Weird problem! Canít figure it out! - Lexus IS Forum
post #1 of 10 (permalink) Old 12-29-2017, 02:34 AM Thread Starter
Quoted: 20 Post(s)
My ABS light is on, trac OFF flashing and BRAKE is on. You might be thinking ďanother speed sensor problemĒ but I donít know! I went to my mechanic he hooked up his fancy snap on scanner and my car had NO ABS FAULT CODES. I donít know what the hell is going on. It had a fault code on the airbag because my airbag light is on but idk what airbag is causing that issue. Yes i know it mightíve been stupid on my part to not check what airbag is causing that problem but whatever.. my question is do you think my airbag fault code is what is tripping my other lights to go off? At this point I donít know what else to think lol my fluids are all good, the fuse is fine.. Iím stumped yíall help a brother out.
Mostdope2jz is offline
post #2 of 10 (permalink) Old 12-30-2017, 06:58 PM Thread Starter
Quoted: 20 Post(s)
Bump..
post #3 of 10 (permalink) Old 12-30-2017, 11:54 PM
Low voltage? Check the battery.
Sent from my LG-H915 using Tapatalk
CameronR is offline
post #4 of 10 (permalink) Old 12-31-2017, 01:02 PM
Quoted: 595 Post(s)
well ok so there are some dash lights, but what about the performance of the car? How is it running? Everything normal , or what? maybe just an ECU reset would get rid of the lights if everything is fine, and if they come back, then you do have a more real problem
TobiasSing is online now
post #5 of 10 (permalink) Old 12-31-2017, 02:16 PM
Quoted: 125 Post(s)
Great, but did he check for anything else? Any other codes anywhere else? Did he do any other diagnostics?
If the lights are flashing i would be surprised if there isn't a code throwing somewhere, but if you are only looking at the ABS you wont always see it.
It could be my OCD but personally i would be fixing the airbag fault to get that possibility out of my head. Flashing lights on the dash could be anything from a faulty sensor to electrical short to ECU/module. You need to start working through the problems you can see and fix and go from there.
2001 Altezza Gita JCE10
Pnut00 is offline
post #6 of 10 (permalink) Old 01-01-2018, 09:05 PM
I would look into the red brake light first. Go back to you friend with the scanner. On the way pull the e brake handle up while on throttle. It should chime a warning. If no chime check switch for hand brake.
Unplug Brake fluid level sensor If it does not code for that change the abs module. If it does change the sensor if fluid level is correct.
quicksilver31 is offline
post #7 of 10 (permalink) Old 01-03-2018, 03:03 PM Thread Starter
Quoted: 20 Post(s)
To all above posts.. my cars performance is normal.. nothing weird going on besides the obvious like no traction control.
We ran a full diagnostic, we had no codes besides my compressor being messed up and the airbag code.
Yes when I pull the ebrake up it chimes, no my brake fluid is not low. I will add that my ebrake is kinda wasted i guess you could say. It brakes a very SMALL amount. If you pull up the ebrake while your moving you will feel It trying to slow ur car down but it canít really do much.. can this be a reason for a abs light?
post #8 of 10 (permalink) Old 01-04-2018, 08:30 PM
You test e brake function by holding the brake pedal down while stopped then pulling hand brake lever up release foot brake. The car should resist being moved.
If the fluid level sensor is faulty It does not matter if the level is correct of not. That is why I suggested unplugging it and useing a scanner to see if it codes for level sensor circuit. Or just try replacing that sensor.
post #9 of 10 (permalink) Old 01-07-2018, 06:21 AM Thread Starter
Quoted: 20 Post(s)
Yes it resists being moved.. and ok I will unplug the sensor and see if it throws a code Iíll get back to you guys !
post #10 of 10 (permalink) Old 02-05-2018, 09:36 AM
Have you figured out what is causing the problem with your lights being on, on your dash? I'm having the same exact problem with the same lights on and no performance issue at all and e-brake works just fine and also I don't have any airbag fault codes. Thanks
irishawn is offline
IS300 SC problem with cranking wiciu_p89 Basic Help & Repair 0 09-21-2017 09:18 AM
Right Turn Signal Problem. Video of the problem included. Shobster Basic Help & Repair 2 03-27-2017 08:10 AM
Wheels and tires... the debate problem and headache 04bluIS300 Wheels and Tires 9 04-26-2016 08:09 AM
No power, no acceleration, sputtering, 2 new motors, same problem Cmoore002 General Discussion 2 03-10-2016 03:59 PM
Weird problem with the vvti gear after bc 264 cams joelpr1234 Go Faster 7 01-28-2016 08:05 PM
