-   Basic Help & Repair (https://www.my.is/forums/f115/)
-   -   Oxygen Sensors - FAQ (https://www.my.is/forums/f115/oxygen-sensors-faq-334479/)
Squareback 07-06-2007 03:42 PM
WHY DO I CARE?
What Is OBD?
http://i6.photobucket.com/albums/y21...OBD-02Port.jpg
http://i6.photobucket.com/albums/y21...i/DSC00696.jpg
http://i6.photobucket.com/albums/y21...-view011-1.jpg
Thanks to digger08 for the below pic.
http://i6.photobucket.com/albums/y21...f?t=1200685627
WHERE CAN YOU BUY THEM?
Here are some online sites, you can get a Denso 02 Sensors: Denso starters, alternators, iridium plugs, fuel pumps and glow plugs, OELEXUSPARTS.com, or Sewell Lexus Parts and Accessories Online - All Genuine Lexus Original Equipment Parts. They are all around the $100-$150 neighborhood with shippine. Generics can be as much as half that amount.
WHAT ARE THE PART NUMBERS?
Bank 1 Sensor 1:
89465-53090 (2001) *
89465-53140 (2001) *
89465-53210 (02+) **
Bank 1 Sensor 2:
89465-53110 (2001) *
89465-53200 (02+) **
Bank 2 Sensor 1:
89465-53110 ?
89465-53200 ?
89465-53190 (02+) **
Bank 2 Sensor 2:
89465-53120 (01) **
89465-53150 ?
HAS ANYBODY DONE A DIY YET?
https://my.is/forums/f115/diy-p0161-o...e-pics-263613/
https://my.is/forums/f88/how-fix-p016...-p0141-290038/
https://my.is/forums/f88/how-install-...ulator-284733/
https://my.is/forums/f88/o2-simulators-dummies-336947/
kayotik 07-06-2007 03:50 PM
*subscribed* and +repped
Squareback 07-06-2007 03:55 PM
Thanks bro.
I'm not an expert, so if something is wrong, point it out, it won't hurt my feelings.
I just did a lot of reading on it recently as my B1S2 went out. As more and more IS300 hit 50K+ miles, people are going to get more and more CELs due to worn out O2 sensors.
kaptain86 07-08-2007 04:06 PM
Great info, using it to get my car fixed!
Lexus_Rider02 07-11-2007 03:58 PM
Well this article will be very useful. Lexus of Cerritos is selling the O2 sensor for 177.71 while oelexusparts.com is selling it for 120.78. What a Difference!
chiu_888 07-11-2007 04:04 PM
there are denso ones that are actually plug n play and do not require repinning or splicing. they are actually not that expensive they are around 80 something dollars
Carlin
Gray Rider 07-12-2007 04:54 PM
Al, :approve: :approve: :approve:
SirMichael 07-21-2007 04:44 PM
I just had this out with Advanced so here are the Bosch part numbers for the O2 Sensors.
B1S1 = 13646
B1S2 = 13732
B2S1 = 13647
B2S2 = 13644
Atleast that is for the 2002 I don't know how that will translate to the other year models but I found the information on the Oriely's website.
Jared'IS 07-25-2007 08:57 AM
Straight forward and clear. A huge amount of threads are about these issues, now theres a comprehensive thread to direct people too after they refuse to search for the answer first ;) +rep
jamesmoney 08-05-2007 06:09 PM
I am about to install megan headers but I am not sure If I am going to
pass A California Smog Check. Can anyone let me know if I will
pass? I would truly appreciate it.
- This post helped me alot rep+
Seven0Three 08-06-2007 11:23 AM
Great post, i'm having issues w/my B2S2 and am trying to figure out which route to take. I'm basically just delaying fixing it right. ahwell!
i have to spread some rep around before giving it to you again square!
i'm not from cali but i can tell you that you will not pass after installing aftermarket headers since they remove 2 of your 3 cats.
i'm not sure how they do a smog check, but if it's not visual then you can pass the OBDII scan by getting an O2 sim to prevent the CEL from coming on.
02LexIS300 08-21-2007 07:29 PM
just got my CEL(have 52K miles on 2002)on..and this will def.help..thanks for the link to DIY also. +rep
Squareback 08-21-2007 08:12 PM
Thanks bro. Updated original post with pics of OBD port and y-pipe contributed by member viphoria.
I have an O2 Sensor B1S2 CEL (P0141) right at 52,000 as well. I think it is a conspiracy!
I have been staring at the stupid CEL for about 1500 miles already. My wife thinks I'm low on gas. (Better hurry up and get gas, your light is on - Squareback's wife)
acumenhokie 08-22-2007 04:34 PM
This is some great info. Have some rep and feel free to sticky :)
03_IS 08-23-2007 07:05 AM
great info...thx....repped
