HID Bulbs for the 350 - Lexus IS Forum
post #1 of 12 (permalink) Old 06-03-2006, 12:22 PM Thread Starter
Last thing I heard, the stock HID's on the 350 only run at sumthing like 5800k, which to me is crap. I heard that the HID bulbs in the 350 are a special one (D4S or sumthing?) and there havent been any aftermarket bulbs made. Is that correct? If anyone knows where I can pick up some higher temp. bulbs (if they make them yet) that will fit my 350, let me know. thanx.
~Im Solo_Stage's Favorite White Guy~
'06 Black/Black IS350
19'' Volk GT-S Titanium Gunmetal
StopTech Big Brake Kit
Tein SS Coilovers
HKS Hi-Power Exhaust
K&N Typhoon Intake
8000K HIDs
2-10'' Kicker CVR's
Memphis Audio 1000 Watt Monoblock
Dual Vizualogic 7'' Headrest Monitors
Parts Coming In: INGS Full Body Kit, JDM Blitz Grille, LMS Front Strut Bar
Also: Paint N' Place Custom Paint Job (after all parts come in and are installed)
Thetrinityhk is offline
post #2 of 12 (permalink) Old 06-03-2006, 09:47 PM
There are HID bulbs for the IS350 out and many people on this forums have installed them. Do you have stock HID lights or are you looking to upgrade.
2006 IS350
mmmm is offline
post #3 of 12 (permalink) Old 06-04-2006, 02:27 AM Thread Starter
I have the stock HIDs but im lookin to upgrade the bulb....any info?
Tein SS Coilovers
K&N Typhoon Intake
8000K HIDs
2-10'' Kicker CVR's
post #4 of 12 (permalink) Old 06-04-2006, 02:52 AM
Your bulbs are D4S which are mercury free bulbs...stock D4S bulbs are 4800K bulbs...correct me if im wrong...are almost 5000K bulbs...which should give you a decent output of light. If you go above 6000K your light output will be negligible, but if you want to go with the aqua blue look go with 8000K, anything above 8000K will be purple....
P.S. Excuse me if im wrong...typing in almost in a drunken stage...
06 Glacier Frost Mica IS 350 Sterling Interior
13.888 @ 100.16MPH
PICS
- MTEC 6000K HIDs
- LMS Intake
- Ground Fusion Grounding Kit
AzNrAcEr is offline
post #5 of 12 (permalink) Old 06-04-2006, 04:24 AM Thread Starter
Are there any D4S aftermarket bulbs yet? Im lookin to get sum at 7000k to match my fogs
Tein SS Coilovers
K&N Typhoon Intake
8000K HIDs
2-10'' Kicker CVR's
post #6 of 12 (permalink) Old 06-10-2006, 12:03 PM
if you want crappy output then get higher temp. THe only thing u get out of higher temp is the blue color.
TT061880 is offline
post #7 of 12 (permalink) Old 12-25-2007, 05:55 PM
phil9892 is offline
post #8 of 12 (permalink) Old 12-26-2007, 08:19 AM
Cone Killer
Correct....and the reason they are that temperature (NOT LIGHT OUTPUT) is because that is the temperature that most resembles the light temperature of the sun.
The higher the temperature, the bluer it the light gets. The only drawback is that now you see less given the same light output (35watts).
I went with a slighter bluer tone, 6K with my aftermarket kit, because I wanted just a bit more blueish light.
I know there are higher wattage HID bulbs, I think 55 watt units, but I am not sure if the ballasts can handle them.
https://my.is/forums/showthread.php?t=265815
METEORO is offline
post #9 of 12 (permalink) Old 12-26-2007, 11:58 AM
Way to bump a thread from the dead, but the above information is both right and wrong...
It is true that stock ISx50 HID bulbs are Phillips D4S mercury free bulbs with a color temperature 4800K, but the light output, measured in lumens, is greater than that of a Phillips 4150-4300K D2S by 600 lumens (i.e., 3800 lumens vs. 3200 lumens).
While color temperate of a D4S bulb is approaching that of sunlight, it actually puts out more lumens than its D2S counterpart. Because of that, you cannot think in terms of D2S vs D4S. Not only does light output differ but voltage voltage requirements are not the same. A standard D2S bulb operates at 35W @ 85V while a D4S bulb operates at 35W @ 42V.
The misnomer that as the color output increases, lumens decrease is essentially true, but D4 based HID lighting is an attempt to overcome electronic limitations of man-made lighting. Man is not able to produce the full spectrum of light as we increase color temperature, and instead of a broad graph of the entire visible spectrum of light, we get short peaks of light through the visible spectrum, which is what contributes to the loss of lumens as you go up the Kelvin scale.
As a side note, 50+ watt HID's are a whole other entity that I covered in the following thread and to the best of my knowledge, NO ONE has toyed with such setups utilizing anything other than D2 bulbs and the Phillips MPXL-DL50 designed for high wattage use.
BlackTi is offline
post #10 of 12 (permalink) Old 01-15-2008, 01:25 PM
swamp them out 8000k is the way to go
jdmtezza is offline
post #11 of 12 (permalink) Old 03-17-2008, 10:01 AM
I installed 8000k's HIDs from AAC in my 08 is350 and they gave me a purple output, but on the other hand my 8000k fogs are light blue the way i want them. Why dont they match? Anyone else have the same problem?
08 ~ SGM IS350 ~ Sports Pkg ~ Navigation ~ Many Mods In Progress!
L-Tuned300 is offline
post #12 of 12 (permalink) Old 09-14-2009, 03:38 PM
That's what I did
Car Brakes Rotors
bimmer4life2009 is offline
