need help with 2008 ISF RPM/Shifting issue - Lexus IS Forum
post #1 of 1 (permalink) Old 12-15-2015, 02:12 PM Thread Starter
Question need help with 2008 ISF RPM/Shifting issue
Hello everyone!
I'm having some RPM/shifting issues with 08 ISF. Here are the symptoms so far:
Unnaturally high RPMs in Neutral/Park whether on a cold start or after being warmed up. Drop back down in Reverse/Drive.
Standing up hill, if I put the car in neutral and let off the brake, it wont roll back until I tap the gas. It will then rollback for a second and then stop once again.
RPMs have to go much higher than before to shift into 2nd, 3rd, etc gear and the car jerks during the lower gears.
When in bumper to bumper traffic the jerking is much more noticeable as the car keeps shifting between low gears. (I drive in chicago traffic into the city for work so it gets old quick haha)
Under wide open throttle and then release the RPMs will drop very quickly but then once they hit 2-3k they will hang and bounce up before going back down. Never did this early on when I bought the car.
When releasing throttle, the car decelerates very slowly and wont come to a complete stop until the brake is fully pressed down and brake has pressure/pushback even when at a stop and car will lunge forward slightly when brake is released.
Here's what I've checked/had done.
Replaced throttle body, problem continued, put old one back.
Checked for vacuum leaks, apparently none.
Had transmission reflashed at dealer, same problem.
Had ECU reset, same problem.
Had data logged/read for an hour, nothing out of ordinary apparently.
Only thing that's obvious is that one of my cats is a bit clogged but mechanic friend said it shouldn't be causing it.
Also said MAF should not be issue either.
No idea what it could be and it's been driving (haha a pun) me nuts. It's my daily driver too so this worries me every day. To top it off, no check engine light so I'm completely in the dark!
Thanks in advance everyone! Hope I can figure out an answer soon.
Wojtek5884 is offline
  Lexus IS Forum > 2nd-Gen IS250/IS350 > IS-F
