Worst gas mileage ever - Lexus IS Forum
post #1 of 20 (permalink) Old 12-21-2018, 04:03 PM Thread Starter
I'm getting 170 to 190 miles per tank, no CEL. Runs strong..just cant seem to figure it out. 01 is300 automatic with 133,000 miles. Timing belt done recently along with new water pump, new head gasket along with resurfaced head..all other seals were done at this time also. It's not leaking oil or low on coolant cuz I've been checking it every few days. So confused, also has new spark plugs and wires. Any idea what to check next? Just replaced vvt solenoid and pcv valve also
ZBee is offline
post #2 of 20 (permalink) Old 12-21-2018, 10:37 PM
Quoted: 32 Post(s)
Have you checked the injectors? Seems like the next logical step, when I replaced mine, the o-ring seals have to seat just right for no leaks
DH_71631 is offline
post #3 of 20 (permalink) Old 12-22-2018, 10:44 AM Thread Starter
I haven't checked the injectors yet I'll have to when I get some free time to work on it , was thinking about seafoaming it through the pcv hose to see if the gas mileage improves at all. Maybe some in the gas tank also..
ZBee is offline
post #4 of 20 (permalink) Old 12-22-2018, 01:36 PM
Quoted: 605 Post(s)
well, those numbers don't tell us what the actual MPG is. Has it always been like this? Or just recently worse? MPG does go down in the winter because of the fuel additives, depending on location
post #5 of 20 (permalink) Old 12-22-2018, 06:49 PM Thread Starter
Per gallon I'm getting about 10.5 to 11 miles or so. It has been like this since I've got it 2 months ago. It runs solid as a rock and hasn't given me any issues besides this gas mileage. I'm in California and only use Chevron 91 premium gasoline
ZBee is offline
post #6 of 20 (permalink) Old 12-23-2018, 03:47 AM
Quoted: 14 Post(s)
I average 20 to 24 mpg in my '05 5 spd car. It depends a lot on how I drive it.
Check your air filter and while its apart, clean the MAF sensor with the correct cleaner.
Jaysz28 is offline
post #7 of 20 (permalink) Old 12-23-2018, 02:08 PM
Quoted: 364 Post(s)
It may be the way you are driving. The few I have dealt with. Only get that bad when I real pound on the accelerator.
post #8 of 20 (permalink) Old 12-23-2018, 02:21 PM Thread Starter
I cleaned the MAF but I used electronic cleaner and also cleaned the K&N air filter with k&n cleaner and lightly reoiled it after . I will fill up and try to drive it as light as possible as I do have a heavy foot and see what the difference might be there.
ZBee is offline
post #9 of 20 (permalink) Old 12-23-2018, 02:28 PM
Quoted: 605 Post(s)
is there any leaking fluid under the car? ANy smells during or after driving? Black build up over the muffler tip? Engine clean ?
post #10 of 20 (permalink) Old 12-23-2018, 05:09 PM Thread Starter
No fluids leaking or dripping at all I've been looking daily. Once in a while I smell gas but it's usually at 5 am when I warm it up for work and its 47 degrees outside. The inside of muffler tip is black but nothing out of the ordinary looking for the year of the car
ZBee is offline
post #11 of 20 (permalink) Old 12-23-2018, 05:49 PM
Quoted: 32 Post(s)
So if you pull the spark plugs, you can look at the tips and if they're gunked with carbon, odds are you're running extremely rich, which could be tied to a bad o2 sensor. If it's not the injectors I mentioned earlier
DH_71631 is offline
post #12 of 20 (permalink) Old 12-23-2018, 06:44 PM
Quoted: 605 Post(s)
if it was running extremely rich, that's why I'd look for the black buildup above the exhaust, but it's not there. It would also make CELs eventually, which he doesn't have. If it was running extremely rich, wouldn't it be obvious?
post #13 of 20 (permalink) Old 12-23-2018, 10:12 PM
Quoted: 32 Post(s)
I suppose it would, my CEL bulb was actually removed before I bought my car so there's an chance he's in the same position. I just can't imagine getting half the economy without the ECU seeing something wrong.
DH_71631 is offline
post #14 of 20 (permalink) Old 12-23-2018, 11:43 PM
Quoted: 132 Post(s)
Was the cam belt and other work done before you got it?
Could also be possibly the belt is out a tooth, it may or may not run right with a tooth out depending on how its out, but may not be making power like it should and so you are gassing it more than it should be. If you hadnt driven it before or haven't driven another IS then you may not have noticed.
I would pull the battery for a minute or so to reset the ECU and then give it a try. It might set everything right after cleaning the MAF and other work, or it might throw a CEL if something is wrong and it finally tell you whats going on. I would also get the CEL's read properly, dont wait for the light as it often only lights up on critical items, but might overlook something else.
2001 Altezza Gita JCE10
Pnut00 is offline
post #15 of 20 (permalink) Old 12-24-2018, 02:08 PM
Quoted: 605 Post(s)
Yeah, make sure the CEL is actually coming on when you first start the car for the first couple of seconds
2001 IS300 p0440 code terrible gas mileage ZBee Basic Help & Repair 2 12-06-2018 06:40 AM
2001 gas mileage reporting. Dsthez General Discussion 6 06-15-2018 11:02 PM
Gas Mileage per Fill Up F/I Touge2jz Go Faster 19 04-27-2018 02:47 PM
2016 IS300 - Terrible Gas Mileage?? Ashymow General Discussion 5 08-10-2016 01:24 AM
