WHY DO I CARE?
What Is OBD?
Thanks to digger08 for the below pic.
WHERE CAN YOU BUY THEM?
Here are some online sites, you can get a Denso 02 Sensors: Denso starters, alternators, iridium plugs, fuel pumps and glow plugs, OELEXUSPARTS.com, or Sewell Lexus Parts and Accessories Online - All Genuine Lexus Original Equipment Parts. They are all around the $100-$150 neighborhood with shippine. Generics can be as much as half that amount.
WHAT ARE THE PART NUMBERS?
Bank 1 Sensor 1:
89465-53090 (2001) *
89465-53140 (2001) *
89465-53210 (02+) **
Bank 1 Sensor 2:
89465-53110 (2001) *
89465-53200 (02+) **
Bank 2 Sensor 1:
89465-53110 ?
89465-53200 ?
89465-53190 (02+) **
Bank 2 Sensor 2:
89465-53120 (01) **
89465-53150 ?
HAS ANYBODY DONE A DIY YET?
http://my.is/forums/f115/diy-p0161-o2-sensor-b2-s2-change-pics-263613/
http://my.is/forums/f88/how-fix-p0161-o2-sensor-heater-circuit-malfunction-b1s2-free-p0141-290038/
http://my.is/forums/f88/how-install-o2-simulator-284733/
http://my.is/forums/f88/o2-simulators-dummies-336947/
WHY DO I CARE?
What Is OBD?
Bank 1 Sensor 1:
Bank 1 Sensor 2:
Bank 2 Sensor 1:
89465-53110 ?
89465-53200 ?
Bank 2 Sensor 2:
89465-53120 (01) **
89465-53150 ?
