T-belt change and Cams - what parts am I missing? - Lexus IS Forum
post #1 of 6 (permalink) Old 06-13-2012, 09:39 PM Thread Starter
Timing belt
Tensioner
Idler
Drive Belt (Serp)
Water pump
T/stat
T/stat gasket
PVC (5/2001 and up)
O-ring Bypass pipe
O-ring Bypass Outlet
Valve Cover Gasket (intake side)
Valve Cover Gasket (exhaust side)
Cam Seal x2
Crank Seal (front main)
Spark plug x6
Air Filter
And then of course BC stg 2's and a cam gear.
Anything else you guys can think of that I should order/do while in there?
2002 MSM IS300 - 5MT with LSD
BC 264 // Titan Cam Gear // Eibach Prokit & Bilsteins // Figs CDDD, #1 & #2 LCA bushings
"Trac off" is clearly just Japanese for "Sideways on"
Tire_Marx is offline
post #2 of 6 (permalink) Old 06-14-2012, 04:41 AM
Gallon of concentrated coolant(red).
post #3 of 6 (permalink) Old 06-14-2012, 05:11 AM
Bezik777's Avatar
Quoted: 44 Post(s)
Toyota black gasket sealant
Intake manifold gaskets if you want.
Remember tight side of oem on cams for clearance
Also clean out throttle body
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #4 of 6 (permalink) Old 06-14-2012, 05:23 AM
Good call Tom...
It was mentioned to add a dab of some silicone sealant to the front corners of the valve covers and where it goes over the cam cap. This is to prevent leaks and done as a precautionary, otherwise it will leak.(remember only 75 IN/LBS.).
post #5 of 6 (permalink) Old 06-14-2012, 02:39 PM
Shims to adjust the camshaft clearances.
cline100 is offline
post #6 of 6 (permalink) Old 06-14-2012, 04:38 PM Thread Starter
Have a friend who is a Toyota tech who will do the work. He will supply the coolant. I will ask him about the silicone sealant trick, but I'm gambling that he already does it.
Shims will be based on if I need them, and will be seen during install.
Thanks guys
The teeth on my timing belt are missing rickmassingill Go Faster 7 06-20-2010 09:29 PM
timimng belt kit whats missing? bmwmike Basic Help & Repair 1 10-15-2008 10:11 PM
Missing parts of this turbo kit? citra Go Faster 25 03-25-2008 10:11 PM
parts needed for change timing belt toronto1234 Showroom 4 08-23-2007 07:38 PM
is my dragerII missing parts ISracer300 Go Fast Stuff 1 12-07-2003 01:43 AM
