Oxygen Sensors - FAQ
242K views 260 replies 106 participants last post by  01 SolarYellow
#1 · (Edited)
WHY DO I CARE?
What Is OBD?
Thanks to digger08 for the below pic.
WHERE CAN YOU BUY THEM?
Here are some online sites, you can get a Denso 02 Sensors: Denso starters, alternators, iridium plugs, fuel pumps and glow plugs, OELEXUSPARTS.com, or Sewell Lexus Parts and Accessories Online - All Genuine Lexus Original Equipment Parts. They are all around the $100-$150 neighborhood with shippine. Generics can be as much as half that amount.
WHAT ARE THE PART NUMBERS?
Bank 1 Sensor 1:
89465-53090 (2001) *
89465-53140 (2001) *
89465-53210 (02+) **
Bank 1 Sensor 2:
89465-53110 (2001) *
89465-53200 (02+) **
Bank 2 Sensor 1:
89465-53110 ?
89465-53200 ?
89465-53190 (02+) **
Bank 2 Sensor 2:
89465-53120 (01) **
89465-53150 ?
HAS ANYBODY DONE A DIY YET?
http://my.is/forums/f115/diy-p0161-o2-sensor-b2-s2-change-pics-263613/
http://my.is/forums/f88/how-fix-p0161-o2-sensor-heater-circuit-malfunction-b1s2-free-p0141-290038/
http://my.is/forums/f88/how-install-o2-simulator-284733/
http://my.is/forums/f88/o2-simulators-dummies-336947/
See less See more
4
#137 ·
i replaced the b1s2 with the bosch universal... matched up the appropriate wire colors and everything. but my check engine light is still on. reset the battery, and after 30 miles, it still came back on. need to fix to pass smog. help???
I would pull the codes again. I wouldn't be surprised if another one went bad.
#139 ·
Well who knows it could be a result of bad gas or even the gas cap. My suggestion is to read the code or simply reset your ECU and see if it comes back on. Anything can trigger the CEL and even if the issue went away..the computer needs reset. Stupid little light...lol
#141 ·
Oxygen Sensors & Cylinder / Location
For whatever reason, websites don't list sensors as B1/2 and S1/2. They list them in terms of cylinder and location. Here is the breakdown:
B1 = Cylinders 1-3
B2 = Cylinders 4-6
S1 = Front
S2 = Rear
I had my B1S2 replaced with Denso Part 234-4015 earlier month. So far so good.
I hope this helps. Cheers!
#147 ·
I got the placement of the sensor figured out. But just not sure if the sensor is plugged into the right part of the engine harness. there are two plugs near the front passenger side of the cylinder head. how do i know which one b1s1 plugs into and which b1s2 plugs into? When my sister owned the car, she brought it to a shop to fix this issue and they changed all the o2 sensors and exhaust mani but still coming up with o2 faults. i just swapped out the b1s1 sensor and p0135 popped up again..
#148 ·
Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
So you need to check the resistance and continuity in the sensor, if that is OK then check the voltage (power side) and ground path on the low side of the connection.
search for the proper procedures.
Others that have had this problem have posted threads on here, heater circuit problems seem quite common.
#150 ·
Ok on my 2004 the lower one, looks more grey and loose in your pic, goes to B1S1
BTW both mine are the same grey color .....both attached to the bracket on my car.
Its easy to follow this wire to the Sensor.
#153 ·
heater circuit malfunction
I followed your directions which were great by the way, but my problem continues. I did a code read after installing the new b1s2 oxygen sensor made by lexus and the code reads p0141. What I want to know is WHERE is the "heater circuit?" nothing more nothing less, a picture by anyone would be great. I am assuming the heater circuit is the connector attached to the oxygen sensor.
alvaro quinonez
#154 ·
alvaro quinonez
The heater circuit is a part of the 02 sensor. Inside of an O2 sensor is a sensor signal circuit and a heater circuit. The heated circuit in the oxygen sensor decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The two black wires on an OEM Denso sensor are the heater wires and should read about 10-14 ohms @68*F, IIRC.
P0141 - Oxygen O2 Sensor Heater Circuit Malfunction (Bank1, Sensor2)
Replacing the correct sensor should have solved the problem. Check to see if the connection harness is tight(by the air box) and possibly reset/clear the code by pulling the negative off the battery for a few minutes. Other than that, they either replaced the wrong sensor or the new one is bad, which they should replace free of charge.
#156 ·
Jason, so whats does the P0036(same sensor)code refer to?
There are at least 5 related codes just for that sensor's(B1S2) heater circuit. That's because our ECM is that damn sensitive. Normally any of these codes would indicate the heater circuit is open, shorted, or simply malfunctioning. I would check the connections and if they look ok, then I would replace the sensor and clear the code.
