Not going into gear - Page 2 - Lexus IS Forum
post #16 of 35 (permalink) Old 11-23-2013, 10:50 AM Thread Starter
Yeah I scanned it and nothing about the solenoids came up. I do notice that when I put it in gear it doesn't click or shift or give any type of sign that it is engaging a gear. It's just quiet. Do you think it might be the trans or the torque converter?
2001 IS300
E-Shift
Spectra Blue Mica
LSD
Tein CS V2.0 w/ EDFC
Greddy EMU
Alucard13 is offline
post #17 of 35 (permalink) Old 11-23-2013, 10:58 AM Thread Starter
I think I mentioned this before, I replaced the speed sensor on the rear of the trans. If I put the car in gear and rev the motor to 5000 rpms the cel comes on and it is p0500, which is the vehicle speed sensor.
2001 IS300
E-Shift
Spectra Blue Mica
LSD
Greddy EMU
post #18 of 35 (permalink) Old 12-09-2013, 08:43 PM Thread Starter
I'm starting to think I might have to just replace my entire transmission at this point.
2001 IS300
E-Shift
Spectra Blue Mica
LSD
Greddy EMU
post #19 of 35 (permalink) Old 12-09-2013, 09:10 PM
So car starts fine? idles fine, you can push on the brake and then move the gear selecter into R N and D 321 and it still acts like its in park?? rev and no clunking or grinding or anything?
2003 GGP IS300 Sport Design 5 Speed
halfzac is offline
post #20 of 35 (permalink) Old 12-09-2013, 09:11 PM
to me this sounds more electronic or sensor than something mechanical IMO
halfzac is offline
post #21 of 35 (permalink) Old 12-09-2013, 10:42 PM Thread Starter
It revs fine and idles fine, when I put it in gear it acts like it's in neutral.
2001 IS300
E-Shift
Spectra Blue Mica
LSD
Greddy EMU
post #22 of 35 (permalink) Old 12-10-2013, 06:46 AM
Sounds to me its a solenoid. no sure if your familiar with mechanical stuff but you can take test each solenoid individual to see wich one is clicking and wich one is not.
BC 264 Cams / Titan cam gear /AAC Halos /TRD lip kit /Megan camber kit /FIGS rear lower arms/ Fortune coil overs/ fog mod/ joe-z intake/ 19" PIAA SUPER ROZZAS/
lexguy300 is offline
post #23 of 35 (permalink) Old 12-11-2013, 01:05 AM Thread Starter
If you'd be willing to give me a quick tutorial on how to test the solenoids that would be awesome
2001 IS300
E-Shift
Spectra Blue Mica
LSD
Greddy EMU
post #24 of 35 (permalink) Old 12-11-2013, 04:51 AM
Thhe solenoids should read 11-15 ohms @68*F. One side of the coil is grounded so the solenoids (S1-S3, SLU, SLD) are fed with one wire. There is a whole bank of codes for the automatic transmission and you should really download the diagnostic manual and FSM from the stickies (threads in blue) in the Gen. Disc. forum. Here is also a book just on our transmission that may also help.
https://www.dropbox.com/s/s28enzg0ganbb18/A-650E.pdf
post #25 of 35 (permalink) Old 12-11-2013, 11:01 AM Thread Starter
I have all the fsm and diagnostic pdfs as well as alldata. The reason I am so confused is because I don't have any codes on my scanner that refer to my valve body. Given it is possible that my scanner is unable to read issues with my valve body solenoids.
2001 IS300
E-Shift
Spectra Blue Mica
LSD
Greddy EMU
post #26 of 35 (permalink) Old 12-11-2013, 11:06 AM Thread Starter
Wow I didn't have that pdf. Thanks, that thing is awesome.
2001 IS300
E-Shift
Spectra Blue Mica
LSD
Greddy EMU
post #27 of 35 (permalink) Old 02-02-2014, 06:59 PM Thread Starter
So I tested the ecu connections that go to the ecu. In the diagram its connection 5. All the voltage checks out and is what it should be. Any ideas what I should check next.
2001 IS300
E-Shift
Spectra Blue Mica
LSD
Greddy EMU
post #28 of 35 (permalink) Old 02-02-2014, 07:31 PM
It almost sounds like the torque converter is not locking up mechanically. So the only code that was active was P0500, have you checked the speed sensor to verify it's OK and seated tight? The diagnostic troubleshooting starts on page #471 for P0500.
post #29 of 35 (permalink) Old 02-02-2014, 07:50 PM Thread Starter
Yeah I checked the sensor and even replaced it just to be sure. It's fine.
2001 IS300
E-Shift
Spectra Blue Mica
LSD
Greddy EMU
post #30 of 35 (permalink) Old 02-02-2014, 08:05 PM Thread Starter
So you think it might be the torque converter then?
2001 IS300
E-Shift
Spectra Blue Mica
LSD
Greddy EMU
Auto trans 4th gear & 5th gear Intensa Lex General Discussion 27 03-15-2013 05:42 PM
Some Say He's Tiff Needell: Fifth Gear host back at Top Gear to fill in for The Stig? -=Hot|Ice=- The Garage 2 12-22-2010 10:20 PM
Pagani Zonda F on 5th Gear & Top Gear EricK The Garage 3 04-12-2007 05:28 AM
Top Gear & 5th Gear Torrents mr. haison The Garage 1 12-21-2004 06:08 AM
3rd gear AUTO dyno, what was the method of holding in gear? Fig Go Faster 10 04-06-2004 03:10 PM
