11:18 AM Thread Starter
Supporting Vendor
We don't have any 1.1 bars in stock. Get the TRD cap at 1.3bar.
Will Xiao
- [email protected]
post #80 of 92 (permalink) Old 10-11-2011, 02:42 PM
baadhabit's Avatar
i did this swap years ago so maybe there are differnt versions but my TRD cap didnt fit the koyo. i had to use a Nissan cap.
baadhabit is offline
post #81 of 92 (permalink) Old 10-11-2011, 08:13 PM
Quoted: 27 Post(s)
So should I not be worried about this...
Originally Posted by black86 View Post
i dunno if you wanna use a high pressure cap. stock system has a max rating of 1.25 bar (17.8 psi) meaning yeah your fluid will now boil at a higher temp but pressure will be beyond the max capacity before any relief is given. think of all the coolant seals main example is headgasket! honestly, since you are already going 2 row you will be well within temps/pressure for the stock system to handle. especially w/o FI. going to a higher pressure cap is mainly to suppress hot spots within the motor and to keep an area from boiling and placing air in the system.
The TRD cap isn't worth it to me if it will cause issues later down the road. I mainly wanted it to go with my TRD oil cap.
I'll hold off on a cap for now, I don't plan on installing it for a couple months anyway.
But I did just purchase the Koyo
I assume you never had issues with the TRD cap being a higher pressure huh?
white_is is offline
post #82 of 92 (permalink) Old 10-12-2011, 08:55 AM Thread Starter
Supporting Vendor
no issues with the TRD bud, works just fine even on boosted apps.
Will Xiao
- [email protected]
post #83 of 92 (permalink) Old 10-13-2011, 09:36 AM
baadhabit's Avatar
no i never had any issues with the TRD Cap.
but just to be clear none of the IS300 caps OEM or TRD fit my Koyo.
post #84 of 92 (permalink) Old 10-17-2011, 08:25 AM Thread Starter
Supporting Vendor
What are you using now?
Will Xiao
- [email protected]
post #85 of 92 (permalink) Old 10-17-2011, 11:08 AM
baadhabit's Avatar
post #86 of 92 (permalink) Old 10-18-2011, 09:50 AM Thread Starter
Supporting Vendor
very nice!!!!
Will Xiao
- [email protected]
post #87 of 92 (permalink) Old 10-23-2011, 01:34 PM
Quoted: 27 Post(s)
I did some looking around on Supra forums and they said an older style TRD Type S cap would fit. I guess it's the newer Type N style that doesn't fit. Both are 1.3 caps.
Either way, I found a Type S cap so I bought it. Seems like it fits fine to me.
So unless there is some kind of issue with it being all the way sealed I think I'll be fine.
Ray I'm assuming it was blatantly obvious that your TRD cap wouldn't fit?
white_is is offline
post #88 of 92 (permalink) Old 01-03-2012, 10:33 AM Thread Starter
Supporting Vendor
up top
Will Xiao
- [email protected]
post #89 of 92 (permalink) Old 10-30-2012, 12:34 PM
Quoted: 27 Post(s)
Jonathan I just sent you an email. I bought my Koyo back in October 2011, but didn't get around to installing it until this past August. There seems to be a pinhole along a weld by the cap.
If you look REALLY close, you can almost see what looks like a pinhole while it's still in the box.
white_is is offline
post #90 of 92 (permalink) Old 01-03-2013, 02:54 PM
very interested in purchasing a Koyo radiator with no pin hole leaks please. also just wanted an update do these come with the koyo radiator caps or do I have to purchase a radiator cap on the side? thanks PM sent!
'02 Scarlet Red | HippoSleek | SRT | HKS | JDM | TRD | MAZZURI | iFORGED | MMSport | BCRACING | STOPTECH | VERTEX | MODELLISTA | APR | FORMULAONE |
HiPPOXSLEEK is offline
  Lexus IS Forum > Vendors > TH Motorsports
for those with koyo's Lexotic Concepts Go Faster 15 04-10-2009 09:09 PM
First Post! axel-back vs. cat-back/ SRT ?? CassiusKing Go Fast Stuff 5 10-24-2005 02:33 PM
cat back vs. axle back (rear section) 2JZ GE Go Fast Stuff 6 03-21-2003 04:13 PM
Type of bulbs for the corner, back, and back up lights wdskuk General Discussion 9 02-21-2001 03:15 PM
