Noise from Diff. please help!!! - Lexus IS Forum
post #1 of 10 (permalink) Old 03-04-2019, 07:54 PM Thread Starter
Hello, i am a noob to the car community and car forums in general. i bought a rebuilt title IS300, with 74k miles wanting a reasonable rear wheel drive car.
has a vibration when above 40mph so took it to a local pepboys for a steering and wheel diagnosis and they said the wheels are bent which i kinda expected. but the technician added there is a noise from rear diff. i am not sure what to make off of it and he refused to give me more info.
This is a new car to me so i cant tell apart weird noises from the normal ones.
Any suggestions on diagnosis and/or repair will be greatly appreciated.
also i live in central NJ. any suggestions for reasonable shops for repair would be amazing.
ps:i apologize for any my gramatical errors, english is not my first language.
Charan is offline
post #2 of 10 (permalink) Old 03-05-2019, 03:42 AM
Quoted: 36 Post(s)
Where the damage was located on your car?? Because Usualy Orignal Diffs are really sturdy especially the Torsen, IS's had a Thumping noise coming from the diff that is refered to the slack in the driveline, more noticeable on manual versions. It can also be the stupid parking brake assembly in your rear brake system. Mine was clunking last summer. And sadly it still present even if I've worked on the parking brake system during the winter.
Color: Cromax YR580M
TRD Carbon Fiber Shifter Ball
Fidanza Exhaust Cam Gear
SPC Rear Camber Kit
Continental ProContact Tires
Mathieu Bernier is offline
post #3 of 10 (permalink) Old 03-05-2019, 06:01 AM
Quoted: 339 Post(s)
Double posts are not cool and will not get you help faster.
As for your issue. Do you have a video or sound file? Otherwise we need more info.
post #4 of 10 (permalink) Old 03-05-2019, 12:09 PM
Quoted: 229 Post(s)
if you cannot hear any noises from the diff, and the tech refused to give you any more info it sounds like there really isnt an issue here...?
if you worried enough about it, do a visual inspection of the diff and go from there.
Lucy; 04 manual sportdesign
mesooohoppy is online now
post #5 of 10 (permalink) Old 03-05-2019, 02:54 PM
Quoted: 71 Post(s)
First, get round and balanced wheels/tires on the car. Then move onto other sources of noise and vibration.
I thought my differential was making an ugly growling noise, but then I noticed it was definitely worse when going around left hand turns - and almost went away around right hand turns. That pointed me toward a right rear wheel bearing.
Replacing that right rear wheel bearing eliminated the growling noises.
Hodgdon Extreme is offline
post #6 of 10 (permalink) Old 03-06-2019, 09:12 PM Thread Starter
Damage seems to be near the passenger side front door. I actually don't hear any noise for myself it seems to be running smooth as far as I can tell. I don't hear any clunking or thumping. Even in any turns. So have to see after replacing the wheels.
Charan is offline
post #7 of 10 (permalink) Old 03-06-2019, 09:15 PM Thread Starter
My bad, this is my first time posting something and after doing it in the drop stop and roll page. I saw this page so did it again.
I actually can't hear any of the noise. I ordered new wheels. Once I get them on there I will try to get more information.
Charan is offline
post #8 of 10 (permalink) Old 03-06-2019, 09:18 PM Thread Starter
I thought of that, but these guys don't do diffs, hence no incentive for him to give me that information.
I am not sure what I should be looking for in the diff. There would be signs visually of any damage. I am sorry, if I sound completely stupid. Kinda a noob to DIY. Thanks.
Charan is offline
post #9 of 10 (permalink) Old 03-06-2019, 09:20 PM Thread Starter
Yep ordered the wheels already. From pepboys. Hoping to get the wheels done next week. Got the proline 17" matte black ones. Fingers crossed they will look good.
Thank you for the tip though.
Charan is offline
post #10 of 10 (permalink) Old 03-07-2019, 10:01 AM
Quoted: 229 Post(s)
since its a vibration, it leads me to think it something else. verify your wheels are good first and then go from there.
with that being said, since we are already here and on topic of inspecting the diff: inspect the diff cover bushings (you cant really inspect the pinion bushings without taking the diff out). do they look okay? do you see any tears in the rubber? throw a wrench on the pinion bolts and diff cover bolts and confirm they are still tight. also check the allen half shaft to stub shaft bolts; very unlikely they are to come loose unless someone has already dicked with it. you can also check the pinion flange to driveshaft nuts/bolts. check for leaks at the pinion seal and the cover plate.
again, its likely something else. but i just thought i would chime in.
Noise from Diff. please help!!! Charan Stop, Drop and Roll 1 03-05-2019 05:48 AM
Strong Flex Bushing Review and Comparison to Super Pro mesooohoppy Stop, Drop and Roll 49 02-26-2019 11:17 AM
rear diff swap possibilities? NOT re-gear whole diff rockosocko Go Faster 18 05-01-2018 08:26 AM
Noise after Timing Belt and Water Pump Service bradleyhenry94 General Discussion 8 09-19-2017 05:39 AM
Can you identify this suspension noise? catnap General Discussion 33 04-21-2017 10:19 PM
