Multiple issues.. - Lexus IS Forum
post #1 of 4 (permalink) Old 05-20-2014, 11:49 AM Thread Starter
Quoted: 41 Post(s)
Multiple issues..
Hey all,
recently i was told my No. 2 LCAs were bad...i bought some used ones with decent bushings from a junk yard. I was also told my steering rack was "leaking" into one of the boots..i have yet to change the LCAs and steering rack as im compiling parts for a steering and suspension refresh. Recently my power steering has been has been whining (not loud, but noticeable) especially on full lock...
my steering wheel also struggles to return to straight coming off of a turn.
my question is, would it be safe to say that the lower ball joints, lcas, steering rack and the possibility of bad belts result in the sloppiness and noisy front suspensiom?
2002 MSM Sportcross
TEIN//Gita//Blitz//Pioneer//FIGS//Work
instagram - ellis300
ellis300 is offline
post #2 of 4 (permalink) Old 05-20-2014, 12:40 PM
mm71522's Avatar
Quoted: 353 Post(s)
Yeah sounds about right..I had a bad ball joint and my steering rack was leaking into one of the boots as well, so it sounds exactly like what you described..noisy front suspension, steering wheel would return after a turn. Driving it just didn't feel right anymore, and now that I replaced it all, new tires and alignment..it feels perfect again! I'm sure the bad LCAs are making it worse.
Mike
'02 AR IS300; M98 L-Tuned
TOKICO HP/TANABE NF210
ENKEI KOJIN 18X8.5+35/9.5+30
DIY: Nav+Aftermarket HU
DIY: Timing Belt
My Thread
mm71522 is offline
post #3 of 4 (permalink) Old 05-20-2014, 12:54 PM
The lower ball joints and rack issue would give you the sloppiness as mm71522 mentioned and went through, but the whine at lock is pretty normal because the pump is pushing max pressure and I believe is releived by a check valve. Idle rpms should also bump up at lock as well, so that may be normal. It wouldn't be a serpentine belt issue unless it screaches and/or is cracked and old.
post #4 of 4 (permalink) Old 05-20-2014, 01:32 PM Thread Starter
Quoted: 41 Post(s)
Thanks guys. I always knew something wasn't right beyond what I already knew on the car, a second opinion eases the mind
2002 MSM Sportcross
ellis300 is offline
Multiple issues with IS350, need help Sleepy1711 General Discussion 1 03-07-2013 07:08 PM
Why do i waste my time with this car.....(Cooling Issues) (now with Battery issues!) OKCIS Go Faster 70 06-01-2012 02:27 PM
Multiple issues on 2007 is350 Rowzter Basic Help & Repair 1 05-08-2012 10:50 AM
Multiple issues with my 2004 IS300 DSantos Basic Help & Repair 5 01-03-2012 06:38 PM
BMW finally admits turbo lag issues on twin-turbo six, issues fix jruhi4 The Garage 2 11-18-2008 04:05 PM
