Oxygen Sensors - FAQ
242K views 260 replies 106 participants last post by  01 SolarYellow
#1 · (Edited)
WHY DO I CARE?
What Is OBD?
Thanks to digger08 for the below pic.
WHERE CAN YOU BUY THEM?
Here are some online sites, you can get a Denso 02 Sensors: Denso starters, alternators, iridium plugs, fuel pumps and glow plugs, OELEXUSPARTS.com, or Sewell Lexus Parts and Accessories Online - All Genuine Lexus Original Equipment Parts. They are all around the $100-$150 neighborhood with shippine. Generics can be as much as half that amount.
WHAT ARE THE PART NUMBERS?
Bank 1 Sensor 1:
89465-53090 (2001) *
89465-53140 (2001) *
89465-53210 (02+) **
Bank 1 Sensor 2:
89465-53110 (2001) *
89465-53200 (02+) **
Bank 2 Sensor 1:
89465-53110 ?
89465-53200 ?
89465-53190 (02+) **
Bank 2 Sensor 2:
89465-53120 (01) **
89465-53150 ?
HAS ANYBODY DONE A DIY YET?
http://my.is/forums/f115/diy-p0161-o2-sensor-b2-s2-change-pics-263613/
http://my.is/forums/f88/how-fix-p0161-o2-sensor-heater-circuit-malfunction-b1s2-free-p0141-290038/
http://my.is/forums/f88/how-install-o2-simulator-284733/
http://my.is/forums/f88/o2-simulators-dummies-336947/
See less See more
4
#3 ·
Thanks bro.
I'm not an expert, so if something is wrong, point it out, it won't hurt my feelings.
I just did a lot of reading on it recently as my B1S2 went out. As more and more IS300 hit 50K+ miles, people are going to get more and more CELs due to worn out O2 sensors.
#8 · (Edited)
I just had this out with Advanced so here are the Bosch part numbers for the O2 Sensors.
B1S1 = 13646
B1S2 = 13732
B2S1 = 13647
B2S2 = 13644
Atleast that is for the 2002 I don't know how that will translate to the other year models but I found the information on the Oriely's website.
#11 ·
Great post, i'm having issues w/my B2S2 and am trying to figure out which route to take. I'm basically just delaying fixing it right. ahwell!
i have to spread some rep around before giving it to you again square!
i'm not from cali but i can tell you that you will not pass after installing aftermarket headers since they remove 2 of your 3 cats.
i'm not sure how they do a smog check, but if it's not visual then you can pass the OBDII scan by getting an O2 sim to prevent the CEL from coming on.
#13 · (Edited)
Thanks bro. Updated original post with pics of OBD port and y-pipe contributed by member viphoria.
I have an O2 Sensor B1S2 CEL (P0141) right at 52,000 as well. I think it is a conspiracy!
I have been staring at the stupid CEL for about 1500 miles already. My wife thinks I'm low on gas. (Better hurry up and get gas, your light is on - Squareback's wife)
#18 ·
Here is some more interesting news for everyone.
Today I replaced the B2S1 sensor in my 2004 Lexus IS300...
Not that exciting except for the fact that I replaced it with a 2001 B1S1 sensor! It is running great so far. The 02+ B1S1 will not work with the B2S1, unless spliced in...however the 01 B1S1 plugs in and works perfectly in the B2S1 position.
Just thought I'd share. This could help some people.
#20 ·
I could be very much wrong, but I was under the impression that all the 02 Sensors are pretty much the same (the sensor part), but the connector and the wire length are different for different applications.
I need to PM lextech1 or another tech to confirm the info in this thread is 100% correct.
#24 ·
I wish someone with the skillz could help me out with how to fix my P0125 code. I think the diagnostic explanation was miswritten, as I'm 99% sure this has something to do with O2 sensors. There's a thread on the code, but I'd like to see if I could fix it without plopping down five bills for all new sensors.
Anyone?
#26 ·
P0125
Insufficient Coolant Temperature For Closed Loop Fuel Control
I've had that code before at the same time as some o2 sensor ones.........I can't remember what I did to get it or get rid of it though. For some reason I think it just went away when I fixed my o2 problems. added an o2 sim when I put the headers on.
the wrong tone--What's your exhaust system like? headers? y-pipe? axle-back?
#27 ·
Megan header, stock y, HKS Ti Limited axle-back.
I never installed my O2 sim, we just secured the after cat sensor to a hardline. The code came on after installing my header. One of my O2 sensors was seized up, so I had to buy a universal. I reckon I'll just have to replace that one with an OE unit. I'll try installing the O2 sim first, I just lack the soldering skills.
