IS350 owner here... xenon bulbs aimed too low? - Page 2 - Lexus IS Forum
post #16 of 19 (permalink) Old 09-09-2010, 10:29 PM
Originally Posted by Knightshade View Post
Well, if the AFS method doesn't raise them high enough for your tastes you can always manually raise them using the under-hood adjustments... just remember to do both screws for each light... (so 4 total adjustments for 2 lights)
Cool - will try that too. Thx.
Supernintendo is offline
post #17 of 19 (permalink) Old 05-10-2012, 12:07 PM
I have a 2007 IS250 and just changed the headlights to 6000K. Went for a drive last night on some dark roads and it seemed like i could see really well for only 2-3 car lengths. Checked out the boards and found this thread and it helped a lot. I just wanted to add my experience.
I started by jacking up the driver side back wheel.
The best way to look at the AFS Level sensor is from the middle of the car looking back. The best way (for me) to adjust the AFS level sensor is from the back. Pic IMG_1702-adj.jpg is after i adjusted it and its still up on the jack. Pic IMG_1705adj.jpg is after the adjustment and the car is back down. Pic AFS-Adjustment-01.jpg shows how much i adjusted the the AFS level sensor. I only loosened the 10mm bolt located at the red circle on pic AFS-Adjustment-01.jpg
If this dosent help, im going to adjust the bolt so that it is all the way to the bottom of the slot. ill post more after checking my lights tonight.
ID:	32840   Click image for larger version
ID:	32841   Click image for larger version
ei79 is offline
post #18 of 19 (permalink) Old 05-16-2012, 09:05 PM
After adjusting the AFS Level sensor all the way down, there was some improvement but i still dont think its high enough. Seems to have improved a car length, im going to adjust the headlight directly a little bit.
ei79 is offline
post #19 of 19 (permalink) Old 06-01-2012, 03:25 AM
Under House Arrest
The sensor is behind the rear driver side wheel. You will need a 10mm socket.
poloaa008 is offline
  Lexus IS Forum > 2nd-Gen IS250/IS350 > Showroom
What size low-beam bulbs for non-xenon IS250/350's??? bimmer88 General Discussion 1 06-08-2007 07:29 PM
on is350, is one hid spost to be aimed higher than other? andrew350 Showroom 2 10-21-2006 10:08 AM
IS350 Changing the Xenon Bulbs ??? Mrbig General Discussion 2 04-04-2006 08:55 AM