P0054-O2 sensor heater resistance B1S2
P0036-O2 sensor heater control circuit B1S2
P0037-O2 sensor heater control circuit low B1S2
P0038-O2 sensor heater control circuit high " "
P0141-02 sensor heater malfunction
#158 ·
Hello All,
I have been lurking for about a week and wanted to post on here to make sure I get the right O2 sensor and have the right location. The Code im throwing up is a P0430 Catalyst System Efficency Below Threshold (Bank 2). I have been reading on this forum and using the search function to make sure I have the right location and right sensor but want some reassurance. Is this O2 sensor it is identifying the one under the passenger area that you can plainly see and that some have removed the seat to get to it easier? I want to verify before I start taking one out and changing it. From what I have read this is the right location. I am at Densoproducts and sparkplugs.com and on eBay and want to verify im looking at the right o2 sensor too. Since the dealer wants 190 for this sensor, i'm going to try and change it for cheaper :)
Densoproducts.com shows Front cylinders 4-6, front upper cylinders 1-3 , rear cylinders 1-3 and rear cylinders 4-6. It doesnt mention the one after the cat (downstream I guess) . This is the one im looking at on ebay New Rear Bosch O2 Oxygen Sensor Lexus IS300 2002 2001 Parts Auto Car | eBay
I bought the car a week and a half ago and have unplugged the batt 2 times and cleared the code twice. The same code keeps popping up. I ran seafoam in the tank as well. I test drove the car 3 times and it never came on. I got 91 gas in it (previous was putting 87 in mostly and occasional 91) and about 20 miles later the light came on.
Thanks again to the community for your help
BTW its a 2001 Lexus IS300 with 203k miles. (high miles I know, but I had faith in it, no leaks no burning)
#159 · (Edited)
Yes, P0430 is bank 2 sensor 2 is a cat efficiency code. It can be caused by a cat going bad, an exhaust leak, or bad o2 sensor. It is easier to check for leaks and replace the O2 sensor, even though the sensor can be tested with a voltmeter to verify it's .2 to .9 volt fluctuation. You don't nessesarily have to remove the front seat. I know some members have moved the seat forward and up all the way and had enough room to pull the old sensor wiring out and fish the new sensors wiring in. It is located at the Y pipe, directly below the seat. If you do remove the seat, make sure to disconnect the battery and wait a few minutes before doing any work, this is to prevent the airbags from deploying when the seat harnesses are disconnected. IMO, I would go with an OEM Denso replacement, but Bosch is fine and that link looks like the correct sensor. This image here shows all the o2 sensor locations and the part numbers to replace them with.
Http://img522.imageshack.us/img522/8813/o2diagram16.jpg
#161 ·
Perfect, Thank you Jasonm444. I may just go ahead and purchase the Denso. If I get the one with the plug already on it, I should still be able to just move the seat forward right and disconnect the current one and connect the other? I don't really wanna deal with air bag change of deployment.
#162 ·
Yes, I've heard but not actually done myself, that you can move the seat all the way forward and high as it can go. You can cut the old sensor's wires and use them to fish the new ones into the car. Just tape the new sensor's wires onto the old wiring. Removal of the seat is really no big deal, basically 4 bolts and a few harnesses, but the battery does have to be disconnected and a there is a couple minute waiting period before disconnecting the seat harnesses. Ahh, and sorry about ya Blacksport. Our vendors can definitely help you out there as well.
#163 ·
I'm prolly cursing myself but, the code hasnt come back on since I cleaned the MAF and cleared the code for the o2 sensor. It usually would have come on by now. Ive put 80 miles on it and no code, usually it would throw at 20...don't know if this has anything to do with it, but the previous owner said he sometimes would hit it with 91 but usually ran 87, you think it has some gunk on it and the seafoam and normal 91 finally cleared it through?
#164 ·
Well, I hope for you sake it does not come back on, but since it's a heater circuit malfunction, it 95% of the time comes back. If it's not a connection, then it may be slowly going bad(internally). I would wait till 500 miles or so before you get your hopes up.
#168 ·
Went back on 20 miles after getting gas, just like it did the first time. Seems to come on 20 miles after getting a fresh tank of gas. I went 160 miles without the code and then filled up and it went off. Sigh, oh well. I'll get the 02 on my next paycheck. Getting the tie rods replaced and plugs changed with this paycheck lol
#169 ·
sorry to hear. It's worth it to just change the O2, as you mentioned, or test it if you have a voltmeter and are the hands on type. I would also check for any exhaust leaks. If the code comes back after a new O2 or if the sensor voltage fluctuation tests ok, then you may have a cat issue.
#170 ·
I've been searching around the forums and just want to make sure I have this right. I bought my IS300 a couple of months back and had a CEL. When I checked all 4 o2's were bad. I bought aftermarket headers and also bought the Token Solutions o2 delete. I reset the codes and a couple of miles later I got the CEL. I put the computer on and got B1S1 and B2S1. My question is this, if I buy those two o2's and put them in will the CEL go off or it won't because of the headers? Thank you guys.
#171 ·
You need the S1's, both of them, to control the fuel mixture, with or without headers. The O2 delete is for the S2's
UNLESS you have a replacement fuel control solution, stand alone computer etc ....
#174 ·
Here is my problem:
Code P0038: Oxygen sensor heat control circuit high voltage B1S2
My setup is Mazzuri headers, SRT intake, Token Solutions O2 Delete
I just replaced my old O2 simulator with the Token Solutions O2 Delete. I've probably only driven ~750 miles since, max, and I did rewire the ECU back to stock when I removed the O2 sim. I have had emissions checked within that time with no issues.
So, the question is, what could have gone wrong? Loose connection in rewire of ECU? An issue with the O2 delete (which I honestly do not completely understand how it works)? Safe to drive?
