Longer studs - Lexus IS Forum
 3Likes
  • 1 Post By mesooohoppy
  • 1 Post By TobiasSing
  • 1 Post By nismofan240
post #1 of 12 (permalink) Old 04-15-2019, 10:51 PM Thread Starter
Longer studs
Just got some new wheels and had to add spaces, now looking to add longer studs. Any help?
YoungNino is offline
post #2 of 12 (permalink) Old 04-16-2019, 08:06 AM
Quoted: 18 Post(s)
might want to give some more info. Do you need a DIY or advice?
2004 Absolutely Red 5 speed
nismofan240 is offline
post #3 of 12 (permalink) Old 04-16-2019, 08:52 AM
Quoted: 140 Post(s)
https://www.google.com/ has some
Piggity is offline
post #4 of 12 (permalink) Old 04-16-2019, 09:25 AM
Quoted: 55 Post(s)
ARP is the way to go. The part number you need is ARP 100-7715
However, if you don't shorten them, they'll be WAY too long. also, the rear brake drums will need to be disassembled to finagle the longer studs into the rear hubs...
Hodgdon Extreme is online now
post #5 of 12 (permalink) Old 04-16-2019, 10:29 AM
Quoted: 221 Post(s)
you will also need open ended lug nuts. ARP studs are long.
Hodgdon Extreme likes this.
Lucy; 04 manual sportdesign
mesooohoppy is offline
post #6 of 12 (permalink) Old 04-16-2019, 11:33 AM
Quoted: 55 Post(s)
True that.
Unless you shorten the wheel studs to precisely the required length to accommodate the wheels/spacers/lugnuts chosen.
I chose these lugnuts. They're light, strong, and pretty!
https://store.katechengines.com/tita...15mm-p490.aspx
post #7 of 12 (permalink) Old 04-16-2019, 02:25 PM
Quoted: 582 Post(s)
Sounds like you got the wrong wheels.
juicij36 likes this.
post #8 of 12 (permalink) Old 04-16-2019, 03:08 PM
Quoted: 55 Post(s)
That wasn't my default assumption. Unfortunately, it's rare for wheel offset, sizing, style, price-point and availability to all coincide simultaneously.
Sometimes tradeoffs must be made. Wheel spacers aren't "bad" as a rule, especially when they're limited to ~1/2" thick. I would definitely recommend avoiding the style that bolt to the hub, and have the wheel bolted to the spacer. Those are terrible.
post #9 of 12 (permalink) Old 04-16-2019, 07:11 PM
Quoted: 582 Post(s)
The problem I have with the thin spacers with extended studs is you loose the lip of the inside center bore bit that holds the wheels in place concentrically. t least with the bolt-on type, you can get them with the inner lip. Even just 5 mm means 5 mm less holding the wheel in place concentrically. IDK. I guess I don't like making compromises on things when it comes to safety. Not saying I never have, just that I learned the hard/expensive way lol.
That said, I'd love to see what ultra rare wheels these are lol
post #10 of 12 (permalink) Old 04-17-2019, 09:34 AM
Quoted: 55 Post(s)
Hubrings might be effective when dealing with flat-bottomed lugnuts (OEM on our IS300), but hubrings are certainly not able to hold/maintain concentricity when used in an application that uses tapered seat conical lug nuts.
If there is non-concentricity in the relationship between the wheel bearing and the wheel-stud bolt circle, OR non-concentricity between the wheel outer diameter and the wheel's bolt circle, do you think a crappy little plastic or aluminum ring (that easily slips over the lip on the hub) is going to solve this?
To do so, they'd need to resist the force of 5 conical lugnuts trying to center themselves in a tapered bore, as they are torqued to ~100lbft. Ain't happening.
post #11 of 12 (permalink) Old 04-18-2019, 12:36 AM
Quoted: 18 Post(s)
who needs school when you can learn all the big words here!
Piggity likes this.
post #12 of 12 (permalink) Old 04-18-2019, 09:43 AM
Quoted: 221 Post(s)
as someone who has never used hubrings on my car and never had a problem, this is what ive always assumed is going on. i can watch the wheel center itself when im tightening all of the lug nuts in the proper sequence. the 60 degree seat (multiplied by 5 in a circle), acts as a concentric aligning tool. of course, buying quality products (arp studs, rays wheels, etc) probably helps a lot in the end.
im always checking my tire pressures (stretched tires...) and ensuring my lug nuts are always tight. i think this also helps me.
Extended Wheel Studs? Sniper512 Wheels and Tires 3 01-10-2019 02:02 PM
When is a caliper no longer rebuildable? trancend Basic Help & Repair 2 09-26-2018 08:09 PM
E-shift No Longer Functioning :confused: Touge2jz Go Faster 9 02-07-2017 04:27 PM
