New Radiator, How much coolant to add? - Lexus IS Forum
post #1 of 4 (permalink) Old 10-11-2018, 11:45 PM Thread Starter
Buying a Denso radiator after I found a crack in the oem one. How much coolant should I add into the new radiator? I'm new to this and i'm not sure since there will be some in the block already?
Macavinta is offline
post #2 of 4 (permalink) Old 10-12-2018, 10:06 AM
Quoted: 66 Post(s)
jack up the front of the car slightly and use this https://www.amazon.com/Lisle-24680-S...dp/B00A6AS6LY/
Just fill it up as much as you can and turn the car on. Then keep the funnel 3/4 full and run the car for 10 minutes with the heater on. when all the bubbles are out turn off the car and remove the funnel by using the stopper to prevent the funnel from spilling.
if you don't do this your car will make gurgling sounds due to that high heater return hose in the back.
lessthanjakejohn is offline
post #3 of 4 (permalink) Old 10-12-2018, 04:42 PM Thread Starter
Thanks
Anyone know the system capacity? I'm going to flush the block as well when I install the new radiator
post #4 of 4 (permalink) Old 10-12-2018, 06:14 PM
Quoted: 66 Post(s)
Coolant Leak Adam_AntiAir General Discussion 2 02-18-2019 07:59 PM
Coolant line routing for turbo-new comp oiless turbo puertorico Go Faster 1 04-11-2017 08:10 AM
DIY: TB coolant line delete. az989 Go Fast Stuff 13 01-22-2017 04:00 PM
coolant issue _sambo Basic Help & Repair 2 09-29-2016 10:33 AM
Heater Core Coolant Hose jmooney5115 Go Faster 7 02-08-2016 06:56 PM
