Trunk leaking inside from rain(HELP!!) - Lexus IS Forum
post #1 of 9 (permalink) Old 03-06-2019, 12:13 PM Thread Starter
Hello, need help....I own an 04 IS300 and I noticed on the left side of the trunk, there is dripping water after the rain....I read thru some posts with similar problems and tried applying silicon to the left side where the gasket meets the metal, checked the rubber seals, etc....NOTHING HAS WORKED......here is a pic of what it looks like after rain(or a car wash).
It’s inside the trunk, NOT underneath the side covers so I don’t suspect it’s the sunroof drains(right?).....and it’s a dripping type of leak.
ANY HELP WOULD BE APPRECIATED!! Thanks!!!
Lexus-Russ is offline
post #2 of 9 (permalink) Old 03-06-2019, 12:34 PM Thread Starter
Sorry here is the pic
post #3 of 9 (permalink) Old 03-06-2019, 01:43 PM
Quoted: 321 Post(s)
Are you sure it is the truck seal? If memory serves me. There is a drain that comes down from the sunroof also.
post #4 of 9 (permalink) Old 03-06-2019, 02:28 PM
Quoted: 582 Post(s)
Mine does literally the same thing, ever has since I crashed it into a concrete wall many years ago. But only when the car is inclined sloped forward. I figured I just busted a seam or something, but I have never for my life been able to find the leak. I've tried all sorts of things, including spraying "great stuff" expanding foam in there. Granted, the leak is very small. But I just accepted it, since it's just the trunk
TobiasSing is online now
post #5 of 9 (permalink) Old 03-06-2019, 02:56 PM Thread Starter
Can’t say for sure but if it was the the drain would it be leaking on the carpet?
post #6 of 9 (permalink) Old 03-07-2019, 05:49 AM
Quoted: 321 Post(s)
Originally Posted by Lexus-Russ View Post
Canít say for sure but if it was the the drain would it be leaking on the carpet?
I was thinking of it leaking down from above and dripping off the body panel. TobiasSing brings up a good point. Has it been in a wreck before?
post #7 of 9 (permalink) Old 03-13-2019, 05:49 PM
Tighten down your bolts for the rear spoiler if you have one. It will require removing the trunk cover and using a 10mm long socket 4 bolts. As the gaskets wears and the car ages and rattles these screws loosen over time. Its worth a try and easy fix if it solves it Good Luck
American Complex, cock it and pull it
Str8 Six is offline
post #8 of 9 (permalink) Old 03-20-2019, 05:09 PM
Did you find the problem
Str8 Six is offline
post #9 of 9 (permalink) Old 04-22-2019, 01:24 PM
I have this same problem, same side... I'm going to try and tighten up the spoiler bolts when I get home. I cleaned the drains out pretty well already. Mine will get wet in the lower area closer to the wheel... I ended up just popping the rubber piece out to let it drain and stop the rust buildup.
Mine is a salvage vehicle and was in a wreck in the rear end before, so that could be my issue.
Skryblz is offline
Water Inside Trunk? IS300GEAHEAD General Discussion 6 09-30-2018 02:07 PM
Need help removing the exterior trim piece on the trunk. TinaBobina Basic Help & Repair 4 08-02-2018 10:08 PM
Cam Seal Leaking or VVTi Gear? Stanri010 General Discussion 6 05-16-2018 06:18 PM
Carbon Fiber Trunk Installed IS5043 General Discussion 5 10-25-2016 01:42 PM
Water leaking into trunk? aluminum_welder General Discussion 21 02-25-2016 07:44 AM
