Supercharged IS250 Arma - Lexus IS Forum
post #1 of 15 (permalink) Old 11-04-2010, 03:17 PM Thread Starter
I'm going to supercharge my IS250. I have installed Invidia midpipe and catback. Guys from Armaspeed are ready to ship stage 2 kit which includes: Supercharger, fitting stand (a set of idle gear and a set of air filter), air intake, oil supply computer system, injection nozzle, breed valve and inter cooling. ARMASPEED
Question: Does anybody have ARMA kit installed? What disadvantages does supercharger kit have? Thanks for your comments!
pavlin1 is offline
post #2 of 15 (permalink) Old 11-04-2010, 04:13 PM
mainly price - $7480.
20incher is offline
post #3 of 15 (permalink) Old 11-05-2010, 06:43 AM
Yeah, it cost twice as much as just buying an IS350 rather than a 250.... and likely adds considerably less power than said upgrade will.
At 12:1 compression and the stock ECU/fuel you're not going to safely run more than 5-6 psi.
Knightshade is offline
post #4 of 15 (permalink) Old 11-10-2010, 09:23 AM
Also maintanace of the kit and/or replacement parts could be a hassle.
I was in communcations with Arma about the fitment for AWD. But havn't heard anything back in a while. They were looking to get support from a local shop to have the install done. I was more interested in a DIY kit at a discount so that they could perhaps gain some exposure.
John
2007 IS250 AWD Black/Sterling, LUX, ML, NAV, AFS, PCS
NAVI-KIT R-Spec TTN-46, JoeZ Intake, Mazzuri Super Headers w/ceramic coating, Tanabe MT
http://www.youtube.com/watch?v=Dr9FokzQUHY
Gaugster is offline
post #5 of 15 (permalink) Old 02-03-2011, 11:45 AM
If you got a 0.050" bigger head gasket then you're compression ratio would only be about 10.0 I think... The N54 BMW engine uses 10.2:1 and its boosting over 500rwhp on stock internals.
klipseracer is offline
post #6 of 15 (permalink) Old 02-03-2011, 12:57 PM
There's a reason that "slap on a thicker head gasket" is a poor solution for this motor that has been discussed in some detail elsewhere.
Edit- Found it-
http://www.clublexus.com/forums/4267714-post33.html
Originally Posted by lobuxracer View Post
Yes it will lower the compression ratio, but it will also ruin the squish height and in all likelihood create more opportunity for detonation. All the late model Toyota engines use an angled squish area to force the a/f mixture toward the plug in the combustion chamber. If the gap between the piston and the head is too great, this effect won't work and will promote detonation. So, a thicker head gasket is a really poor band aid.
There's a diagram of it in the link as well
Lower compression pistons are the other thing most often mentioned- but there's a technical challenge there too, the crown has a very specific shape to make the stratified lean intake charge work properly without detonation.... so any pistons that change the shape would have to be engineered to manage the same trick, which AFAIK nobody has successfully done.
There's one fellow on CL that sent a stock piston to a company to have them custom design some low CR ones with this in mind, but AFAIK he has not received anything back yet, let alone actually tried this in real life.
(and obviously a set of custom pistons, and swapping them, is not inexpensive)
post #7 of 15 (permalink) Old 02-05-2011, 09:46 PM
Is it just me or is that I/C tiny? I would have probably just sold the IS250 and gotten an IS350 or IS300 turbo.
Jerm__ is offline
post #8 of 15 (permalink) Old 02-07-2011, 07:35 PM
Not too small for a s/c. But above recommendations i would also do, 1st gen boost, or 350. Depending on your mileage already, maybe even save up for enough to compensate for an F and be on your jolly way.
2005 IIP
Tokico Illuminas // S techs // SRT // Greddy Evo II // W7 12 // P4200 // Hifonics
1st gen for life.
Volumedefiant is offline
post #9 of 15 (permalink) Old 02-08-2011, 02:45 PM
If it's because it's an AWD. Might as well throw in the difference to get the new 350 AWD.
wujo is offline
post #10 of 15 (permalink) Old 08-20-2011, 11:50 PM
water injection would go along way on super/turbocharging a 250/350 engine it effectively raises the octane on the fuel are using, keeps carbon down and lowers egt's
Ings250 is offline
post #11 of 15 (permalink) Old 09-29-2011, 12:59 AM
Under House Arrest
My friend has this arma supercharger.
It looks good and pretty powerful.
urluxury is offline
post #12 of 15 (permalink) Old 10-16-2011, 10:20 PM
what if he wants a manual? cant get that in a 350 so it might be worth it to him so he can keep 3 pedals. pls dont start some dumb argument with me about this either, some people might see it worth if they are like me and only wanna drive a stick
2015 Subaru BRZ Limited 6spd (I miss the IS)
-Sold- Tracked/AutoX'd 2002 IBP Is300 5spd
3 Pedals FTW
BlueTezza39 is offline
post #13 of 15 (permalink) Old 10-17-2011, 07:16 AM
So then he'll have a rigged-up engine with a crappy manual.
Wouldn't it make a lot more sense to convert a 350 to manual?
You'd have more power, in a factory-reliable engine, and a significantly better manual transmission as well.
It'll probably still cost a fairly dumb amount of money (I think the 6-speed manual kit from Japan is like 6-8k) but you won't supercharge a 250 for less than that anyway and the 250 route would get you inferior results in every sense.
Only issue might be any fittment problems adapting for LHD.
post #14 of 15 (permalink) Old 10-17-2011, 07:43 AM
yeah i really know nothing about the new IS's, besides what i've read on here about how hard they are to do anything, so i was just saying that might be a reason. i love the look of the new IS but if i had the money i dont think i'd get one just bc of the lack of a manual for the 350, tho i had no idea they had a manual conversion for the 350 in japan, kinda cool imo.
3 Pedals FTW
post #15 of 15 (permalink) Old 04-17-2017, 11:37 AM
Angry supercharger kit
Do you guys make supercharger kit for is 250 lexus anymore I like to know if you do thanks
jlimpahan is offline
who here is supercharged? stillatoy Go Faster 34 03-17-2011 07:22 PM
A Real IS250 Supercharged video Radeon888 Go Faster 9 01-27-2010 09:26 AM
Blitz Supercharged IS250 -408hp turnip General Discussion 4 01-18-2006 12:49 PM
If you are supercharged....... NY IS300 Showroom 3 10-20-2004 09:03 PM
Supercharged IS DAC17 Go Fast Stuff 12 12-17-2001 09:43 PM
