Installing LED DRL - Lexus IS Forum
post #1 of 3 (permalink) Old 03-19-2014, 03:23 PM Thread Starter
Installing LED DRL
Hi everyone, new to the forum and my 2010 IS350.
I am about to wire up some LED DRL strips and have no idea where I should tap into the acc power.
I've looked at the fuse boxes under the hood, and there isn't a easy to get the wires into the boxes while keeping the lids closed.
So I was looking at the wiring harness that appears to go down behind the headlights to see about tapping into one of those wires but there are a lot of wires in there and no idea where they all go or what they are for. My brain gets stupid when it comes to wiring.
So, where would be the best place to tap into the accessory power under the hood? Or should I think about running the wires into the cabin and doing something like an Add-A-Fuse?
I did search the forums and didn't see anything like this, found some posts about the IS300, but not for a IS350, if I missed it, my bad.
DNuggs is offline
post #2 of 3 (permalink) Old 05-01-2014, 12:06 AM
If the strips have built in resistors just tap them into your DRL's....Problem solved, If not I would run them through a toggle switch. easiest way would be the first if the resistors are built in, you can try it even if you don't know if they have it or not, they don't draw a lot of amperage, if you connect them and don't get any error codes then its a done deal. Since these aren't turn signals you should be OK
crzyruss80 is offline
post #3 of 3 (permalink) Old 11-21-2018, 05:46 PM
You should not get an error code since this is an add on item
I don't drive fast, I fly low
ericwudi0830 is offline
  Lexus IS Forum > 2nd-Gen IS250/IS350 > Showroom
Is250 led drl GeeRodreezy Mobiletronics 2 07-10-2013 06:59 PM
LED DRL Problem bam711 Showroom 13 07-13-2012 02:08 PM
help installing on/off switch for DRL NVMYlex General Discussion 1 04-07-2008 11:54 AM
blue LED DRL IS 2 NV Showroom 3 07-28-2003 05:06 PM
