Oxygen Sensors - FAQ - Lexus IS Forum
post #1 of 258 (permalink) Old 07-06-2007, 03:42 PM Thread Starter
Squareback's Avatar
WHY DO I CARE?
What Is OBD?
Thanks to digger08 for the below pic.
WHERE CAN YOU BUY THEM?
Here are some online sites, you can get a Denso 02 Sensors: Denso starters, alternators, iridium plugs, fuel pumps and glow plugs, OELEXUSPARTS.com, or Sewell Lexus Parts and Accessories Online - All Genuine Lexus Original Equipment Parts. They are all around the $100-$150 neighborhood with shippine. Generics can be as much as half that amount.
WHAT ARE THE PART NUMBERS?
Bank 1 Sensor 1:
89465-53090 (2001) *
89465-53140 (2001) *
89465-53210 (02+) **
Bank 1 Sensor 2:
89465-53110 (2001) *
89465-53200 (02+) **
Bank 2 Sensor 1:
89465-53110 ?
89465-53200 ?
89465-53190 (02+) **
Bank 2 Sensor 2:
89465-53120 (01) **
89465-53150 ?
HAS ANYBODY DONE A DIY YET?
https://my.is/forums/f115/diy-p0161-o...e-pics-263613/
https://my.is/forums/f88/how-fix-p016...-p0141-290038/
https://my.is/forums/f88/how-install-...ulator-284733/
https://my.is/forums/f88/o2-simulators-dummies-336947/
Squareback is offline
post #2 of 258 (permalink) Old 07-06-2007, 03:50 PM
Ninja?
*subscribed* and +repped
kayotik is offline
post #3 of 258 (permalink) Old 07-06-2007, 03:55 PM Thread Starter
Squareback's Avatar
Thanks bro.
I'm not an expert, so if something is wrong, point it out, it won't hurt my feelings.
I just did a lot of reading on it recently as my B1S2 went out. As more and more IS300 hit 50K+ miles, people are going to get more and more CELs due to worn out O2 sensors.
post #4 of 258 (permalink) Old 07-08-2007, 04:06 PM
Great info, using it to get my car fixed!
kaptain86 is offline
post #5 of 258 (permalink) Old 07-11-2007, 03:58 PM
Well this article will be very useful. Lexus of Cerritos is selling the O2 sensor for 177.71 while oelexusparts.com is selling it for 120.78. What a Difference!
Lexus_Rider02 is offline
post #6 of 258 (permalink) Old 07-11-2007, 04:04 PM
there are denso ones that are actually plug n play and do not require repinning or splicing. they are actually not that expensive they are around 80 something dollars
Carlin
chiu_888 is offline
post #7 of 258 (permalink) Old 07-12-2007, 04:54 PM
Al,
01 GGP / Stealth On Wheels
Lexotic Concepts NE014
Elusive Media
Gray Rider is offline
post #8 of 258 (permalink) Old 07-21-2007, 04:44 PM
I just had this out with Advanced so here are the Bosch part numbers for the O2 Sensors.
B1S1 = 13646
B1S2 = 13732
B2S1 = 13647
B2S2 = 13644
Atleast that is for the 2002 I don't know how that will translate to the other year models but I found the information on the Oriely's website.
2002 LEXUS IS300
5SPD LSD | TEIN | CUSCO | MEGAN | CLUTCHMASTERS | FIDANZA | HOTCHKIS
Last edited by SirMichael; 07-21-2007 at 04:45 PM. Reason: Adding a little more information.
SirMichael is offline
post #9 of 258 (permalink) Old 07-25-2007, 08:57 AM
Straight forward and clear. A huge amount of threads are about these issues, now theres a comprehensive thread to direct people too after they refuse to search for the answer first +rep
01 GGP w/LSD
Joe-Z/TRD - 18" ASA AR1s - BFG KDW 2's
Jared'IS is offline
post #10 of 258 (permalink) Old 08-05-2007, 06:09 PM
I am about to install megan headers but I am not sure If I am going to
pass A California Smog Check. Can anyone let me know if I will
pass? I would truly appreciate it.
- This post helped me alot rep+
jamesmoney is offline
post #11 of 258 (permalink) Old 08-06-2007, 11:23 AM
Great post, i'm having issues w/my B2S2 and am trying to figure out which route to take. I'm basically just delaying fixing it right. ahwell!
i have to spread some rep around before giving it to you again square!
i'm not from cali but i can tell you that you will not pass after installing aftermarket headers since they remove 2 of your 3 cats.
i'm not sure how they do a smog check, but if it's not visual then you can pass the OBDII scan by getting an O2 sim to prevent the CEL from coming on.
[NLC--MA #004][Find me @ ISFanatics][Walk Hard]
Vouch List: Hiroshima, redline814, mixtapeguru, asukadc, SexusinmyLexus, Sparky, IntensaBlu, TDLI, Velocity02, BLK_IS350, Phil, IS_Monster, 02LexIS300, Chado, LexIS307, ToyotaPete, jakes_is, ayoitsstevo, 03_IS, 04_IS, acumenhokie, FutureISdriver, and everyone else I missed.
can't forget about enjoico
Seven0Three is offline
post #12 of 258 (permalink) Old 08-21-2007, 07:29 PM
just got my CEL(have 52K miles on 2002)on..and this will def.help..thanks for the link to DIY also. +rep
02' MSM 5 Spd w/LSD
02' GGP E-Shift R.I.P.
[NLC MA#001] [Club Lexus - NELOC]
[Find me @ ISfanatics.com]
Nikon D300
č^õ(`;ī)č^õ
02LexIS300 is offline
post #13 of 258 (permalink) Old 08-21-2007, 08:12 PM Thread Starter
Squareback's Avatar
Thanks bro. Updated original post with pics of OBD port and y-pipe contributed by member viphoria.
I have an O2 Sensor B1S2 CEL (P0141) right at 52,000 as well. I think it is a conspiracy!
I have been staring at the stupid CEL for about 1500 miles already. My wife thinks I'm low on gas. (Better hurry up and get gas, your light is on - Squareback's wife)
post #14 of 258 (permalink) Old 08-22-2007, 04:34 PM
acumenhokie's Avatar
This is some great info. Have some rep and feel free to sticky
IS300 Alumni
acumenhokie is offline
post #15 of 258 (permalink) Old 08-23-2007, 07:05 AM
great info...thx....repped
https://my.is/forums/members/61675.html
NIKON D80 | MBD80 | 50mm f1.8 | 18-135 f3.5
03_IS is offline
Oxygen Sensor Purchase Crester Canada 33 08-21-2007 03:49 PM
Aftermarket Oxygen Sensors. Brianol Showroom 3 04-08-2007 11:58 AM
CEL: Oxygen Sensor dcarp Basic Help & Repair 12 02-01-2007 02:36 PM
oxygen sensor $250!??! sam_riceburner General Discussion 10 10-05-2005 10:21 PM
