Removing Rear Axle.. - Page 2 - Lexus IS Forum
post #16 of 23 (permalink) Old 06-01-2010, 02:04 PM
TB_
Part Number 90110-10016
10-1.25P x 53.4-34.7
From the notes on item 42330A HERE
They're not a standard length you can find at a hardware store. I tried 2 hardware stores. Rather than running around town I just ordered them.
2001 IS300 - SOLD
TB_ is offline
post #17 of 23 (permalink) Old 06-01-2010, 02:18 PM
yes u are right, there isnt even a 55mm listed in 1.25 mm pitch
a 60 mm and cut it down, they are 7.51 for 10 plus shipping, so might as well just buy the right part.
2003 Pathfinder SE 4WD
IanH is offline
post #18 of 23 (permalink) Old 06-01-2010, 02:26 PM
TeCKis300's Avatar
Originally Posted by IanH View Post
I found a similar way for broken off bolts, drill into the bolt, off center is ok or maybe even better. increase the size slowly, when you get close to the threads the bolt collapses and you can screw it out with vice grips or a screw driver wedged in there. I DONT use easy-outs anymore, once they break you are buggered.
Fully agreed on the easy-out thing.
Drilling is definitely a legitamate strategy and just depends on the bolt that I'm working with. Use whatever is more appropriate and less likely to damage the part your working with.
Car sold to a good new home!
TeCKis300 is offline
post #19 of 23 (permalink) Old 06-01-2010, 02:31 PM
when i was doing the clutch one of the bolts holding the under-tray at the rear sheared off.
Rusty !!!
drilled it and screwed it out, no damage to the threads !!!
new bolt and all fixed.
IanH is offline
post #20 of 23 (permalink) Old 05-12-2014, 06:55 PM
Quoted: 109 Post(s)
For the record, cutting a slot in the bolt head doesnt always work. I ended up having to cut off the whole head. The threads are seized in the stub of the old differential.
-- Pres. George Washington
Real gun stats will shock you
IM QUIKR is offline
post #21 of 23 (permalink) Old 05-13-2014, 10:30 AM
They do make these amazing things called "bolt-out kits", in it is a reverse drill bit wide tooth, along with a reverse threaded expanding screw head. You drill the center of the bolt, screw it in and the screw tightening in reverse loosens the seized and stripped bolt, then have it that bolt replaced. It's the best and most convenient $25 you will ever spend especially with cars 10+ yrs old.
1986.5 Toyota supra mkiii 1jzgte (sold)
2001 GGP auto NA-T SRT 2.75 ms3pro s366 ~550
2002 MSM 5sp 1JZ VVTi swap underway
Hakujohn is offline
post #22 of 23 (permalink) Old 05-13-2014, 10:38 AM
Yes but be warned when you break an easy-out or similar tool that is hardened tool steel, its very difficult to then drill it out. I had HSS and cobalt drills and got no where. I had to buy a new exhaust manifold.
IanH is offline
post #23 of 23 (permalink) Old 05-13-2014, 05:25 PM
Quoted: 109 Post(s)
I havent met an easy out I can't break. And then you're screwed. Try drilling out a hardened steel bit.
Besides, there just not much room down there to work.
IM QUIKR is offline
Rear passenger side Axle Hub removal LuvMyIs1 IS300 Owner's Forum 7 09-10-2017 12:40 PM
How to replace rear axle? chsamia Stop, Drop and Roll 0 03-20-2008 08:28 AM
Rear Axle djlutchi Stop, Drop and Roll 0 05-28-2007 08:28 AM
Rear axle "klunk" noise with the manual transmission LexusBuckeye General Discussion 10 11-22-2001 11:24 AM
