Anybody have a is300 turbo in the LA area?????? - Page 2 - Lexus IS Forum
post #16 of 18 (permalink) Old 01-24-2014, 05:38 AM
Originally Posted by hdiego06 View Post
Are you running on stock ecu and fuel pump?
no stock fuel pump I got a DW200 from TokenSolutions and also 420 cc injectors and aftermarket fuel regulator
BC 264 Cams / Titan cam gear /AAC Halos /TRD lip kit /Megan camber kit /FIGS rear lower arms/ Fortune coil overs/ fog mod/ joe-z intake/ 19" PIAA SUPER ROZZAS/
lexguy300 is offline
post #17 of 18 (permalink) Old 01-29-2014, 02:37 PM
Originally Posted by BlackSportD View Post
I tuned that car, that kit, with an EMU, 330cc injectors, walbro 255lph. I have to say, it ran strong, fuel trims and air fuels pretty solid. His 330cc ran out of steam, hit 100% duty cycle during the tune. Wastegate spring was 8psi, but we say boost creep (or spikes) into 10psi, so maybe the wastegate needs some refinement, or its the spring.
Typically, the BOV placement where it is at, causing major MAF metering issues, but the CXracing BOV kept things in check, but one should note when changing to another brand name BOV, it will be cracked open in low load/vacuum and will most likely need to be moved further upstream to avoid low load tuning issues.
The kit as-is, ran strong, surprisingly strong. I run 9psi OE compression and this test car was running 8psi and I was super surprised, it was fast, smooth and hauling ass. Had some break-up that IMO is due to the OE spark plugs at over .045 gap. Get some colder .035 plugs and your good to go.
the TS EMU PNP harness addressed the o2 sensor configuration, tuned in some safeties with the EMU IAT and coolant temp maps, timing map and calibrated the MAF clamp. Once he upgrades the injectors, he has the head room to make more power with upgrades like internals.
Blacksport, how much power did it made? Is it a M/T or eshift?
I plan on running 7psi on a comp ct4-6065, which is closer to the gt30 though
Do you have any fitment issue with the IC and exhaust/downpipe kit?
IS503 is offline
post #18 of 18 (permalink) Old 01-29-2014, 06:51 PM
Quoted: 26 Post(s)
It was not on a dyno, but street tuning. It felt strong, surprised at his OE clutch (M/T).
Fitment? You mean his setup? I did not install it but it is supposed to be pretty bolt on. Looks like the typical hole needs to be drilled for the charge piping behind the passenger light, thats about it. Me personally, I'd move the BOV to behind the passenger fog light so I can change brands if I want to (other brand BOVs might be cracked upon in vacuum and cause a MAF metering issue with how they have it placed) and recirc the wastegate. But thats just me.
BlackSportD is offline
  Lexus IS Forum > Regional Forums / All Together Now > California
is300 turbo install/tune (Orlando, FL area) Engis300 South 3 04-01-2007 04:07 PM
NY area - anyone with a turbo on their IS300? dongnong North-East 17 08-24-2006 10:03 AM
Where in Bay Area to get s/c or turbo kits for IS300? rlee926 Go Fast Stuff 12 07-30-2003 05:35 PM
bay area turbo ed is300 engine failure.... Benign General Discussion 10 02-03-2003 02:09 PM
