When is a caliper no longer rebuildable? - Lexus IS Forum
post #1 of 3 (permalink) Old 09-25-2018, 07:40 PM Thread Starter
I'm considering rebuilding oem rear calipers which (should) have 100k on them.
However, there is a measurable amount of rust, and after removing it (sand blasting) I'm not sure if the dimensions will change enough to effect the pad "glide slots" (or whatever they're called) and pad spring tension. That is, will it be possible for the pads to have too much play from the widening of the glide slots and the spring lip (I suppose the spring could be bent to compensate)?
Thanks.
trancend is offline
post #2 of 3 (permalink) Old 09-26-2018, 09:35 AM
Quoted: 230 Post(s)
hot damn those are rusty. do you have an after pic?
Lucy; 04 manual sportdesign
mesooohoppy is online now
post #3 of 3 (permalink) Old 09-26-2018, 08:09 PM Thread Starter
I don't want to attempt to restore them until I determine if there is going to be any issues with all the lost surface area (like with pad glides or spring clip being too loose). Rebuild kits are almost free compared to the cost of replacements, so am seriously considering. I've used a sand blaster before, it's just care must be taken to not get sand where it shouldn't be, like in the piston ports.
trancend is offline
Budget big brakes for IS300 - IS350 front calipers/rotors/pads Steve Theodore Stop, Drop and Roll 228 06-04-2019 12:02 PM
Caliper bolt broke off, NEW caliper brackets wont fit?? 01 IS300 Nocturnal2J Basic Help & Repair 7 09-08-2018 09:36 PM
Rear brake caliper help Dram General Discussion 1 10-24-2017 02:16 PM
Frozen Caliper or Bad Bearings? PoR2GeEzIS300 General Discussion 7 11-04-2016 02:34 PM
is300 Caliper Megagwar General Discussion 3 05-24-2016 11:36 PM
