"A program cannot be read. Please consult to a dealer" Please help!!! - Lexus IS Forum
post #1 of 11 (permalink) Old 04-15-2010, 06:20 PM Thread Starter
So I just installed a Vais Slv2i on my 2006 IS250 and when I reconnected the battery everything worked fine except the navigation system. My screen shows the error "A program cannot be read, please consult to a dealer" followed by some Japanese writing. How do I fix this?? Thanks for any help you can give!!
dshokair is offline
post #2 of 11 (permalink) Old 11-27-2010, 05:54 AM
I have exactly the same problem. Is there a fix. Im sure my nav worked after i installed my vais but I changed the battery and I dont think it has worked since then. is there a resetting procedure after a battery change?
Cheers
Darren
Libbor is offline
post #3 of 11 (permalink) Old 11-28-2010, 05:13 AM
any ideas Anyone??
Libbor is offline
post #4 of 11 (permalink) Old 10-04-2011, 06:00 PM
I am having the same problem with this message. Has anyone found a solution for this. It started after I disconnected my battery, ive been reading through the forums to find this problem.
fearstangs is offline
post #5 of 11 (permalink) Old 10-05-2011, 06:24 PM
I would try to remove the disc and reinsert it. The DVD is behind the panel where the clock panel is. There's two holes and with a small pick you should be able to pull it out.
My Build Thread
Solid_Snake is offline
post #6 of 11 (permalink) Old 11-19-2011, 04:55 PM
Same problem with my sat nav... after disconnecting the battery problem started.
I did try to remove disc and load again but it didn't help still the same message...
does anyone have a solution? dealer wants to order a new unit they don't know what's wrong.
dan11 is offline
post #7 of 11 (permalink) Old 11-19-2011, 04:58 PM
Hi fearstangs, did you find a solution? Thank you
dan11 is offline
post #8 of 11 (permalink) Old 11-23-2011, 09:21 AM
Problem solved!
Just in case someone else has the same problem, I've fixed mine and in my case it was a faulty disc that refused to load a necessary program so the unit can work after a full reboot. The original disc is still fine to run the map and guide to the destination but was not able to upload the program that got deleted after disconnecting the battery. All I needed was a new disc which I got from ebay
Hope this feedback helps to others here!
dan11 is offline
post #9 of 11 (permalink) Old 11-24-2011, 02:49 PM
nav fix
hi all
just had the same thing on my nav,
remove the nav and unplug all wires,
wait a few mins and plug it all back in,
it should work fine.
painterpaul is offline
post #10 of 11 (permalink) Old 01-15-2014, 04:03 AM
Toyota TNS 510 message error "A program cannot be read. Please consult a dealer"
I have. Contact me by e-mail for a solution [email protected]
t
Thanks
nehme388 is offline
post #11 of 11 (permalink) Old 12-08-2016, 09:54 AM
Contact for detail:
Call/Whatsapp/ Viber us @
+8801819199795
+8801672761737
BDCAR NAVIGATION DISK
Dhaka , Bangladesh
Visit:
Facebook: http://www.facebook.com/navigationdisk
Email: [email protected]
WE PROVIDE FOLLOWING SOLUTIONS
( Outside Bd)
# Insert Map Disk error?
# Insert SD card error?
# ESN unlock code error?
# Insert ERC unlock code error?
# Unlimited ERC Unlock Software
# Eclipse AVN ESN unlock code
# Pioneer Unlock
# Mitsubishi Unlock
# Clarion Unlock
# Clarion Unlock Softwre
# SD Card
# SD Card Software
# Mobile phone spy software
# Original Japanese radio unit with navigation
# Low cost Chinese radio unit with navigation
bdcar is offline
  Lexus IS Forum > 2nd-Gen IS250/IS350 > Mobiletronics
A program cannot be read, please consult to a dealer. Help!!! dshokair Mobiletronics 2 04-14-2010 10:24 PM
Car dealer steals truck back after "Price Mistake" YisSerL The Garage 4 07-29-2006 01:01 AM
Did you read the "Car Key Code" news story? MaChao General Discussion 21 05-11-2006 10:05 AM
Lease Early Termination "Program" tholzer General Discussion 3 03-03-2006 12:04 PM
