Is 14.3 MPG bad for a 2007 IS350? - Lexus IS Forum
post #1 of 28 (permalink) Old 11-08-2010, 09:20 PM Thread Starter
I just got a used 2007 Lexus IS350 last month as my first car. After driving it to school for about a few weeks, I realized I only get 14.3 MPG and had to refill 3 times already. Is it normal for the IS350? I drive about 25 miles a day, 10 being on the highway. Is there anything I can do to increase gas mileage? Thanks!
chi123 is offline
post #2 of 28 (permalink) Old 11-08-2010, 09:26 PM
Jedi Knight
Tigger's Avatar
Yes, relax on the gas pedal speedracer.
2003 Lexus IS300 - Graphite Gray Pearl 5MT (sold)
2010 Lexus RX350 - Starfire Pearl
2014 Mercedes-Benz E350 Sports - Polar White
2015 Toyota Sienna Swagger Wagon - Super White
Tigger is offline
post #3 of 28 (permalink) Old 11-08-2010, 09:43 PM
This. I get around that in my IS300 in SF (Hills, hills, hills).
GenEric587 is offline
post #4 of 28 (permalink) Old 11-08-2010, 11:45 PM
That sucks for an IS 350. Now I don't feel so bad for getting 21 mpg on my IS 300.
Are you keeping up with the scheduled maintenance?
baylisstic is offline
post #5 of 28 (permalink) Old 11-08-2010, 11:45 PM
Geezer
bartkat's Avatar
I got 28 mpg on my trip to the smokies including lots of mountain driving.
MOLON LABE
bartkat is offline
post #6 of 28 (permalink) Old 11-09-2010, 06:39 AM
Yeah... me too... (same trip even, to the smokies!).
I routinely get 27-29 mpg on highway trips and 21-23 in city driving.
14.3 is awful
Like, there's something wrong with the car awful. (assuming you're not constantly flooring the gas/slamming the brake 100% of the time)
First cheapest/easiest things to check are the air filter and tire inflation. If it was never changed and is badly clogged then changing it would greatly improve mileage... also check your tires are properly inflated (though your mileage problem is bigger than I'd expect just underinflated tires to cause)
Checking/cleaning your MAF would be another thing, this is slightly less easy than the two above, but is mostly free (couple bucks for cleaner).
Beyond that- how many miles on the car? Spark plugs are called to be changed at 60k miles, and bad plugs will certainly kill mileage too... Do the other things first though as they're cheap and easy, changing your plugs are considerably less so. Ditto the front O2 sensors, a bad one will hurt mileage a lot, but it's not cheap to replace (though you're probably still under warranty there, and a bad one OUGHT to throw a CEL)
Knightshade is offline
post #7 of 28 (permalink) Old 11-09-2010, 07:43 AM
14.3 is awful
Any chance it could be a defective ECU?
When mine went on my car, I noticed that mileage went down the tank (although that car had so many issues, tough to use it as an example).
I average right around 22mpg. Most of my driving is city. If I do drive for extended periods on the highway I can get 28.
2008 IS350 Starfire Pearl
JoeZ Intake & K&N Air Filter
Razal is offline
post #8 of 28 (permalink) Old 11-09-2010, 11:01 AM
It's possible, but as you note there'd likely be more issues than just poor mileage from that (and it's a bit tougher for someone without a spare, known good, ECU to diagnose than a lot of the other more likely possibilities I mention)
post #9 of 28 (permalink) Old 11-09-2010, 10:15 PM Thread Starter
14.3 is awful
I brought the car with 49,310 miles on it for $20,300. In the month I had it, put like 500 miles on it. When I went to replace the air filter, I found a clean air filter inside, same thing with the engine oil, fresh oil was inside. I just replaced the differential fluid and had the dealer flush out the brake fluid and coolant so it's updated with maintenance. I'll probably get the spark plugs replaced before winter comes in. About the tire pressure, it's at 33 psi on the front and 34 psi on the rear, that's a normal drop I guess since it's like 40 degrees outside now in the mornings.
Also, I don't accelerate hard or brake, only at like 3000 rpm at most. You think if I brought it to the dealers, they can diagnose what's up with the bad gas mileage?
chi123 is offline
post #10 of 28 (permalink) Old 11-10-2010, 06:30 AM
They SHOULD, but it depends on the dealer really... some will just shrug and say "No warning lights, no noises, so it's fine" and some will actually try and help you.
Worth a shot though if they're willing... do it quick though as unless you bought an extended one you're just about out of warranty (50k miles) on anything besides powertrain.
I'd probably put a bit more air in those tires, but that's not nearly enough of an issue to cause that kinda mileage hit.
post #11 of 28 (permalink) Old 11-11-2010, 12:58 AM
These cars are six cylinders expect to pay more for gas .
SuperTerrificHappyCarBlog!
Amoeba Culture is offline
post #12 of 28 (permalink) Old 11-11-2010, 07:30 AM
Huh????
Razal is offline
post #13 of 28 (permalink) Old 11-11-2010, 08:18 AM
Geezer
bartkat's Avatar
I don't see the point here. If most people are getting in the mid to high twenties mpg, and this guy is getting 14 mpg from a similar car, then he's definitely got a problem.
MOLON LABE
bartkat is offline
post #14 of 28 (permalink) Old 11-12-2010, 05:58 PM Thread Starter
Well, I went to the dealer today. They had one of their best troubleshooting mechanics check it out but an hour and half later, he said the car is in perfect condition and there were no problems at all! Then the service advisor simply said to use better gas from Shell or BP that burns more slowly than others like Citgo or Marathon, which was what I was using. He also recommended next time I come back to have the fuel injectors cleaned and the fuel filter replaced.
chi123 is offline
post #15 of 28 (permalink) Old 11-13-2010, 01:28 AM
thats pretty bad for highway and city. maybe lots of uphill driving and or lead foot? i get no less the 16 all city and on occation i have urges to rev pass 4000 rpm. i think you should look into possible mantenience such as air filter, gas tank treatment and seafoam.
Starfire Peal IS350 NAV
GGP 2k2 IS300-GONE
sw2oboi is offline
What about IS Engineering=Bad MPG? Humility General Discussion 49 09-24-2008 06:41 PM
new is bad mpg Griz Basic Help & Repair 17 05-12-2005 11:40 AM
SAFC and bad MPG _DAG_ Go Fast Stuff 13 04-24-2005 04:15 PM
How bad does header drop MPG? jzak423 Go Fast Stuff 12 11-08-2003 10:09 AM
why does the IS get such bad MPG? moop General Discussion 14 06-21-2002 04:05 PM
