Is There A DIY for Replacing Valve Cover Gasket? - Page 3 - Lexus IS Forum
post #31 of 44 (permalink) Old 12-22-2012, 12:51 PM
So the car won the battle today - wasn't feeling well enough to fight with anymore.
I had most of it torn down, but there was one 10mm bolt on the firewall side of the Y intake - it is on the bottom, driver side of the EGR Shift bolt. How do I get to that. The lines/wires it's holding are to short to let me move it much.
-JD
jdnizzle is offline
post #32 of 44 (permalink) Old 12-22-2012, 12:53 PM
A swivel adapter on the socket didn't help? They shouldn't be on there too tight.
post #33 of 44 (permalink) Old 12-22-2012, 01:00 PM
Quoted: 22 Post(s)
Ya that nut is a b*tch. I think its a 12mm nut, not a 10mm bolt if I remember correct. Either way only way I could get in there is with a long thin 12mm ratchet wrench. A socket wrench was too bulky to get in there.
Zachj is offline
post #34 of 44 (permalink) Old 01-27-2013, 03:49 AM
Has anyone used non-Toyota/Lexus valve cover gaskets from an auto parts store? Have you had any issues with the auto parts store gaskets?
2002 IBP 5-speed - Cloth - LSD - Konis
mball19 is offline
post #35 of 44 (permalink) Old 01-27-2013, 04:13 AM
Quoted: 32 Post(s)
OEM is cheap and reliable, why would you consider this option?
Sent from AutoGuide.com App
'03 IS300 SD TCM 5-SPD LSD
tonynca is online now
post #36 of 44 (permalink) Old 01-27-2013, 11:32 AM
Quoted: 22 Post(s)
Would you use a spoon to eat a salad? Comon man just get the correct ones, dont chance it. Got mine at napa auto for like $25.
Zachj is offline
post #37 of 44 (permalink) Old 01-28-2013, 02:56 AM
Did the napa gaskets stop your oil leaks? How long have you had them installed?
mball19 is offline
post #38 of 44 (permalink) Old 01-31-2013, 10:13 AM
I just changed the gasket with a autozone one and work just fine. The dealer did not have it in stock and it was my only day off to do it.. Stopped the leak.
randya44 is offline
post #39 of 44 (permalink) Old 03-10-2013, 09:00 AM
You will have to unbolt the Y flange piece of intake either fully which might be easier or after bolt on Y.
Remember to only tighten to 75 Inch/pounds and dab some silicone on the corners.
(borrowed pic)
post #40 of 44 (permalink) Old 04-27-2013, 12:48 AM
Hey guys, so i just figured out that i need to replace these gaskets too. Ive read most places that its a fairly simple job but after reading all these posts... kinda skeptical.
hospy94 is offline
post #41 of 44 (permalink) Old 04-27-2013, 11:57 PM
i found a link from clublexus Replace Valve Cover Gaskets + Lots More DIY - Club Lexus Forums hope this help
project IS -drop snail- on process %-
Tomotoyo rods, eibach sway bar, koni with df210 springs, tower bar cusco, transmission cooler, poly bushings lca #1/2, hks dli ignition _all dyi thanks to my.is successfully done with run problem
ISfro is offline
post #42 of 44 (permalink) Old 03-24-2014, 01:52 AM
Quoted: 32 Post(s)
Did you guys have to move the wire harness out of the way? I can see that's it's in the way of the valve cover bolts.
post #43 of 44 (permalink) Old 03-24-2014, 03:58 AM
The main engine harness that wraps around the front? No, you don't need to, only disconnect the few sensors on the exhaust side and remove their support clips. Be very careful not to break them because they are very brittle. Basically you take the Y-pipe off from the intake plenum, 4 12mm bolts, 2 10mm nuts, disconnect all the vacuum lines and clips from Y-Pipe and TB, remove the coolant lines to the TB and TB itself(you don't have to fully remove the TB, just move it to to the side. If you don't put a dab of silicone sealant on the front corners of the valve cover where it goes over the cam cap, it will leak there. Put some over the cam seals, the FSM shows the specific locations. Remember to tighten to only 75"/lbs and you'll be good to go. But to help answer your question, make sure to have a 10mm short socket with a swivel or swivel box wrench and you will not have to touch the engine harness. Hope this helps...
post #44 of 44 (permalink) Old 03-27-2014, 12:11 PM
Quoted: 32 Post(s)
Thanks Jason. My main concern was being able to torque the bolts and nuts down with the engine harness in the way. I think I'll be able to move it around a bit a make room.
How to replace valve cover gasket beetz12 General Discussion 26 03-10-2013 06:21 AM
Help: Problems after replacing valve cover beetz12 General Discussion 7 07-04-2009 10:23 AM
Need help with replacing valve cover gasket beetz12 General Discussion 2 06-24-2009 03:19 PM
VVTi GTE Intake Valve Cover Gasket? TeCKis300 Go Faster 5 05-04-2007 12:06 AM
