Pink Headlight - Lexus IS Forum
post #1 of 12 (permalink) Old 03-13-2014, 10:14 PM Thread Starter
Pink Headlight
Hi, All
I just want to verify that my headlight is going bad
It started turning pink today, passenger side.
Hopefully, it will solve the problem after I change the light bulb.
Otherwise, would this be the ballast problem??
So, there are two possibility here
1. light bulb
2. ballast
I'm thinking about getting OEM one, I found one for $150
Is this reasonable???
yongberg is offline
post #2 of 12 (permalink) Old 03-13-2014, 11:19 PM
Quoted: 9 Post(s)
Sounds about right for legit oem ones. I'm sure yours are done as they're going pink. If you want to be 100% sure, you can always swap your left and right lights to see. BTW, both bulbs are probably done.
My pix whoring thread
Johnnysks is offline
post #3 of 12 (permalink) Old 03-13-2014, 11:22 PM Thread Starter
OK Thanks
Even the left one as well???
Looks okay so far, mine is 02 model.
yongberg is offline
post #4 of 12 (permalink) Old 03-13-2014, 11:50 PM Thread Starter
are the both Headlight HID Bulb same?? or they have different part number?
Can anyone verify part number of headlight bulb please?
I found this one.
9098120007
HIGH DISCHARGE HEADLAMP BULB LAMP - HID BULB, 12V 35W
yongberg is offline
post #5 of 12 (permalink) Old 03-14-2014, 01:41 AM
Quoted: 9 Post(s)
They tend to wear out at the same rate.
post #6 of 12 (permalink) Old 03-14-2014, 08:15 AM
Quoted: 87 Post(s)
Swap bulbs, and if it's still pink, then it's the ballast. If it fixes it, then it's the bulb. In which case you SHOULD swap both bulbs at the same time.
-'03 MSM IS 300 5-Speed w/LSD - #REKT. Parted out
-'05 TCM Scion xB
-'08 Mazdaspeed3 Sport - Zoom-zoom.
RazoE is offline
post #7 of 12 (permalink) Old 03-14-2014, 09:07 AM
If it goes pink it's usually the bulb... if the ballast went you'd probably have other issues other than a colour change. They're the same part, just replace both. Bulb size is D2R.
$150 for a pair of bulbs is insane, even though that's how much OEM costs. If you can't find OEM for cheaper then just buy aftermarket, just don't go too blue, stick with 4300K or 5000K. I bought a replacement pair for something like $30 shipped.
2001 Lexus IS300 GGP + some mods
VorteC is offline
post #8 of 12 (permalink) Old 03-14-2014, 09:25 PM
Quoted: 601 Post(s)
Pink bulb means the bulb needs to be replaced, not the ballast. Your other side was obviously replaced relatively recently. Always replace HID bulbs in pairs so that this doesn't happen.
post #9 of 12 (permalink) Old 03-14-2014, 11:33 PM Thread Starter
Yeah, I'm trying to buy a pair from Sewell.
It says $149. Does this come with pair or just one for $149?
I just like to get an OEM one.
yongberg is offline
post #10 of 12 (permalink) Old 03-15-2014, 07:40 AM
Agreed it's most likely the bulb but as mentioned it's good to swap sides with them to see.
Usually it turns pink when the metal halide bulb has lost much of it's gas in the "arc tube" and cannot sustain an arc. Now if you said it won't fire up at all, then it might have been the ballast's ignitor.
Remember to wear gloves or wipe the glass on the bulbs after handling them, the oil on your skin can shorten their lifespan or make them burst.
post #11 of 12 (permalink) Old 03-17-2014, 04:50 AM Thread Starter
Thanks Jason. I've ordered the parts and I will receive them soon, I will replace them as
soon as possible, and I will post updates here
Thanks guys
yongberg is offline
post #12 of 12 (permalink) Old 03-31-2014, 04:25 AM Thread Starter
Finally got my headlight fixed last week
The bulb was the problem, as soon as I put the new one in, it shined like diamond!
Thanks!
yongberg is offline
pink grille Grillmatic Showroom 65 01-11-2009 07:14 PM
*UPDATE*pics..Headlight turned pink? Dito General Discussion 14 04-03-2006 08:22 PM
a shade of pink sp33dy714 Showroom 23 10-17-2005 09:53 PM
