Oxygen Sensors - FAQ - Page 8 - Lexus IS Forum
post #106 of 258 (permalink) Old 05-15-2010, 08:20 PM
acumenhokie's Avatar
Originally Posted by IanH View Post
I went to the Denso site or so I thought, and when I purchased was diverted to sparkplugs.com
This is where I got mine.
IS300 Alumni
acumenhokie is offline
post #107 of 258 (permalink) Old 05-16-2010, 01:35 AM
I purchased the generic, same for all four, and comes with anti-seize, crimp on joints and shrink wrap, genuine Denso. about $45 each for 2 shipped, yes I used a coupon for 10% that offset the shipping. Also check amazon, as they were about the same once you have the part number.
DEN234-4209
On the Box 234-4209
Spark plug, Spark plug wire, spark plug gap, spark plug cross reference and ignition wires at Sparkplugs.com
Amazon.com: Online Shopping for Electronics, Apparel, Computers, Books, DVDs & more
This only works on Firefox
Amazon.com: 234-4209
thanks! so theres 2 that i found on densoproducts.com. one is the universal and the other is the OE identical. the reference number is 234-4630. thats B1S2 right?
jsquareD is offline
post #108 of 258 (permalink) Old 05-16-2010, 09:43 AM
B1S2
Super Class OE identical O2 sensor 234-4015 FRONT; LOWER; $109.30
B1S1
Super Class OE identical O2 sensor 234-4626 FRONT; UPPER; $96.80
B2S1
Super Class OE identical O2 sensor 234-4630 REAR; UPPER; Located at Cyl. 4-6; $114.13
Why not save $50 and get the universal, cant go wrong that way.
EDIT ADDED
found
B2S2
234-4517
Images Cylinder 4,5,6; Cylinder 4,5,6; DENSO is the O.E. Manufacturer / Oxygen Sensor N/A Rear
2003 Pathfinder SE 4WD
Last edited by IanH; 06-23-2010 at 08:58 AM. Reason: correction added 4th sensor, cleaned up
IanH is offline
post #109 of 258 (permalink) Old 05-16-2010, 10:11 AM
what about 234-4015 FRONT; LOWER;
IanH is offline
post #110 of 258 (permalink) Old 05-16-2010, 10:32 AM
found this
234-4517
added in post above so all 4 part numbers together.
IanH is offline
post #111 of 258 (permalink) Old 05-16-2010, 10:53 AM
yea i might as well try out the universal sensors.
jsquareD is offline
post #112 of 258 (permalink) Old 06-23-2010, 08:33 AM
Replaced bank 2 sensor 2 in my 01 IS300 last weekend using the instructions in this thread. Took about 1.5 hours total. We used the Denso OE plug so we could skip the wiring. Part #234-4517
IS300 Alumni
post #113 of 258 (permalink) Old 07-05-2010, 04:43 PM
This is probably a dumb question, but I couldn't find an answer anywhere. I haven't purchased the Denso universal 234-4209 yet. How do I know what universal sensor wire to splice to the B1S2 plug? Are they color coded?
2002 MSM 5-SPD LSD K&N FIPK B&M SHORT-THROW 175k+ miles
LexatheLexus is offline
post #114 of 258 (permalink) Old 07-05-2010, 07:34 PM
They give you an insert that says the heater black two wire, signal blue, and ground white connect up. They some Chrysler plugs and import showing wiring.
I believe I already posted some of our wiring, but i can see from the insert the heater is two wires same color, that ready just leaves the signal and ground.
IanH is offline
post #115 of 258 (permalink) Old 07-05-2010, 07:35 PM
so here is what i posed before
IanH is offline
post #116 of 258 (permalink) Old 07-05-2010, 07:49 PM
So for B1S2 we have (this is 2001.x on) your colors may vary !!
OX- this looks like signal to me--- W White
HT --- Heater ---- Green w Blue stripe
E1 --- BR Brown ganged so not signal
+B --- other heater???...Blue Red stripe.. ganged so not signal
E1 is ground goes to manifold .
Other thing to note is others have said heater wires are thicker gauge
Some one who has done this please help. I haven't put mine on yet !!
IanH is offline
post #117 of 258 (permalink) Old 07-06-2010, 11:31 AM
So I need to replace B1S1, B1S2 and B2S1, looking at densoproducts, I see that "2 sensors required" for 234-4626. What do they mean?
As far as I know I need the following:
B1S1 - 234-4626
B1S2 - 234-4015
B2S1 - 234-4630
is this correct?
sdotsen is offline
post #118 of 258 (permalink) Old 07-07-2010, 04:22 PM
B1S1 - 234-4626
B1S2 - 234-4015
B2S1 - 234-4630
is this correct?
I don't see how you need "2 sensors". There are only 4 holes (according to page 1) for 4 sensors. The universal fit 234-4209 doesn't have that phrase under it. I'd just buy the unversals for $43 each.
BY THE WAY, WHAT IS UP WITH AMAZON GOING UP $5 FROM $38 TO $43 SINCE LAST NIGHT??
post #119 of 258 (permalink) Old 07-18-2010, 09:33 AM
UPDATE: I just did a B1S2 replacement with the Denso part 234-4209. You can't really see the sensor nut from the top and the wrench was so big that once B1S2 broke loose, I'd definitely hit B1S1. I had to slide under the car behind the front left wheel. I removed one of those screws that held the plastic underbody and I had just enough room to get a big 7/8" wrench on it. It came off pretty easily, however, I did hit it with PB a day before. Splicing was simple and the butt connectors where good quality. I thought I'd have to solder, but the supplied butt connectors do not allow for it.
When the moment of truth arose and I turned the key, there was the CEL glowing in my face. So for all of you who want that moment of victory right away, definitely pull the negative cable off the battery after you are all done to get rid of the CEL for good. For $43 and a good 2 hours, this was a bargain.
post #120 of 258 (permalink) Old 07-20-2010, 01:25 AM
im tihnking about doing this too! i have amazon prime so i get free shipping.
how easy was it to rewire the o2 sensor?
you have an 02
would this work on an 01?
01' GGP
haiimbrian is offline
Oxygen Sensor Purchase Crester Canada 33 08-21-2007 03:49 PM
Aftermarket Oxygen Sensors. Brianol Showroom 3 04-08-2007 11:58 AM
CEL: Oxygen Sensor dcarp Basic Help & Repair 12 02-01-2007 02:36 PM
oxygen sensor $250!??! sam_riceburner General Discussion 10 10-05-2005 10:21 PM
