Added a sub to stock system killed my Alternator. - Lexus IS Forum
post #1 of 6 (permalink) Old 08-18-2016, 11:35 AM Thread Starter
2 weeks ago I had a shop install a single 12 JL Audio W3 with a 1000 watt Fosgate amp and 2 farad capacitor.
Install was tied into the stock amp in the trunk.
Now is it just a coincidence that my stock alternator is now fried or did they install something incorrectly or was the setup just too much for the stock alternator to handle?
2006 Lexus Is350.
Just replaced the fried alternator with a new one, question is, do I play my music now or disconnect.
I don't want this problem to happen again, the removal & install on that alternator sucked.
I didn't think one 12 with a 1000 watt amp would pull that much to kill the alternator, maybe it was just time the stock 2006 alternator took a dump or do you think the capacitor may have led to it as I have heard mixed reviews on them having a negative affect on the alternator. Or maybe a bad ground on the install?
Should I do the "Big 3", remove the cap or just take the beat out all together.
Whatcha guys think?
JaxBlack350 is offline
post #2 of 6 (permalink) Old 08-18-2016, 11:52 AM
Quoted: 60 Post(s)
I would have just taken it out...I had subs and all before...takes up trunk space when you already have a small trunk. Plus the stock system is way better than most cars already. Now when I see people with subs driving with passengers, in my head, I'm like, "Man, sucks that you either have to scream at your passenger for them to hear you or you have to turn down your system to talk."
Wanna go faster? Press the gas pedal harder!
DemonIs300 is offline
post #3 of 6 (permalink) Old 08-19-2016, 05:58 PM
Quoted: 167 Post(s)
I fried the rectifier in my IS300 in a couple weeks using an old school amp with a few subs wired pretty low impedance. I would guess something similar where the amp was drawing too much current for too long. They can either turn down the gain on the amp, change wiring so its higher impedance (if dual coil sub), or amp might have something that limits current draw like a high voltage/high current setting.
Personally, what I hate about most stock systems is that 40-100hz is over-emphasized. Because most OEM speakers aren't physically capable of handling down to 20 hz effortlessly they make it seem more 'bassy' by adding more bass in a higher range where the smaller speakers can handle. So even though most factory systems sound pretty decent modern digital signal processing, the low end is still painful to me and I get wanting to put in a 12" sub. infinite baffle setup however is what I prefer
2006 Lexus Is350.
Whatcha guys think?
whatthe is offline
post #4 of 6 (permalink) Old 10-04-2016, 09:37 AM
Does your radio turn off and on randomly now that you took them out? I have a 2010 250 IS, the person who had it before me had some but took them out when they sold it to me and now my radio will turn off and on randomly. Any ideas?
danipoo is offline
post #5 of 6 (permalink) Old 10-04-2016, 12:40 PM
Quoted: 60 Post(s)
Check the power wire to the deck and the ground wire. If it's loose and isn't connected correctly, then it's just connecting and disconnecting a lot. If that does happen, you are likely to fry your deck. Fix it before that does happen.
post #6 of 6 (permalink) Old 10-04-2016, 02:53 PM
Do you have you take the whole face off? Or is it the wires connected to the battery? All the wiring for the subs and amp are still connected.
danipoo is offline
  Lexus IS Forum > 2nd-Gen IS250/IS350 > Mobiletronics
blkaltezza's build blkaltezza Member Build Threads - Lexus IS only 349 03-05-2018 02:18 PM
Brand-New SP Series Short Ram Intake System by Injen for 2016 IS CARiD CARiD.com 0 08-04-2016 06:18 AM
Diy alternator swap homedepotmade DIY/tutorial forum 9 03-02-2016 11:17 PM
SUCCESSFUL Head-unit swap with ALL 9 stock speakers and stock amp (TYTO-01-kit) Nougatti SportCross Owner's Forum 39 06-26-2013 07:51 AM
