Coming up on 150,000 - Lexus IS Forum
post #1 of 13 (permalink) Old 12-29-2011, 03:26 AM Thread Starter
Expieranced advice anyone?
Sedandan is offline
post #2 of 13 (permalink) Old 01-03-2012, 02:39 AM
Lexus
what advice do you need ?
sXe10 SoCal
R.I.P 1998 Toyota 4 Runner
2005 Lexus IS300 Bluestone Metallic "Altezza"
"There is a fine line between making your Car look Nice , and making your Car look Rice"
eL b3bO is offline
post #3 of 13 (permalink) Old 01-03-2012, 08:04 AM
Quoted: 18 Post(s)
lol all depends on how its been treated
DsouthMia07 is offline
post #4 of 13 (permalink) Old 01-04-2012, 02:49 AM Thread Starter
I'm starting to hear a "whining" noise from my rear right what could it be? And bank two sensor 2 o2 sensor needs to be replaced it looks somewhat complicated but not impossible
Sedandan is offline
post #5 of 13 (permalink) Old 01-04-2012, 03:12 AM
Lexus
hmm........a whining noise from your rear passenger side , not so sure about that , as for the o2 sensors its not that bad of an issue , are you positive its your sensors that need replacing , check the code your CEL is giving you ?
sXe10 SoCal
eL b3bO is offline
post #6 of 13 (permalink) Old 01-04-2012, 06:41 AM
Quoted: 18 Post(s)
that whining could be your wheel bearing. Change left and right if it is. Sometimes you can even lift that wheel off the ground and see if there is any play in the wheel, if there is even slightest play then it could be the bearing. Mine wouldnt really move but I would hear it click just a little when I played with it. I changed both my fronts and problem solved
post #7 of 13 (permalink) Old 01-05-2012, 01:16 AM Thread Starter
Yeah I did a diagnostic and 2 problems came up, o2 sensors bank2 and evap system I heard that you have to remove passenger seat to get to bank 2 sensor 2 o2 sensor? Yup the bearings need to be replaced thanks!
Sedandan is offline
post #8 of 13 (permalink) Old 01-05-2012, 06:31 AM
Quoted: 18 Post(s)
No problem, yea the O2 sensors are easy to replace. The passenger seat comes out with 4 14mm bolts and 2 electrical clips under the seat then you just pull it out. The wire should be under the carpet through the air vent. GL
Tip: when I got my front bearings from auto zone I had to also get a seal (dont know if the rear needs one) and it didnt fit. I had to get the seal directly from the dealer and I also had to take my spindle to a shop to have them press the bearing out and the new ones in for about $20 a spindle.
post #9 of 13 (permalink) Old 01-05-2012, 06:48 AM
Just wanted to make note, if you loosen up the front seat to access the O2 sensor wiring, make sure to disconnect the battery before disconnecting the wire harnesses because one of them is for the squibs and your air bag could go off if you simply disconnect it. Also, it's easy to loosen up the seat but you really don't have to. Just move the seat all the way forward and raise the seat the highest it will go. Then remove the small duct piece for the a/c handling and use the old sensor's wiring to fish in the new harness. Just throwing another way of replacing it.
post #10 of 13 (permalink) Old 01-10-2012, 12:54 AM Thread Starter
THANKS! for advice fellas exactly what I was looking for. Can you imagine your airbag going off? That would suck
Sedandan is offline
post #11 of 13 (permalink) Old 01-20-2012, 12:55 AM Thread Starter
I got the o2 sensor problem out of the way. Now I got to deal with "p0440" what a headache...
Sedandan is offline
post #12 of 13 (permalink) Old 01-26-2012, 03:11 AM
for the evap, try replacing your gas cap first
`02 BO IS300 5MT
SRT Intake w/ Race Ecu / Xerd Race Pipe / APEXi N1 Catback / STANCE GR+ Coilovers / TRD Yellow F&R sways / Cusco front subframe brace / Cusco front under brace / Cusco rear under brace / Figs Clutch Dampener Delete / VIS Vertex + AIT TRD / Work Emotion CR Kai / Hankook Ventus v12 Evo / SPC F&R Camber Kit / PLP Short Shifter
xapexi is offline
post #13 of 13 (permalink) Old 01-26-2012, 04:02 AM Thread Starter
Yeah I'll try that but I have a feeling that it's not the as cap, I have the worst luck lol
Sedandan is offline
  Lexus IS Forum > Regional Forums / All Together Now > California
My B-day is coming up..... acumenhokie Mid-Atlantic 3 09-21-2005 11:33 AM
(Need help) Thump noise coming out when getting in the car or coming out Jis300 General Discussion 1 11-09-2004 02:26 PM
is400 coming? manual trans coming? justin singh General Discussion 4 08-04-2000 02:27 AM
