Please help!!! p0300 - Lexus IS Forum
post #1 of 3 (permalink) Old 01-12-2013, 02:36 PM Thread Starter
I have an 01 is300 stock.... I have the following codes p0300, p0304, p0305, p0306 and bank 2 too rich.... I have replaced plugs and wires with oem and the problem went away for about a 1000 miles and now it's back..... Please help!!!
J_mac01 is offline
post #2 of 3 (permalink) Old 01-12-2013, 03:43 PM
Are you sure all ignition wire connectors are locked into the coil packs? What plugs did you put in?
These are all the causes of DTC P0300..
-open/short in engine wire
-connector connection
-vacuum hose connection
-ignition system(all replaced on yours)
-fuel pressure
-MAF
-engine coolant temp sensor
-compression pressure
-valve clearance
-valve timing
-PVC piping
-ECM
Check the vacuum piping near the driverside firewall and clean your MAF as wellnas throttle body. Then reset your ECU and see if a specific cylinder misfire comes back. I would also verify your other bank isn't running rich, which would narrow it down. You aren't running extremely rich or you'd be throwing P0172/P0175 rich codes.
post #3 of 3 (permalink) Old 05-19-2014, 08:39 PM
555
Hate to bring this from the dead as my first post but i have the exact same codes. What did you find out was the culprit?
555 is offline
Need help diagnosing P0300 - P0303... continued POHRacing Basic Help & Repair 86 08-08-2016 06:52 PM
p0300,p0301,p0302,p0303 marc piety Basic Help & Repair 2 10-04-2014 10:59 PM
P0300 Random Misfire in all cylinders TravisB Basic Help & Repair 3 01-09-2013 04:05 PM
Need Help, IS300 With CEL P0300, tried everythings but still not fix evovic IS300 Owner's Forum 2 11-25-2010 04:08 PM
code p0300 wrxvic Basic Help & Repair 2 01-12-2009 10:35 AM
